Old 06-06-2022, 07:42 PM   #1
boi
Drives: 2013 Brz
Need some help with my abs system
Hello all I'm having an issue with my 2013 brz I've done the 17+ abs module cluster and pp brake swap. After I did the brake swap I have a spongy pedal I've been trying to use techstream to bleed the abs as well as my friends snap on scanner but nether will connect to the abs module and I'm not sure what could be happening any advice would be greatly welcomed
boi is offline   Reply With Quote
Old 06-07-2022, 03:16 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
If you do not mind getting the car dirty, the old way of bleeding the abs would be to got to a dirt or othe low traction surface and repeatedly activate the abs system while driving. Hope this helps.
Jdmjunkie is offline   Reply With Quote
Borla "full system" VS "full system" minus headers Trashed675 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 01-07-2014 01:17 AM
Be Spoke system/ BRZ system navigation swap Mrqb22 Electronics | Audio | NAV | Infotainment 4 09-27-2012 06:48 PM
