Old 06-01-2022, 04:37 PM   #1
TooFRSh
Drives: Argento FRS MT
2013 Scion FRS won't start - Not Battery!
Hey everyone, so my car was perfectly fine right before I parked it. I just went for a carwash and then came back. After about a couple hours I went to go start the car and everything was normal until I turned the key to the on position and started to crank it. First turn of the key and all the electrical cut off. No engine turnover or anything occurred. I cleaned the battery terminals and posts and got the battery tested. Everything is good. So no battery issues. To get the electrical back up in the car I have to disconnect the battery and connect it again. Then the cycle repeats. Anybody have any ideas what this could be?
TooFRSh is offline   Reply With Quote
Old 06-01-2022, 06:29 PM   #2
Grady
Grady's Avatar
The battery.
But seriously Get a volt meter find out where you have a bad connection/losing voltage(or have voltage if you are checking ground connections). Start at the battery then work you way down the system. Without knowing where you have or do not have voltage in the system it is all just a guess.
The Following User Says Thank You to Grady For This Useful Post:
TooFRSh (06-02-2022)
Old 06-01-2022, 06:34 PM   #3
WNDSRFR
Drives: FR-S,GTI
Maybe has something to do with it ?
The Following User Says Thank You to WNDSRFR For This Useful Post:
Old 06-01-2022, 07:32 PM   #4
You didn't mention your remote start system. Disconnect all of that jazz and then start tracing stuff if needed.
humfrz (06-02-2022), TooFRSh (06-02-2022)
Old 06-02-2022, 02:54 AM   #5
@Ultramaroon , does a 2013 FRS have a remote start system?
OP, did you have the battery "load" tested?
Is that the original battery?
When you went through the car wash, was it the kind/feature that sprays water underneath the car?
Old 06-02-2022, 03:11 AM   #6
I doubt it's his battery. Sounds more like a corroded ground strap, OP just has to suck it up and troubleshoot point to point. Either that or fix it your way.
Old 06-02-2022, 11:47 AM   #7
TooFRSh
@humfrz The remote start was an aftermarket addition btw.
Hey so when I had it tested I went to Advance Auto Parts and they hooked it up to their battery tester. Not sure what all it looks for but I assume it had to have applied some load onto it to get diagnostics back.
This is not the original battery.
And when I went through the carwash it did do the underbody wash as well
The Following User Says Thank You to TooFRSh For This Useful Post:
humfrz (06-02-2022)
Old 06-02-2022, 11:50 AM   #8
TooFRSh
@Ultramaroon Yea I'm probably gonna go the tracing route just to eliminate any other possibilities.
Update: I went out to see if the car would start this morning and it fired right up. Let it sit for a bit and turned it off to see if it would start again. Then it went back to the same thing with the power cutting off. From this I'm definitely getting suspicious of some grounding issues
humfrz (06-02-2022)
Old 06-02-2022, 06:50 PM   #9
Grady
Grady's Avatar
I am back suspicious of the battery. Those quick testers do not tell you much.
2013 Scion FR-S cranks but no start!!! Btborja Issues | Warranty | Recalls / TSB 43 10-29-2023 10:30 PM
2013 FRS wont start unless battery is disconnected first KN0W Electronics | Audio | NAV | Infotainment 5 07-21-2021 10:44 AM
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
DIY: how to replace battery for push start keys, and scion to toyota swap 1GiantTurtle DIY (Do-It-Yourself) Guides 2 12-27-2014 01:24 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
