Old 05-10-2022, 07:56 PM   #15
Originally Posted by KillerBMotorsport View Post
I've never looked at the PCV diagram for a CVT, but I would bet $1 it's because an auto does not pull nearly as much manifold vacuum when you let off the throttle. So an external vacuum source is required.
If you transition from throttle to brake in a manual, you get a lot of manifold vacuum. In an auto, you take your foot of the throttle it upshifts (and some CVTs go to idle) and you have little-to-no vacuum.
Not a CVT. If I had to guess I would say the pressure difference is why though. though.
Old 05-10-2022, 08:37 PM   #16
KillerBMotorsport
KillerBMotorsport's Avatar
Well then, go to the brake booster and follow the vacuum line? Does it go to an external vacuum source like the 2022 models?
KillerBMotorsport is offline   Reply With Quote
Old 05-11-2022, 08:12 AM   #17
The auto goes to a separate pump. The manual does not. That is the whole point of this question.
Old 05-11-2022, 11:52 AM   #18
WNDSRFR
Drives: FR-S,GTI
What do the boosted guys do for vacuum?
If you have a positive manifold pressure you won't have any vacuum for the brake booster.
I know my GTI has a vacuum generator to boost the brakes to counter act the turbo.
What gives?
Old 05-11-2022, 01:26 PM   #19
Arcadien Angel
I may be an idiot
Arcadien Angel's Avatar
Drives: Winona - White 2014 Scion FR-S
Thanks for the replay, that does make some sense, but the FRS does not have a CVT. The gear ratios are a little different, but being in 6th gear in the auto and 6th gear in the manual should pull almost the same vacuum. Even in 6th gear, an angine with an AT will pull heavy vacuum during engine braking, same as an MT.
To further the point, and Edelbrock Supercharger on these cars is the same for AT and MT, and it needs vacuum for the bypass valve. If the vacuum was different on MT and AT, then the Bypass vacle should act differently or incorrectly if you have an AT, which it does not.
Winona, My Wingless Angel
Edelbrock SC w/ Flex Fuel - 18x9.5 Titan 7 wheels w/ 265/35x18 Michelin PS4S - Radium Dual Catch Cans - Verus Aero - OEM Brembos - Prototype HVT 6100e Dynamic Dampening Coilovers - JDL 4-2-1 EL / OP / Dual Catted FP w/ Greddy SP Supreme Catback
Arcadien Angel is offline   Reply With Quote
Old 05-11-2022, 01:28 PM   #20
RedReplicant
Drives: None
What gives?
The brake booster effectively stores vacuum since there is a one way check valve inline.
As long as the booster and check valve aren't leaking then you will regenerate booster vac on decel. It is possible to get into a case where you get on and off the brakes without lifting throttle under boost and that ends in a hard pedal, but it is a series of steps that doesn't normally happen, especially in a RWD car. I experienced it in a turbo Miata and it was an interesting discovery.
RedReplicant is offline   Reply With Quote
The Following 3 Users Say Thank You to RedReplicant For This Useful Post:
Arcadien Angel (05-11-2022), Ohio Enthusiast (05-11-2022), WNDSRFR (05-12-2022)
Old 05-11-2022, 01:33 PM   #21
Arcadien Angel
I may be an idiot
What gives?
Not sure. If the vacuum lines are plumbed after the TB, then even on a boosted application, the manifold sees high vacuum since the TB is closed and the engine is still trying to suck in air. But that's just a guess. Assuming that the setup is standard: turbo -> throttle body -> intake manifold.
Old 05-11-2022, 02:06 PM   #22
KillerBMotorsport
My mistake, but it's an auto, which is essentially the same.
They do the same thing as before being boosted. None of the older boosted cars have vacuum pumps. No STi does. You have to do some pretty odd things (even beyond 'normal' track use) in order for it to cause an issue.
Old 05-11-2022, 02:08 PM   #23
KillerBMotorsport
If you really want a vacuum source, you might be able to retrofit the vac pump from a 2022. They all have a vacuum pump. Same with the newer FA20/24 WRX.
Old 05-11-2022, 02:13 PM   #24
Not really sure why you are so concerned with this. Send an email to the Subaru engineers and ask them why. They obviously have a reason but everybody making up guesses is just pissing into the wind.
Old 05-11-2022, 02:24 PM   #25
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
A M/T sees multiple vacuum spikes on acceleration through the gears, an A/T doesn`t see any.
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
RedReplicant (05-11-2022), Ultramaroon (05-11-2022)
Old 05-11-2022, 04:05 PM   #26
I only flat-foot shift. Besides, brakes are for losers.
gen3v8 (05-11-2022)
Plastic Vacuum Tube for Perrin Inlet Tube sebastiansim Engine, Exhaust, Transmission 5 05-04-2018 08:29 PM
2013 intake manifold vs 2017 Aluminium intake manifold Bobster Engine, Exhaust, Transmission 29 12-19-2016 10:40 AM
wtb: sound tube delete inlet tube Jimmy817 Engine, Exhaust, Bolt-Ons 1 12-21-2014 09:15 AM
'Induction Roar Manifold Tube' White64Goat BRZ First-Gen (2012+) — General Topics 1 04-28-2013 06:51 PM
