Old 07-23-2012, 07:41 PM   #57
FreedE
Price/Weight/Dyno/dB of that exhaust?
I have a feeling a longitudinal muffler like that will drone.
I'll be posting up all that info later this week with more detailed pictures.
Originally Posted by RiskyTrousers View Post
Have you installed the coilovers? How do the fronts fit with camber, any rubbing issues?
A friend of mine is coming by in the next couple of days to do a photoshoot I'll post up everything in a new thread most likely.
FreedE is offline   Reply With Quote
Old 07-24-2012, 10:21 PM   #58
os86
Drives: 2jz
good choice on wheels, compliments the white
os86 is offline   Reply With Quote
The Following User Says Thank You to os86 For This Useful Post:
FreedE (08-01-2012)
Old 08-01-2012, 12:23 PM   #59
FreedE
Update. Low and a little bit of camber and wheels fit great. No rub... no fender mods etc. still DD
Old 08-01-2012, 12:31 PM   #60
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
someone has to say it. Pics or it didn't happen. Kidding, you know we all just want to see more of the car
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Old 08-01-2012, 12:42 PM   #61
FreedE
Sorry, pics on page 1
Old 08-01-2012, 03:07 PM   #62
jedichimp
jedichimp's Avatar
Drives: yes
Oh, haha. I didn't realize you updated the original post. My bad. Drop looks good.
panda cheez
Old 08-01-2012, 04:09 PM   #63
Hayashi
Hayashi's Avatar
How is the inner clearance in the front? Still got lots of room? Like oh lets say, 5 - 8 mm more? lol
Hayashi is offline   Reply With Quote
Old 08-01-2012, 04:40 PM   #64
FreedE
Where are you referring to? The clearance between the rim and spring? Or clearance in the fender wells?
Old 08-01-2012, 06:20 PM   #65
Hayashi
Hayashi's Avatar
rim and spring or spring perch, haha my bad.
Old 08-01-2012, 06:35 PM   #66
FreedE
Oh lol. Yeah, there's tons of room now. Actually, these coilovers have slotted upper holes on the lower mounts so technically, you could get more clearance just by adjusting that and the camber plates together.
Old 10-04-2012, 08:47 PM   #67
beebo
Drives: Whiteout Scion FR-S
I am planning on getting the esm 004 wheels for my fr-s which are the same specs as these at 18x9 +38mm. I'm also dropping the car 1" on the eibach pro kit springs. My question is whether or not I should buy the 16mm whiteline camber bolts for this set up or if the drop would make the front wheels flush enough. What do you guys think? Is it necessary? I don't mind a slight poke.
beebo is offline   Reply With Quote
Old 10-05-2012, 11:47 PM   #68
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
so with the tires and wheels you have without the drop and camber, theres no rubbing or issues? bc i was thinking about getting 255/40/18 with a 18x9
HELPPPP im in desperate need before i order these haha and btw im getting winter tires to put on the stock rims for the winter only out here in NY bc i have to drive to school and what not... what size tire do you recommend ?
http://www.wheeldude.com/catalog/pro...oducts_id=6330
ScionFR-S is offline   Reply With Quote
Old 11-04-2012, 10:54 AM   #69
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
off topic but what exhaust do you have sir?
DanoFA20 is offline   Reply With Quote
Old 05-17-2013, 06:50 PM   #70
alexromero.dc
Drives: Toyota GT86
How do you feel the car with those wheels? It is slowly or is the same?
alexromero.dc is offline   Reply With Quote
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 05:09 AM
Wheel Directory: ESM 004 18x9.0 +38 beebo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 06-13-2014 02:34 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 04:15 AM
Wheel Directory: XXR 531 18x9.5 +35 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-10-2013 03:41 PM
Wheel Directory: SSR Professor SP3 18x9.0 +24 / 18x9.0 +20 RZ86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 05-18-2013 05:14 AM
