Old 05-27-2022, 05:44 PM   #1751
No wonder your old cars ran like shit -
Actually, you raise a good point. Maybe I was doing it wrong all those years. I figured as long as I kept the gap on the skinny side, it would guarantee enough time for the coil to do its thing.
humfrz (05-27-2022)
Old 05-27-2022, 05:47 PM   #1752
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
A dwell meter is attached so that the red lead on your meter is attached to the negative terminal on the ignition coil. -
If that is so, why does the set of points have a slot in the bottom plate?
Scroll up. Do you see a red lead?
I admit, I have a cheat sheet somewhere how to hook the dwell meter up to my jeep truck Buick 350, but never once needed a dwell meter for my other cars.
Slot on the points is to set the gap with a screw driver using a Feeler guage, or back in in your day, a match book cover.
humfrz (05-27-2022)
Old 05-27-2022, 05:50 PM   #1753
Right? Then just set base timing by watching/listening for the spark.
humfrz (05-27-2022)
Old 05-27-2022, 05:55 PM   #1754
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’m so confused. Where do I put the matchbook?
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
humfrz (05-27-2022), soundman98 (05-27-2022), Spuds (05-27-2022), Ultramaroon (05-27-2022)
Old 05-27-2022, 06:07 PM   #1755
I did a mix of all three. Use a feeler, adjust by watching if felt needed and then check with meter once back together. Was pretty rare to have to go back in and change the angle.
Until of course the temperature or humidity changed, the wind changed direction, a bird flew over or you sneezed while turning left and you had to adjust it all again.
humfrz (05-27-2022), soundman98 (05-27-2022), Ultramaroon (05-27-2022)
Old 05-27-2022, 06:14 PM   #1756
I know right!
I tried to tune the FRS but couldn’t find the bolt to loosen the distributor so I could give it nudge to advance the timing and there is not an air/fuel mixture screw to be found.
humfrz (05-27-2022), NoHaveMSG (05-27-2022), soundman98 (05-27-2022)
Old 05-27-2022, 06:15 PM   #1757
Hey, OK, so your leads are all faded, how about hooking up the positive lead to the coil?
You're the one that said "And the points don't have an adjustment", which is not what I see in your picture.
Yep, a match book cover will get you close -
Old 05-27-2022, 06:22 PM   #1758
You put the matchbook under one leg of your laptop so it won't tilt.
The Following 4 Users Say Thank You to humfrz For This Useful Post:
bcj (05-28-2022), NoHaveMSG (05-27-2022), soundman98 (05-27-2022), Tcoat (05-27-2022)
Old 05-27-2022, 06:25 PM   #1759
I didn't know you have tried to tune an MG -
Old 05-27-2022, 06:28 PM   #1760
I know right!
Fer sure, fer sure - just open the hood, check the oil, shut the hood - call it good -
Old 05-27-2022, 06:30 PM   #1761
They were all about the same I think. Although I would say the Karmann Ghia was probably the most sensitive so maybe the European stuff was the worst.
Old 05-27-2022, 06:30 PM   #1762
The hood opens?
Old 05-27-2022, 06:42 PM   #1763
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Well that is inconvenient when I need to relight my cigar.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Old 05-27-2022, 06:53 PM   #1764
Just use the lighter in the dash
Oh wait….
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 12:00 PM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-27-2017 12:33 AM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 08:35 PM
