go_a_way1, MisterSheep
Old 05-22-2022, 03:38 PM   #23703
FrickingReallySlow
Drives: 2015 FR-S
Are the LEDs plug and play? I've been thinking about this too. So the Vlands only give you the boomerang and turn signals, no high beam/low beam bulbs?
Originally Posted by keenanok View Post
Switched the OEM Halogen bulbs with the Sylvania LEDs, both low and high beamsAttachment 211975
Only temporary as I wait for my Vland headlights to arrive!
FrickingReallySlow is offline   Reply With Quote
Old 05-22-2022, 08:58 PM   #23704
keenanok
keenanok's Avatar
Drives: 2013 Whiteout FR-S
Yes they are! You can get H11 bulbs from anywhere and they’ll fit the low beams. I forgot which bulbs are the high beams, but they are also plug and play. The Vlands don’t give you bulbs, you have to order them! However, if you get the OLM headlights from FTSpeed (the ones on my car), they come with an HID projector, bulbs, and ballast, all with it for not too much more. Definitely the way to go in my opinion!
keenanok is offline   Reply With Quote
The Following User Says Thank You to keenanok For This Useful Post:
FrickingReallySlow (05-23-2022)
Old 05-23-2022, 11:59 AM   #23705
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by RToyo86 View Post
How do you like the power difference compared to stock?
I tried a 2017 decatted header and ultimately swapped back to my gruppe-s after trying different header/catback setups.
I forgot to ask. Would like to hear on why you preferred the Gruppe-S and the difference over the decatted header.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 05-24-2022, 12:21 AM   #23706
keenanok
keenanok's Avatar
took a side profile shot of my ride, these cars are so beautiful Name:  IMG_0189.jpg
The Following 7 Users Say Thank You to keenanok For This Useful Post:
DarkSunrise (05-24-2022), KMA KiCKz (05-25-2022), MJones_RB (05-25-2022), Nails (05-24-2022), NLSP (05-28-2022), soundman98 (05-25-2022), Ultramaroon (05-25-2022)
Old 05-24-2022, 02:56 PM   #23707
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
The powerband with the gruppe-s feels better to me.
Power from 3500-5500 felt smoother and stronger. I also like the sound of UEL with stock catback over stock setup.
Tuning with both headers was done by @tomm.brz
I went from gruppe-s to decatted back to gruppe-s. It was an experiment to see if a different header would make the greddy SP catback I purchased useable for my ears.
The Following User Says Thank You to RToyo86 For This Useful Post:
Compelica (05-25-2022)
Old 05-25-2022, 01:32 PM   #23708
Compelica
Compelica's Avatar
Drives: 86 GT
Any dyno graphs with both headers?
Old 05-25-2022, 01:41 PM   #23709
RToyo86
RToyo86's Avatar
The car was street tuned with data logs on the same stretch of road. I have tried using virtual dyno to get a rough idea. I did not do a baseline so numbers are not worth much. Used a different road when doing the OEM decat unfortunately, so virtual dyno would be even less accurate for any sort of valid comparison.
This was gruppe-s tune, early-mid revision vs final with stock front pipe.
Gruppe-s with decatted front pipe
https://datazap.me/u/mygotousername/...d?log=0&data=1
Decatted with OEM front pipe
https://datazap.me/u/mygotousername/...log=0&data=1-7
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Compelica (05-26-2022), SuperTom (05-25-2022)
Old 05-26-2022, 07:28 AM   #23710
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
Fitted a new knob
ACT86 is offline   Reply With Quote
The Following 5 Users Say Thank You to ACT86 For This Useful Post:
DarkSunrise (06-02-2022), MJones_RB (05-27-2022), NLSP (05-28-2022), RToyo86 (05-26-2022), Wally86 (05-26-2022)
Old 05-28-2022, 07:37 AM   #23711
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
made a quick clip of the current exhaust setup - Fujitsubo front-pipe (catless, dual-resonated) x TRD Special Edition exhaust (with Vibrant Ultra Quiet resonator)
The Following User Says Thank You to NLSP For This Useful Post:
FRSapex (05-30-2022)
Old 05-29-2022, 11:09 AM   #23712
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
tein installed
I finally got around to installing Tein Flex's on my FRS. I lower the car only 3/4". I'll get an alignment next week.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
MJones_RB (05-31-2022), SuperTom (05-29-2022), Wally86 (05-31-2022)
Old 06-02-2022, 09:25 AM   #23713
FSFRS
Drives: '13 FR-S Firestorm
I painted my RPF1s white.
Went to a Drive Thru and got asked if my car was a BRZ or FRS, lol.
Told them it was an FRS on the inside, BRZ on the outside as they're looking at my FRS interior lol.
My camber up front is 0 and there is a slight reverse rake. Rear is at 2 degrees. Do you guys think camber bolts can help with the fronts being slightly higher than the rear?
FSFRS is offline   Reply With Quote
The Following 4 Users Say Thank You to FSFRS For This Useful Post:
DarkPira7e (06-14-2022), MJones_RB (06-02-2022), orz (06-04-2022), Wally86 (06-02-2022)
Old 06-02-2022, 11:22 AM   #23714
Compelica
Compelica's Avatar
Drives: 86 GT
Changed from a double line to a single line number plate. Here, number plates are not government issued so you can create your own as long as it's within regulations.
Also more airflow.
The Following 2 Users Say Thank You to Compelica For This Useful Post:
MJones_RB (06-02-2022), Wally86 (06-02-2022)
Old 06-10-2022, 07:18 PM   #23715
RickyBobby
Drives: 2013 Firestorm FR-S AT
Nothing craptastic. The top of the shift knob on the AT is very plain. Instead of getting a new knob I got a stick-on 86 emblem overlay from here: https://koreanautoimports.com/86-sci...mblem-overlay/
I used a 25% off coupon but with shipping it's still pricey.
Looks good from above.
But it's a bit too big for the top and overhangs. Yes, it's centered. I would not recommend getting one of these.
I also purchased a Uniden R4 RD from Amazon for $350. to replace my R3 which will go in my other vehicle. Cheapest it's been, everywhere else it's $450. https://www.amazon.com/R4-Long-Range.../dp/B09LRHV6QT
It's sold by 3rd party vendors but ships from Amazon warehouses. Got it in 2 days.
Review by Vortex: https://www.vortexradar.com/2021/11/uniden-r4-review/
It has better range and more features than the R3 and R7. The R7 though has them arrows.
About the same size as the R3 but the power connector is on the right side.
I used the same mount and power cord from the R3. https://www.ft86club.com/forums/show...&postcount=101
And last but least, got some new plates today. It's actually a law in TN that about every eight years, if there's funds, they issue new plates. I read, that 300,000 TN'ers, not me, voted 42% for the new blue plate.
The problem with the new plate's dark blue color is that traffic light cams, speed cams, and cops, can't read it. https://www.thedrive.com/news/44396/...-plate-readers
https://www.actionnews5.com/2022/02/...icense-plates/
I don't see this as a problem.
At least registration renewal is cheap in TN, $29./vehicle. That includes the new plate.
RickyBobby is offline   Reply With Quote
The Following 2 Users Say Thank You to RickyBobby For This Useful Post:
RToyo86 (06-14-2022), Wally86 (06-13-2022)
Old 06-11-2022, 03:46 AM   #23716
RToyo86
RToyo86's Avatar
Finished up suspension refresh. Added pedders Strut mounts, New springs, and end links. Old end links were pretty crusty with 100k km.
Forgive the mess friend snapped a shot while I was trying to finish before sundown.
The Following 4 Users Say Thank You to RToyo86 For This Useful Post:
blsfrs (06-11-2022), DarkPira7e (06-14-2022), DarkSunrise (06-12-2022), knapper (06-14-2022)
