Old 05-13-2022, 08:06 AM   #1
Nickel
Nick
Drives: 2013 10 Series GT86 #182 of 2500
Sparco Sprint in a 10 Series
Last night, my friend and I swapped my new Sparco Sprint into my 10 Series. I used the Buddy Club adjustable rail and as others have posted on this forum, I used the 1w 3.3 ohm resistors that you can get from Amazon. Everything worked out good. The brackets are maxed out but I wish I could get the seat to move a mm or so to the right, but it's nothing I can't get used to. Anyway, here's some pics.
2013 Scion FR-S 10 Series MT #182 of 2500/2007 BMW Z4 3.0si Coupe/2016 Yamaha FZ-09/2022 Ford Mustang Mach 1 Handling Package MT Recaro 700A (#N3956)/2023 Toyota Camry XSE
Instagram: @the_white_comet_of_zion
Nickel is offline   Reply With Quote
Old 05-13-2022, 08:21 AM   #2
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Looks good, would you be able to point me into the specific rails/supporting equipment you got. How's the feel? Do you sit lower?
spcmafia is offline   Reply With Quote
Old 05-13-2022, 09:04 AM   #3
Nickel
Nick
Sure. So the rail is a Buddy Club super low BC08-RSBSRZN6-L. L is for left so if you want both, you'd have to get different rails. I got mine from eBay because that's where it was in stock. The rail will work with most any seat, but the buddy rail has tons of adjustability so you can sit lower or higher than stock. I've got it on basically the lowest sitting with one up in the front so I have a bit of a rearward rake. I'm 5'10" 140 lbs and wear a 30W32L. This seat is the standard size and fits me well and I'm definitely sitting lower than stock but not by a whole lot.
My rail didn't come with any screws for the side seat mounts but that screw size is an M8-1.25x30 Socket cap Allen and I used M8 washers with them.
As far as feel. Obviously, you don't have to fight being upright so you can feel a lot more of what the car is doing. I'd say spray the rail with WD40 because the grease that's on it isn't enough, the rail is still tight. My only real complaint but this is with every racing seat I've had is that I wish I could sit maybe a mm or 2 more to the right but the brackets are maxed out. It's not a performance issue, just a mental thing.
Old 05-13-2022, 09:45 AM   #4
spcmafia
spcmafia's Avatar
Interesting, thanks for the info! Definitely something to look into if I ever decide to switch the seats. Are you keeping the stock seatbelt or looking to upgrade to a harness, if so, which combo are you looking at.
Old 05-13-2022, 10:53 AM   #5
Nickel
Nick
Well, a harness without a HANS device would be dangerous on the street. I haven't ever used one of those ASM harnesses but if they work the way a stock seat belt does where it gives during a crash then that may be worth looking into but I'm going to use the stock belt for now. I don't really want to add a harness bar as this is still one of my daily drivers but we'll see. It depends on what's needed when I sign up my next track day.
Old 05-14-2022, 10:50 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Bucket seat without rollcage - dangerous.
Driving without helmet on car with rollcage - dangerous.
Driving with helmet on street due reduced visibility - dangerous.
Multipoint harness without hans - dangerous.
And little sense of stock airbags in car with multipoint harness, due different deployment distances.
There is reason why many say it's bad/wrong to mix & match stock & sport safety systems instead of going all-out stock or all-out sport safety systems, why in some events tech inspection won't approve car with such mix to participate, or why in some countries such mixes are making car non street-legal.
I'd suggest at most going for reclaimable back recaro seats (though they also slightly compromise eg. working of side airbags), dropping rest. Or make car track-only, transportable to track on trailer, with all the stuff, bucket seat, multipoint harness, rollcage (and obviously helmet & hans device for yourself).
churchx is online now   Reply With Quote
Old 05-17-2022, 11:31 AM   #7
Nickel
Nick
A fixed bucket seat with the proper safety ratings alone and the 3 point belt working as it should is as safe as the stock seat. Sure you don't get the side air bags but you're in an FIA SFI seat.
Porsche uses fixed bucket seats, a half cage, and the 3 point belt in their road cars in some cases and those cars are very safe.
Old 05-17-2022, 12:40 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Porsche .. probably in properly designed/engineered way, with various safety systems designed/configured to work properly together. Not just some mashup from random aftermarket parts from various shops, often selected more by looks and price.
Proper bucket seat is very strong/rigid. And if you are fixed in it in car without rollcage, in case on roll over it won't fold unlike stock adjustable seats. And with multipoint harness one wouldn't be able to submarine below (and also one risks breaking neck due being in such seat and with such harness w/o hans device in frontal crash if there are no properly deploying airbags to help .. which are there in mentioned porsche, yet are not in twins, rather deploying with wrong timing/distance if keeping stock airbags, or no airbags if also steering wheel replaced with some aftermarket with quick release hub. So in this case .. brought up example of porsche imho will serve in bad way, as twins owners here might think due it that it's safe to mix & match safety systems even if they randomly buy them and install/use without properly thinking out that thoroughly.
Old 09-01-2023, 09:40 PM   #9
toyota_86
Drives: Toyota 86 (old) / GR86 - (current)
Are the seats comfortable? Thinking not getting one myself as I'm too old to be straining at events.
toyota_86 is offline   Reply With Quote
AP SPRINT BIG BRAKE KIT (Pending) & ap sprint pads, cyro rear rotors woojukim116 Brakes, Suspension, Chassis 1 03-05-2020 11:33 AM
Sparco rails, Sparco mount plate, stock parts Shawn86frs Interior Parts (Incl. Lighting) 4 01-02-2019 07:36 AM
FS: Selling Sparco Evo 2 Blue Seat + Sparco Steering Wheel HiiiPwrFRS Interior Parts (Incl. Lighting) 4 04-09-2018 12:19 PM
Custom Center console plaque and Sparco Sprint seat(red) Ashikabi Interior Parts (Incl. Lighting) 16 01-06-2017 02:18 PM
WTB: Sparco Sprint V Skurj Canada Classifieds 3 06-09-2014 08:06 PM
