Old 06-02-2022, 11:05 PM   #1
jrhudson
Drives: 2016 scion frs
Positive battery terminal damage
Hello,
So i had some start up issues that pointed to a dead battery but battery is at full capacity. Anyways, i seem to have snapped off this part of the positive battery terminal uhh thing.
Anyways to fix this without replacing the whole battery wire harness? Or know the small part that touches the white part? Trying to look online to see if i cant just get that part but im not sure what its called.
jrhudson is offline   Reply With Quote
Old 06-02-2022, 11:33 PM   #2
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
search for battery cable lug or ring terminal and you'll find something you can use. It may become a larger project or cost prohibitive if you don't have the tool or you have to cut that one off and don't have enough length.
2020BRZtS is offline   Reply With Quote
The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post:
jrhudson (06-03-2022), Ultramaroon (06-03-2022)
Old 06-02-2022, 11:56 PM   #3
Grady
Grady's Avatar
Totaled, time to part out.
Your choices are to repair or replace. You can cut that one off to avoid shortening the harness. As above find any battery terminal end. If you do not have access to a swedger you can solder but that is not the preferred method for battery terminals.
The Following 2 Users Say Thank You to Grady For This Useful Post:
jrhudson (06-03-2022), Opie (06-03-2022)
Old 06-03-2022, 03:08 AM   #4
jrhudson
I found the whole battery harness for $45 on ebay so if i need i could just get that.
The Following User Says Thank You to jrhudson For This Useful Post:
Opie (06-03-2022)
Old 06-03-2022, 03:16 AM   #5
Bubba says to lay a piece of metal under both pieces and weld it all together.
Then, be careful with it -
JD001 (06-03-2022), jrhudson (06-03-2022)
Old 06-03-2022, 03:19 AM   #6
2020BRZtS
2020BRZtS's Avatar
That's the route I would take. By the time you got the part and the tools you are probably at the same price point or close enough it doesn't matter.
Old 06-03-2022, 03:23 AM   #7
2020BRZtS
2020BRZtS's Avatar
If Grady were the OP I recommend that based on his avatar alone.
humfrz (06-03-2022), Ultramaroon (06-03-2022)
Old 06-03-2022, 03:25 AM   #8
+1 it's a no-brainer.
Old 06-03-2022, 03:46 AM   #9
Bubba here - sorry to be late to the party.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
JD001 (06-03-2022), soundman98 (06-03-2022), Ultramaroon (06-03-2022)
Old 06-03-2022, 08:19 AM   #10
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
Knipex makes a nice double crimp tool but it isn't cheap.
We need more lead in our brass.
thomasmryan is offline   Reply With Quote
Old 06-03-2022, 04:54 PM   #11
jrhudson
...okay so i realized i bought the wrong thing. The terminal that broke was actually on the side coming from the fuse box. ugh have to get those battery terminal things for the positive side. This is annoying.
Old 06-03-2022, 05:07 PM   #12
Bubba's fix is looking pretty good right now.
humfrz (06-04-2022)
Old 06-03-2022, 05:33 PM   #13
jrhudson
I rather solder or weld it but i dont have a welder or anything like that.
Temporary solution until my terminals get here. Works!
Old 06-03-2022, 08:20 PM   #14
Would take a big-ass soldering iron/gun to get enough heat into that cable but, honestly, it's what I would do. Heat shrink is a pro move.
Part number for fusible link block on positive battery terminal? Jack Black Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 08-24-2022 09:58 AM
Battery terminal covers 2017BRZ4ME BRZ First-Gen (2012+) — General Topics 21 04-27-2020 01:04 AM
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
Battery terminal setup fuddbutter Electronics | Audio | NAV | Infotainment 0 01-24-2017 05:27 PM
Lost my battery terminal nut. qqzj BRZ First-Gen (2012+) — General Topics 3 08-05-2014 08:51 AM
