Drives: 2020 86
Mystery Spade
I'm installing a digital rear view mirror (https://amzn.to/3LP4ynX ) but before I hardwire the power supply and use a back plate to replace the strap security setup I want to test it for a while to make sure it is a reliable device.
The problem is the cigarette power supply doesn't work. So far I've removed the head unit and half the dash but I can't seem to find where this spade plugs into. Does this spade look familiar to anyone and, if so, where is the plug connection? The fuse is good and the digital rear view mirror powered up on a neighbor's car so my hope that my assumption that this spade is related to the cigarette lighter and by connecting it I can test the device. Here's a couple of photos of the spade below. It is covered with a transparent sheath and is located behind the radio. The wire is dark blue with a black stripe. https://i.postimg.cc/RhTKxHSB/IMG-20220527-210135.jpg https://i.postimg.cc/kMjgzs95/IMG-20220527-205959.jpg My guess is that I've spent so much time and effort checking wiring and replacing head units that the electrical connection came apart. Thanks! |
#2 |
Just find 12V and splice it in
Sent from my SM-G975U using Tapatalk |
| The Following User Says Thank You to p1l0t For This Useful Post: | blueskiesgreenlights (05-28-2022) |
#3 |
Drives: Crapcan
It’s supposed to be blank. When you buy a trac box from GJP that is where it plugs in so I believe it is a com port for CAN. You can see it’s mate in the pictures on the trac box pictures.
https://www.geraldjustprojects.com/p...gt86-trac-box/
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blueskiesgreenlights (05-28-2022) |
| Tags |
| cigerette lighter spade |
| RiP Kate Spade | Jordanwolf | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 06-07-2018 05:16 AM |
| Mystery problems | Ashikabi | Engine, Exhaust, Transmission | 10 | 04-04-2016 11:29 AM |
| mystery body kit... (no longer a mystery) | Alita | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-16-2015 07:10 PM |
| NEW ADR SPADE 18" Rims $300 | raven1231 | Wheels and Tires | 0 | 06-02-2015 03:08 PM |
| MAF Mystery! | KoolBRZ | Software Tuning | 14 | 12-08-2014 07:11 PM |
