Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 05-06-2022, 05:57 PM   #1
quikag
Drives: '22 BRZ Limited 6MT - Ignition Red
2022 Subaru BRZ Top Speed Run 140mph on private road
Not bad for an NA 4 banger. Car felt rock solid at 140mph. Great chassis that can clearly handle more power and speed. Loving this car!
quikag is offline   Reply With Quote
The Following 2 Users Say Thank You to quikag For This Useful Post:
Code Monkey (05-06-2022), Lantanafrs2 (05-10-2022)
Old 05-06-2022, 06:00 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Solid? At what speed did the lightness in steering go away at?
Old 05-06-2022, 06:06 PM   #3
Up4speed
Drives: 2023 BRZ Limited
"Private road"...."Hazard reported ahead".....hmmmmm lol
Up4speed is offline   Reply With Quote
The Following User Says Thank You to Up4speed For This Useful Post:
OkieSnuffBox (05-10-2022)
Old 05-07-2022, 09:10 AM   #4
KillerBMotorsport
KillerBMotorsport's Avatar
You should calibrate to GPS. There are some pretty decent apps for this, but generally indicated is lower than reality. My 05 STi was horrible, off by over 10mpg at 150 at a half mile event :/
Even so, 1-5 gears seem to pull pretty consistently. 6th gear acceleration is definitely noticeable slower. Was more of an RPM drop than I would have expected at that speed.
KillerBMotorsport is offline   Reply With Quote
The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post:
DarkPira7e (05-07-2022), quikag (05-07-2022), timurrrr (05-07-2022)
Old 05-07-2022, 10:18 AM   #5
AK2112
AK2112's Avatar
Drives: 22 BRZ
I've been impressed by how planted the car feels at high speeds. It's really nice.
AK2112 is offline   Reply With Quote
The Following User Says Thank You to AK2112 For This Useful Post:
quikag (05-07-2022)
Old 05-07-2022, 11:23 AM   #6
quikag
Steering lightness has almost zero to do with chassis stability at high speed.
This car feels surprisingly solid at triple digit speeds. I’ve owned many high performance cars (991.2 GT3, 981 GT4, current C6 ZR1, current CT5V Blackwing, etc.) and this car feels good, especially considering the price point.
The Following 3 Users Say Thank You to quikag For This Useful Post:
BRZ549 (05-08-2022), PBR (05-07-2022), Up4speed (05-07-2022)
Old 05-10-2022, 09:42 AM   #7
dragoontwo
dragoontwo's Avatar
So unloading the front suspension at higher speeds has nothing to do with stability?
Old 05-10-2022, 10:26 AM   #8
quikag
Nope, unless you are turning or the suspension is crap and you get significant float. Even still, my point still stands. This car, for $30k, has surprisingly good stability at high speeds. Suspension compliance, chassis rigidity, and precise steering give it the feel of a more expensive and sophisticated car. I'm surprised how effortlessly it will go down the road at 110-130mph (obviously engine is spinning, but it seems happy too).
Old 05-10-2022, 11:00 AM   #9
OkieSnuffBox
Drives: '23 BRZ Limited
Quoting because me thinks OP is full of shit.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 05-10-2022, 01:06 PM   #10
Originally Posted by KillerBMotorsport View Post
You should calibrate to GPS. There are some pretty decent apps for this, but generally indicated is lower than reality. My 05 STi was horrible, off by over 10mpg at 150 at a half mile event :/.
Actually isn't it the other way around (Speedometers tend to read high rather than low, by SAE regulations) unless of course you've changed your tires out for a different size without recalibrating.
The US doesn't have specific regs on speedometer speeds but most European countries require the speedometer to NOT read low, but it can be off by as much as 10% on the high side (it says you are going 66kph but you are doing 60kph).
Every car I've tested with GPS always read high by a varying degree. Never seen one with correct tires read low. Then I again I don't commonly drive my cars at 150MPH either.
Old 05-10-2022, 01:12 PM   #11
dragoontwo
dragoontwo's Avatar
Actually isn't it the other way around (Speedometers tend to read low rather than high, by SAE regulations) unless of course you've changed your tires out for a different size without recalibrating.
Interestingly enough at least one of my Ducatis owners manual states the percentage of how high that the readout displays, but that the ECU sees the correct speed.
Old 05-10-2022, 01:20 PM   #12
Same with most modern cars. All the traction nannies need accurate speed to do their jobs but that information never makes it to the speedometer.
Tesla is a bit of an exception for this as they use all available data to indicate the speed, which usually makes them dead on.
Old 05-10-2022, 01:24 PM   #13
KillerBMotorsport
There are a couple of good apps out that do a really good job. They will only calculate speed when they have good signal from many satellites. One I came across would even give %error, depending on the number or satellites licked on, but it was laughably low.
I would see a pretty decent change from summer to snows, even though they were the same size. I would imagine you'd get a couple-few MPH off with brand new tires vs bald ones. The math says they'd read different.
In most of the Subies I've owned, doing what you think is 80, is really 75-78. So scaling that up, it made perfect sense why my speedo was indicating 160mph, but the timing gate showed 150mph.
Old 05-10-2022, 01:29 PM   #14
...In most of the Subies I've owned, doing what you think is 80, is really 75-78. So scaling that up, it made perfect sense why my speedo was indicating 160mph, but the timing gate showed 150mph.
I realize now we are both saying the same thing (speedometer is typical lower than actual speed), somehow I managed to read your statement backwards....
Dzmitry (05-10-2022)
2022 Subaru BRZ on the Dyno thekevinvo BRZ Second-Gen (2022+) — General Topics 41 02-08-2022 05:54 PM
2022 Subaru BRZ brochure timurrrr BRZ Second-Gen (2022+) — General Topics 4 11-01-2021 12:04 AM
2022 Configurator up on Subaru.com trippinbillies40 BRZ Second-Gen (2022+) — General Topics 54 09-24-2021 09:09 PM
BRZ traveling 140mph along N Fwy Houston before crashing KDad2 Southwest 38 01-17-2018 04:47 PM
Clicking From Rear - Changes with Road Speed Grimlock Issues | Warranty | Recalls / TSB 18 07-29-2016 04:30 PM
