Old 05-29-2022, 09:26 AM   #1
dynarun55
dynarun55's Avatar
Drives: 2015 midnight blue limited edition.
Potentially moving to California.....Need to add CARB tune
Hey guys!
I might be moving to California in the near future. I live in a non-smog state and I have custom dyno tune so there is no way this will pass Cali-smog. I called Jackson racing and they sell their CARB tune. Is there anyway I can add the CARB tune as a switchable map to my ecu using ecutek ? I don't think the shop will give me the custom tune ROM file. Appreciate any help on this!
dynarun55 is offline   Reply With Quote
Old 05-29-2022, 09:50 PM   #2
Project_1796
Drives: Scion FRS 10 series
Originally Posted by dynarun55 View Post
Hey guys!
here are a copy of the carb bin files
https://www.dropbox.com/sh/gw64kzljt...I_Icsjh-a?dl=0
Project_1796 is offline   Reply With Quote
Old 05-29-2022, 11:52 PM   #3
dynarun55
dynarun55's Avatar
Woah! Thanks much... Now can I add this as a switchable map on my ecu ? I dont want to flash this in and then lose my custom tune.
Old 05-30-2022, 12:12 AM   #4
Project_1796
You can always save your custom tune first before reflashing, you can try to switch tunes,
Old 05-30-2022, 03:33 AM   #5
dynarun55
dynarun55's Avatar
Would you know how to save my custom maps that are currently on the ECU ? I have 2 maps right now and I'm aware about how to switch between them using the cruise control stock. I just want to add the CARB as the 3rd one.
Sent from my Pixel 3 using Tapatalk
Old 05-30-2022, 03:55 AM   #6
steve99
Drives: FT86
Hey guys!
Short answer no
Ecutek tunes while the have whats referred to as map switching its not switching a complete tune.
Its only switching a small subset on maps like base fueling and timing. All the core maps ( about 98% ) are shared between the four map modes.
also the whole idea of a CARB tune is that you cannot just switch it on and off.
the tune needs to be registered and is not able to be altered. The tune will be registered against a ecu calibration id and a checksum value so they can check if its been messed with.
You would need to buy the CARB registered tune for your car.
the new tune will completely overwrite the old current tune
Old 05-30-2022, 04:20 AM   #7
tomm.brz
Drives: brz 2017 hksv2
and you can t save extract your current tune, your only option to have it then back would be to ask your tuner to send you your tune and buy an ecutek kit to be able to flash it
Old 05-31-2022, 11:02 AM   #8
FrickingReallySlow
Drives: 2015 FR-S
Short answer no
I believe the BAR-OIS system for smog checks the CALID and then the CVN which is a hash checksum of the entire ECU plus the calibration area. IF you have a CARB compliant EO tune (and Sticker) I not sure if that has gotten into their database to verify the CVN. The California Bureau of Automotive Repair (BAR) does automatically record the CVN during smog checks (internet connection) to identify if there have been changes to the software. EO labels close to the OEM vehicle emissions control information label will let the smog check operators know that the CVN could be different and will input the EO information to the BAR. BAR has been building a database of CVNs for each EO from all vehicles tested. If BAR is concerned about a CVN, then BAR will call CARB, which will call EO issued company like edelbrock etc to verify the correct software.
FrickingReallySlow is offline   Reply With Quote
Old 05-31-2022, 06:18 PM   #9
steve99
Drives: FT86
Yes id expect that the vehicle tune CVN and tune would be individually registered in their database. So you could not simply flash a carb tune, would need to be registered in the database by a licienced shop ?
Old 05-31-2022, 06:36 PM   #10
FrickingReallySlow
Drives: 2015 FR-S
Since BAR has been collecting these CVN + CALID combos since 2015 they already have a correlation to use to determine if something has been modified. So even within a model (2013-2016 FRS/BRZ) there are many CALID+CVN that are valid and they will match the CALID to the make/model year of your car. So if they don't have enough data on like 2015 CALID + Edelbrock Eforce CARB CVN they may "fail" you and then you get reffed and they do this manual process to see if your tune is the official one supported by the aftermarket supplier (i.e edelbrock). Or they might just let you through because they've either gathered enough data or don't have enough data yet for these EO CARB sticker tunes and will keep collecting for a while longer.
btw I think you did a great write up already on this
https://www.ft86club.com/forums/showthread.php?t=130030
Old 06-06-2022, 05:47 PM   #11
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
CARB files are locked. It can only be used by the Dongle it is assigned to.
JDMChris is offline   Reply With Quote
Carb legal tune? kur0111 Southern California 3 11-02-2021 02:42 PM
Any CARB legal headers out there? (California) ragnarokfps BRZ First-Gen (2012+) — General Topics 13 06-19-2020 07:56 PM
Moving Scion FRS from California to Germany hthought Scion FR-S / Toyota 86 GT86 General Forum 10 09-10-2019 01:47 PM
Jackson Racing California / CARB / Track / FlexFuel Special! Xero-Limit Forced Induction 22 12-14-2015 12:29 PM
CARB Fine California Phantobe Off-Topic Lounge [WARNING: NO POLITICS] 6 11-22-2014 11:50 PM
