Old 06-02-2022, 04:17 PM   #1
saza26
saza26's Avatar
Dash Speakers quiet with new HU
Howdy! I just installed a Sony XAV-AX5000 Android auto unit into my 2013 Fr-s. I used a PAC RP4.2 TY11 kit so that I didn't have to hack up the oem connectors.
Upon turning everything on and playing some music I noticed it was much more bass heavy than before. Seems like the dash speakers are too quiet because if I crank up the volume they don't get very loud while the door speakers do. If a turn the low frequencies all the way down in the equalizer and turn up the high frequencies it does sound close to normal. However this seems like putting a bucket under a leak rather than patching the hole.
Not sure what could be happening here. I've seen lots of posts about the door speakers not working (mostly bc of people not wiring the amp remote turn on wire) but nothing of problems like this. Anyone have any ideas before I rip the car apart over the weekend to figure it out?
saza26 is offline   Reply With Quote
Old 06-02-2022, 10:19 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
did you check your high pass/low pass, and stock eq settings? some units default to a setup that is anything but flat/neutral.
Old 06-02-2022, 11:42 PM   #3
saza26
saza26's Avatar
SOLVED! Short story: I'm dumb. I rechecked all my connections and I had plugged the speaker connector that goes to the RP4.2 TY11 into the amplified audio out when it should've been the un-amplified audio out. Swapped it around and everything sounds great now!
The Following User Says Thank You to saza26 For This Useful Post:
soundman98 (06-03-2022)
audio, dash speakers, head unit, sony
Changing the front dash speakers / door speakers jeffs42885 Electronics | Audio | NAV | Infotainment 8 06-21-2020 07:35 PM
About dash speakers Chimera Electronics | Audio | NAV | Infotainment 10 08-02-2014 06:23 PM
No dash speakers Gir AUSTRALIA 65 03-28-2013 07:15 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 07:31 PM
Dash speakers? SteveGrillo Electronics | Audio | NAV | Infotainment 11 02-01-2013 11:51 AM
