Drives: 2017 BRZ Limited - Pearl White
Wheel Spacers on stock PP rims 2017+
Hey All,
I tried doing a search, but my lord it's a lot of info, and a lot that didn't help. Is there a spacer that can be used on the stock PP rims on a non-lowered car that just bump out the wheels to be a bit more 'flush' with the fender? Thanks in advance! |
#2 |
Drives: Nevermorange FRS
I use both 15mm and 20mm spacers that have a hubcentric lip for the oem wheels. You will need to install 3” studs like ARPs to accommodate them but thats pretty easy.
The 15mm were easy to find on amazon but the 20mm were not because most in that size are the bolt on type which I don’t prefer for my use case (racing). You could probably do 5mm and maybe 10mm without changing studs. You can also get the bolt on type too since they're seemingly plentiful.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | Ducati.Femme (05-31-2022) |
#3 |
Rust bucket enthusiast
I gave my friend a 15mm bolt on spacer for the front, and 25mm bolt on for the back, was pretty good. Buy the bolt on spacers, well worth the expense if you're not buying new wheels any time soon.
Edit: if it wasn't obvious, his car is the series.yellow 2017 pp. It also has KWV3 coilovers, but the stock pp wheels and tires with the spacers, it is still fairly flush when it was stock height
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block Last edited by DarkPira7e; 05-31-2022 at 06:25 PM. |
The Following User Says Thank You to DarkPira7e For This Useful Post: | Ducati.Femme (05-31-2022) |
#4 |
Brilliant, thanks guys!
#5 | |
Drives: Whiteout track car; lava donor
The Following User Says Thank You to Four_wheel_drifts For This Useful Post: | rice_classic (06-04-2022) |
#6 |
Drives: 2016 Toyota 86
I had 20mm/30mm spacers with my non-PP wheels. I believe the offset on the PP wheels is +5 over non-PP wheels so the equivalent of 15mm/25mm spacers. With coilovers/RLCAs and camber around -2.5 the front wheels were a bit too tucked and the rears were a bit too flush for my taste. If I were to do it again, I would get 25mm spacers front and back. That would be equivalent to 20mm spacers square on PP wheels.
If you don't have coilovers and can't get as much camber, your fitment will be different obviously. Last edited by Mike_ZN6; 06-04-2022 at 10:22 AM. |
The Following User Says Thank You to Mike_ZN6 For This Useful Post: | Ducati.Femme (06-06-2022) |
Wheel Spacers on stock wheels?? | Husker BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 140 | 08-01-2020 01:05 PM |
spacers question stock frs rims | nammie81 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-05-2016 08:19 AM |
help with spacers to clear ap sprint kit with stock rims | didinyc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 11-23-2014 01:27 PM |
Stock rims +coilovers +spacers +LCAs | ang31ito | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 04-03-2014 04:22 PM |
Spacers with RCE Yellows on Stock Rims/Tires? | husker741 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 05-04-2013 04:21 AM |
