#23703 | |
Drives: 2015 FR-S
Are the LEDs plug and play? I've been thinking about this too. So the Vlands only give you the boomerang and turn signals, no high beam/low beam bulbs?
#23704 | |
Drives: 2013 Whiteout FR-S
Yes they are! You can get H11 bulbs from anywhere and they’ll fit the low beams. I forgot which bulbs are the high beams, but they are also plug and play. The Vlands don’t give you bulbs, you have to order them! However, if you get the OLM headlights from FTSpeed (the ones on my car), they come with an HID projector, bulbs, and ballast, all with it for not too much more. Definitely the way to go in my opinion! |
| The Following User Says Thank You to keenanok For This Useful Post: | FrickingReallySlow (05-23-2022) |
#23705 |
Drives: 86 GT
I forgot to ask. Would like to hear on why you preferred the Gruppe-S and the difference over the decatted header.
DIY stuff at Compelica Works
#23706 |
took a side profile shot of my ride, these cars are so beautiful
| The Following 7 Users Say Thank You to keenanok For This Useful Post: | DarkSunrise (05-24-2022), KMA KiCKz (05-25-2022), MJones_RB (05-25-2022), Nails (05-24-2022), NLSP (05-28-2022), soundman98 (05-25-2022), Ultramaroon (05-25-2022) |
#23707 | |
Drives: 17 Asphalt 86
Power from 3500-5500 felt smoother and stronger. I also like the sound of UEL with stock catback over stock setup. Tuning with both headers was done by @tomm.brz I went from gruppe-s to decatted back to gruppe-s. It was an experiment to see if a different header would make the greddy SP catback I purchased useable for my ears. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | Compelica (05-25-2022) |
#23708 | |
Drives: 86 GT
#23709 |
The car was street tuned with data logs on the same stretch of road. I have tried using virtual dyno to get a rough idea. I did not do a baseline so numbers are not worth much. Used a different road when doing the OEM decat unfortunately, so virtual dyno would be even less accurate for any sort of valid comparison.
This was gruppe-s tune, early-mid revision vs final with stock front pipe. ![]() Gruppe-s with decatted front pipe https://datazap.me/u/mygotousername/...d?log=0&data=1 Decatted with OEM front pipe https://datazap.me/u/mygotousername/...log=0&data=1-7 Last edited by RToyo86; 05-25-2022 at 11:04 PM. |
#23710 |
Drives: English, French, Swedish & Japanese
Fitted a new knob
| The Following 5 Users Say Thank You to ACT86 For This Useful Post: | DarkSunrise (06-02-2022), MJones_RB (05-27-2022), NLSP (05-28-2022), RToyo86 (05-26-2022), Wally86 (05-26-2022) |
#23711 |
Drives: 2014 Ultramarine FR-S
made a quick clip of the current exhaust setup - Fujitsubo front-pipe (catless, dual-resonated) x TRD Special Edition exhaust (with Vibrant Ultra Quiet resonator)
| The Following User Says Thank You to NLSP For This Useful Post: | FRSapex (05-30-2022) |
#23712 |
Drives: 2013 frs base
tein installed
I finally got around to installing Tein Flex's on my FRS. I lower the car only 3/4". I'll get an alignment next week.
#23713 |
Drives: '13 FR-S Firestorm
I painted my RPF1s white.
Went to a Drive Thru and got asked if my car was a BRZ or FRS, lol. Told them it was an FRS on the inside, BRZ on the outside as they're looking at my FRS interior lol. My camber up front is 0 and there is a slight reverse rake. Rear is at 2 degrees. Do you guys think camber bolts can help with the fronts being slightly higher than the rear? Last edited by FSFRS; 06-02-2022 at 09:37 AM. |
| The Following 4 Users Say Thank You to FSFRS For This Useful Post: |
#23714 |
Drives: 86 GT
Changed from a double line to a single line number plate. Here, number plates are not government issued so you can create your own as long as it's within regulations.
Also more airflow. ![]() ![]()
#23715 |
Drives: 2013 Firestorm FR-S AT
Nothing craptastic. The top of the shift knob on the AT is very plain. Instead of getting a new knob I got a stick-on 86 emblem overlay from here: https://koreanautoimports.com/86-sci...mblem-overlay/
I used a 25% off coupon but with shipping it's still pricey. Looks good from above. But it's a bit too big for the top and overhangs. Yes, it's centered. I would not recommend getting one of these. I also purchased a Uniden R4 RD from Amazon for $350. to replace my R3 which will go in my other vehicle. Cheapest it's been, everywhere else it's $450. https://www.amazon.com/R4-Long-Range.../dp/B09LRHV6QT It's sold by 3rd party vendors but ships from Amazon warehouses. Got it in 2 days. Review by Vortex: https://www.vortexradar.com/2021/11/uniden-r4-review/ It has better range and more features than the R3 and R7. The R7 though has them arrows. About the same size as the R3 but the power connector is on the right side. I used the same mount and power cord from the R3. https://www.ft86club.com/forums/show...&postcount=101 And last but least, got some new plates today. It's actually a law in TN that about every eight years, if there's funds, they issue new plates. I read, that 300,000 TN'ers, not me, voted 42% for the new blue plate. The problem with the new plate's dark blue color is that traffic light cams, speed cams, and cops, can't read it. https://www.thedrive.com/news/44396/...-plate-readers https://www.actionnews5.com/2022/02/...icense-plates/ I don't see this as a problem. At least registration renewal is cheap in TN, $29./vehicle. That includes the new plate. Last edited by RickyBobby; 06-10-2022 at 08:00 PM. |
#23716 |
Finished up suspension refresh. Added pedders Strut mounts, New springs, and end links. Old end links were pretty crusty with 100k km.
Forgive the mess friend snapped a shot while I was trying to finish before sundown.
| The Following 4 Users Say Thank You to RToyo86 For This Useful Post: |
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 05:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 07:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 11:19 PM |
