Old 06-12-2022, 07:36 AM   #15
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
Perrin 2.5” cat back issues
Originally Posted by YCK View Post
Those hangers made a lot of difference for me. Sorry to hear it didn't work for you. I have the "proper" resonated version though. Mine is paired with PSR UEL catless header and tuned for E85. If you can't cope with the stock header, maybe reconsider... It doesn't cover the exhaust sound, everything goes up a notch. I also have a liner in my car, it helps a bit too for longer trip, under the boot mat: https://www.carbuilders.com.au/mass-noise-liner. I think the "boominess" is just that exhaust note, you will never get rid of that note. Maybe just go back to the stock exhaust with your headers. Over here, a lot of the guys at the track don't bother with the catback as there is not much gain.
Thanks mate. Appreciate the feedback. It’s not horrific. I’m going to see how it goes for another couple of weeks (it is better with the hangers) and then possibly try a different resonator. At this stage I have stock headers, but would fit catted if I ever decided to change them. I’ll have a look at the boot liner, thanks.
ACT86 is offline   Reply With Quote
Old 06-12-2022, 08:05 AM   #16
YCK
Drives: Toyota 86 GTS 2019
A bit off topic, but why catted? Is this a restriction because you are in ACT? Catless Headers + E85 is the sweet spot for NA. Check out Steve's article if you haven't yet: https://www.ft86club.com/forums/showthread.php?t=81493
YCK is offline   Reply With Quote
Old 06-12-2022, 06:59 PM   #17
ACT86
ACT86's Avatar
I’d only change it for sound mate. Not looking for power, also not keen on a tune or removing cats (legalities / insurance). Considering actually having the stock header modified (by lengthening two pipes). That way I’ll retain the factory cat and not require a tune, but get a little of the boxer rumble. As I understand it the OEM 17+ header flows as well as the aftermarket Catted headers (which often still throw a code), so figure it’s the simplest way to get a bit of rumble. Still not certain I’ll bother though.
anyone use Perrin cat back 2.5 resonated with Perrin cold air intake? stlgrym3 Engine, Exhaust, Transmission 11 02-21-2018 04:35 AM
Huge issues, seat rail clip not hooking back Mikeez Issues | Warranty | Recalls / TSB 10 03-04-2015 03:48 PM
Perrin Oil Cooler Issues deange Engine, Exhaust, Transmission 137 01-29-2015 07:47 PM
Possible trade? Nameless axle-back for Perrin Resonated Cat-back GTB/ZR-1 Engine, Exhaust, Bolt-Ons 0 03-26-2013 02:51 PM
Issues Swapping Back/Forth from 5spd MT & 6spd MT? endos2000 BRZ First-Gen (2012+) — General Topics 29 02-17-2013 03:56 PM
