| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: 2022 BRZ coming
Dealer service to maintain warranty?
Hi all! I'm reaching 1000 miles, so want to get an oil change done. (By the way, I love my BRZ!). Is it required for oil changes to be done at the dealer to maintain the factory warranty, or can I go to my trusted local mechanic? Would appreciate if anybody could point me to where this info is written down specifically (either confirming or denying) for some piece of mind. Thanks! This forum is great!
#2 |
Drives: '22 BRZ
Not at all necessary. You can change it yourself and retain the factory warranty - it was purchased with the car.
| The Following User Says Thank You to Panda Grahams For This Useful Post: | Grosbard (04-27-2022) |
#3 | |
Drives: '23 BRZ Limited
If so, I'd take advantage of that since you're just trying to get any break-in materials in the oil out. Then at 4-5k get an oil change with the oil and mechanic you prefer. |
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Grosbard (04-27-2022) |
#4 |
Drives: 2022 BRZ Limited WR Blue MT
Def check the dealership included service out. My dealer has the first 4 scheduled services free. But its 150 mile round trip for me also no weekend appointments. Only Mon-Fri. No way i'm using 1/2 a Vac day for an oil change.
| The Following 2 Users Say Thank You to H380 For This Useful Post: | Grosbard (04-27-2022), soundman98 (04-26-2022) |
#5 | |
Drives: 22 brz
Also, I asked if my local dealer would change the transmission fluid to Motul 300v (after suggestions on here) along with my break in oil change. They said they wouldnt do it as it would void my powertrain warranty. I dont have the ability to do it myself since I moved into an apartment. Any thoughts on this? I originally tried another big chain lube place and they said they didnt have any instructions/diagrams for the 2022 model yet for transmission fluid so they also wouldnt do the service. |
#6 | |
ProCrastinationConsultant
now, this should only void your transmission warranty, and if you have valve cover issues, they should still be covered under the magnuson moss act, as the alterations were to the transmission, which would not effect motor leaking issues, but YMMV applies. this guy tried taking that act further than anyone i've ever heard of, and would've lost a ton of money in legal fees had he kept going: https://www.tacomaworld.com/threads/...ss-act.609911/ you can mod your car, or you can maintain your warranty in full. but you can't ever get both
| The Following User Says Thank You to soundman98 For This Useful Post: | Tcoat (04-29-2022) |
#7 | |
IE, use a 0w-20 Synthetic, that meets API SERVICE SN PLUS or ILSAC GF-5 standard. Pages 381-383 of the 2022 BRZ Owners Manual. https://ownersman.com/manuals/2022-S...-owners-manual
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#8 | |
#9 |
I linked the manual and gave the relevant pages.....
It essentially says the same thing, "Use oils that meet these standards." For manual transmission: Manual Transmission Gear Oil LV 75W*3 API GL-4 SAE 75W*4 For rear differential: Differential Gear Oil LX*3 Other gear oil that meets API GL-5 SAE 75W-85 or GL-5 SAE 75W-90 specifications*5
#10 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (04-29-2022) |
#11 | |
That if the manual calls for synthetic 0w-20 GL-5 oil, that putting in straight 50 weight GF-4 would not meet the standard. I should know better based on what I see in the Facebook groups.
| The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post: | soundman98 (04-29-2022), Tcoat (04-29-2022) |
| BRZ Service under warranty. DYI or Dealership? | BDKane01 | BRZ First-Gen (2012+) — General Topics | 16 | 07-05-2016 02:59 PM |
| First warranty service maintenance | vinh359 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 07-09-2014 01:54 PM |
| Good dealer to go for service/warranty in GTA? | shu5892001 | CANADA | 8 | 04-18-2013 06:04 AM |
| Maintenance or Service Warranty? or Both? | JohnAyySays | Issues | Warranty | Recalls / TSB | 24 | 03-27-2013 02:04 PM |
| asked dealer service manager about aftermarket/warranty | NuckinFutsFR-S | Issues | Warranty | Recalls / TSB | 23 | 10-31-2012 08:24 AM |
