Old 04-18-2022, 11:55 AM   #295
Originally Posted by Yoshoobaroo View Post
Am I having a stroke?
I noticed the same thing, but decided to read between the lines, since I thought it was pretty clear what he meant.
Old 04-18-2022, 01:27 PM   #296
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Smile
I'm still dealing with head injuries from wrecking in our GT7 races last weekend
I meant if you're smart enough to use snow tires (which you should somewhere with four seasons), then AWD is still a better solution.
The Following 2 Users Say Thank You to WolfpackS2k For This Useful Post:
Kaotic Lazagna (04-18-2022), Yoshoobaroo (04-18-2022)
Old 04-18-2022, 09:28 PM   #297
soundman98
ProCrastinationConsultant
soundman98's Avatar
4wd allows me to stop better.
Old 04-19-2022, 02:42 AM   #298
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
lol
Old 04-19-2022, 11:55 AM   #299
Dake
Dake's Avatar
Probably won't even be able to see the brake pads on this, so I'm out.
Dake is offline   Reply With Quote
The Following 6 Users Say Thank You to Dake For This Useful Post:
Dadhawk (04-19-2022), Sasquachulator (04-19-2022), soundman98 (04-19-2022), spike021 (04-19-2022), weederr33 (04-19-2022), Yoshoobaroo (04-19-2022)
Old 04-19-2022, 01:31 PM   #300
Sasquachulator
Pavement Grey
I think it uses the deal breaking BMW style turn "goes back to neutral position" signals too.....
Plus i think it only does 0-60 in around 5 seconds? Dead on Arrival......
One step forward...several steps back....
cmon toyota, do better!
The Following 3 Users Say Thank You to Sasquachulator For This Useful Post:
spike021 (04-19-2022), Tcoat (04-19-2022), WolfpackS2k (04-19-2022)
Old 04-19-2022, 11:20 PM   #301
soundman98
soundman98's Avatar
lol
i was serious.
Captain Snooze (04-20-2022)
Old 04-20-2022, 01:54 AM   #302
Captain Snooze
Drives: Red Herring
i was serious.
oh.
I had better watch the videos.
soundman98 (04-21-2022)
Old 04-20-2022, 02:08 AM   #303
Captain Snooze
Drives: Red Herring
i was serious.
I watched the first 2 videos. The explanation in the 2nd video made sense.
I am not going to post in the TIL thread even though I did.
Old 04-20-2022, 08:32 AM   #304
On the first one, I question the validity of test 1 and 2. He locks up all four wheels in both tests, so not sure what advantage 4WD would give you there.
Ultimately I would expect 4WD to be an advantage over 2WD, either front or rear. That just means the limits are different and you have to drive differently to be safe. I would never drive a 2WD vehicle at the same speed, distance, etc as I would a 4WD in those conditions.
That doesn't mean I couldn't drive them both safely.
Old 04-20-2022, 05:10 PM   #305
mn_ca
Drives: 2013 frs, 2005 is300
Driven FWD beaters for the last 20 years in our beautiful MN winters. Yet to have any issues. I do have my Taco but I don't use it. The only time I use it is when I'm hauling stuff to the compost site I just don't find any interest in 4WD or AWD, though my wife does drive an AWD SUV. But then, it's the wife
mn_ca is offline   Reply With Quote
Old 04-21-2022, 11:52 AM   #306
Sasquachulator
Pavement Grey
Ive driven mostly FWD in winter, its all about the tires.
Anywhere i would have gotten stuck, ANY car would have gotten stuck.
AWD is the easiest and most reliable because you got 4 wheels of traction to rely on.
They're usually equipped on cars with high ground clearances, which also helps.
So far RWD has been the most tricky out of all 3, and i think it has alot to do with less weight being on the rear wheels (since most FWD cars are like 70/30 or so F-R weight distribution). I can definately feel the rear tires dont have as much traction as its theres not as much weight back there and it can kick out sideways pretty easily during acceleration. (all about throttle control)
But i do notice people dont really know how to drive in winter here......
-People don't seem to understand the concept of "rocking" the car when you are stuck. Instead they just gun the gas pedal, spinning the wheels at like 5000rpm, dont go anywhere and actually make things worse.
Instead you should be pressing the throttle and feel the car inch forward (or backwards) until the tire hits the bank of snow it cant clear, then release the gas and let it roll back till the tire hits the other end and as it rolls forward again you give it some gas...rinse repeat. If you are successful the car starts inching ever more forward and eventually you can just power over the little rut.
obviously you might have to remove some snow around the drive wheels but theres a chance you can get out of it once the car is moving....and in deep snow momentum is everything...once you are moving you can just plow through the snow as long as you can keep moving (cuz if you stop or if the snow was just too deep to begin with, you'll just get stuck again down the road lol)
The Following User Says Thank You to Sasquachulator For This Useful Post:
Dadhawk (04-21-2022)
Old 04-21-2022, 04:03 PM   #307
I laugh and laugh at people that are stuck in deep or heavy snow (doesn't have to be deep) that franticly dig out the drive wheels and leave the idler wheels packed in snow. It is like trying to get a car moving with chocks under two wheels. You need to clear snow from ALL wheels.
Dadhawk (04-21-2022), soundman98 (04-21-2022)
Old 04-21-2022, 05:45 PM   #308
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
It's even funnier when the person is frantically digging out the non-drive wheels, while leaving the drive wheels alone. Remember that video of a porch pirate who got their Yaris stuck in a snowbank? And then proceeded to dig out the rear wheels only?
(Note: the Yaris was not a GR Yaris)
daiheadjai is offline   Reply With Quote
The Following User Says Thank You to daiheadjai For This Useful Post:
World Premiere of All-New Toyota GR 86 (Europe) gymratter GR86 General Topics (2nd Gen 2022+ Toyota 86) 104 09-19-2022 08:33 PM
2019 Toyota Corolla Hatchback & Sedan spike021 Other Vehicles & General Automotive Discussions 399 03-28-2022 10:32 AM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-13-2022 12:44 AM
The new Volkswagen ID.4 – World premiere of the fully electrically driven SUV vh_supra26 Other Vehicles & General Automotive Discussions 5 09-27-2020 03:40 AM
STI NBR CHALLENGE 2014 World Premiere Movie JPxM0Dz Other Vehicles & General Automotive Discussions 0 02-03-2014 06:04 PM
