Pat.Thornton
Old 06-06-2022, 02:47 PM   #617
Mars
Mars's Avatar
Drives: 2014 Scion FR-S
Mine would sound just as dramatic inside the garage. The clack is to be expected when rapidly accelerating the whole gearset. There's plenty of lash in there to account for that noise. Here's the sound of my backup transmission. It came out of a wrecked boosted one. This is what they sound like after some abuse. It sounds no worse today than it did when first installed....
Thank you very much for this explanation and video! Super helpful! I actually found out right after buying this car that it used to be boosted (seller never disclosed this info and there were no traces of it being boosted) when the motor went. Makes sense that my trans would sound similar. Glad to know its just a little abused, I already switched in Motul Gear Oil (whatever the recommended one on here was) and plan on doing slightly more often than recommended trans and diff oil changes due to the car's prior abuse.
...The creak is annoying, I know. Did you try my trick of pulling the top of the fork forward to bottom out the piston in the slave cylinder? Then jiggle it back and forth rapidly to move stuff around at the pivots. If the creak goes away for a while after that, then you've found the source. You'll probably also notice how badly the TOB hangs up on the quill. It's a really shitty design.
I'll have to give that exact method a shot. Initially the sound did go away so I'm sure once everything has been wiggled around it should disappear.
Again, thank you for your assistance @Ultramaroon
Mars is offline   Reply With Quote
The Following User Says Thank You to Mars For This Useful Post:
Ultramaroon (06-06-2022)
Old 09-18-2024, 02:54 AM   #618
diga
Drives: 2022 Subaru BRZ Limited 6MT
hate to keep reviving this ancient thread but apparently it's still an issue 10 years later! WTF Subaru. This starts happening after car is fully warmed up. Only about 17K miles, been to dealer service 3x now, they replaced the pedal assembly twice - not sure what they're trying to do...maybe run out the clock on my warranty which is up in 6 weeks! What's the current consensus solution on this? If I let it go is this a symptom which will become major? Or is it just an annoying Subaru thing?
diga is offline   Reply With Quote
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
