Old 05-06-2022, 12:35 PM   #1
andys_garage
Drives: 2022 GR86 Premium Track bRed
2022+ Track day part numbers
I just got a GR86 and am working on buying up parts in advance of my first track day. I realized pretty quickly it's hard to find parts since the car is so new, so I figured I'd start this thread with correct part numbers and where to easily find them. This is explicitly for compatibility with oem hardware - oem struts/CA's, oem brake calipers, etc. "Oh yeah this fit after I threw on the 2013 brembos" is out of scope.
Brake Pads:
Raybestos ST-43 Front #1539 lpiracing.com
Raybestos ST-43 Rear #1124.16 lpiracing.com - out of stock, no restock date.
Brake Rotors:
Centric Plain 120 Front #120.47021 tirerack.com amazon.com
Centric Plain 120 Rear # 120.47031 tirerack.com amazon.com
Oil Cooling:
ColorFittings Arctic Series Oil Cooler Kit # CF-OCC-02-FRS-001-XX Colorfittings.com
Suspension Adjustment:
Whiteline Front Camber Bolts # KCA414 amazon.com
Air Filter:
K&N #33-5060 amazon.com
Please respond with any other relevant items which you've used and would like to recommend, and I'll try to update frequently.
andys_garage is offline   Reply With Quote
Old 05-06-2022, 08:29 PM   #2
CSG Mike
CSG Mike's Avatar
Basically everything is interchangeable with the 1st gen *except* for some air filters, and of course, excluding factory Brembos.
If you're having trouble finding something, feel free to message me and I'll get you set up properly.
Old 05-07-2022, 10:05 PM   #3
jflogerzi
jflogerzi's Avatar
Why replace factory rotors now. You just need pads and brake fluid.
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
Old 05-09-2022, 09:32 AM   #4
andys_garage
I did that on my first track day in my old WRX and completely destroyed the rotors. This set of pads and rotors will go on a day before and come off a day after.
Plus, they'll need to be replaced at some point anyway.
Old 05-10-2022, 04:38 PM   #5
CSG Mike
CSG Mike's Avatar
But, this isn't a WRX.
You'll be good with just pads and fluid.
Old 05-10-2022, 04:53 PM   #6
andys_garage
gotta love light cars!
The Following User Says Thank You to andys_garage For This Useful Post:
CSG Mike (05-10-2022)
2022 GR86 & BRZ Post Serious Performance Numbers (Nearly 1g Skidpad)! [C&D Review] Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 3 11-24-2021 08:18 AM
Part Diagrams / Numbers for BRZ (like RealOEM for bmw), Part Vendors vlad128 BRZ First-Gen (2012+) — General Topics 7 06-29-2018 05:05 PM
Part numbers or part diagram? pacemkr Engine, Exhaust, Transmission 6 08-22-2016 02:44 PM
How do I get JDM part numbers? InstantNoodles Cosmetic Modification (Interior/Exterior/Lighting) 2 07-09-2012 05:29 PM
part numbers Staticfrost BRZ First-Gen (2012+) — General Topics 5 05-29-2012 01:02 PM
