| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: '22 BRZ 6MT MGM
Has anyone tried swapping out their head unit yet?
I'm currently looking to replace the head unit with a Pioneer DMH-WT8600NEX but I haven't been able to find any info on head unit swaps for the car yet. I see in Japan that they do run custom head units but asking people there hasn't yielded much info likely due to the fact that they didn't install it themselves (the people I asked said they did retain steering wheel controls though).
Anyone here try to do the swap themselves? |
| The Following User Says Thank You to shoreline86 For This Useful Post: | humfrz (04-09-2022) |
#2 | |
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
#3 |
Drives: 06 Ridgeline, 03 VFR, 03 FLHTPi,
#4 | ||
ProCrastinationConsultant
^he's talking his RV in the first part.
there was a minor alteration with the brz limited/premium where the limited gets the same speakers as the pervious gen limited, but the premium drops the dash midrange speakers. but still have a door 'sub' amp, still tweeters in the dash, and still 3" speakers in the rear seats. Quote:
#5 |
2022 BRZ and a 2019 Ascent, both have Apple Car Play and Android Auto. It is the kludgy head unit in my RV that is functionally challenged and was the reason I went to the car audio shop in the first place. The Ascent has built-in Tom Tom navigation which is just so-so. I use Waze, Google Maps or Apple Maps connected to my iPhone. Mostly I use Waze (Police reported ahead or dead animal on the road). My Ascent will drive over most road-kill, but the BRZ has to dodge the blood and guts. Back to the Pioneer head units; that is my first choice for aftermarket gear. Back in the day before satellite or internet channels, the Pioneer radios were the best at pulling in both FM and AM radio when I was cruising somewhere USA.
| The Following User Says Thank You to Flarpswitch For This Useful Post: | soundman98 (04-05-2022) |
#6 | ||
But the Japanese owner I talked to said steering wheel controls work with his aftermarket head unit. And if the car is the same maybe Maestro RR2 support could at least be mostly complete? My only thing is where are people finding these parts, I don't want to take everything apart only to realize I need some module for the steering wheel. And also perhaps the biggest thing is I don't know what the deal with housing an aftermarket unit would be. There were dash kits from gen one, and people are doing it with gen 2 but I don't know the part number for it. Also I don't know if it would accommodate a floating display without having a huge gap in the back. Replacing the head unit would only basically eliminate the app for Starlink/MySubaru but would not get rid of the Starlink functionality. You'd just miss things like maintenance alerts etc which is no big deal. Also, it seems like every vehicle-related setting in the stock head unit can be altered in the gauge cluster display anyway so again no loss there. |
#7 |
really shouldn't 'absolutely need' a sub unless you really want the seats shaking. a plenty-decent sound system can be put together without a sub...[/QUOTE]
Right. He caught me looking at an Earth shaking sub and he knew that the spare tire was deleted for 2022. "Here's what you do: cut a hole in the floor. We have a grill that will fit real nice. Drop the back seat down and show time." I told him that I would have to think about that mod. |
#8 |
Okay, so I found some videos showing head unit replacements. I could possibly do this, the only issue remaining is the gap with a single DIN head unit.
| The Following 2 Users Say Thank You to shoreline86 For This Useful Post: | Flarpswitch (04-06-2022), joemysterio (04-05-2022) |
#9 |
Drives: Mini
I want to add a sub to mine but not sure how yet, going to figure this out so I can do the work myself. So, thanks for those vids, looks really easy to access the head unit. I was afraid it would require a lot more work.
#10 | |
i suspect you should be able to locate another toyota/subaru model that would at least fit to fill the gaps right, might even bolt up right. and major +1 to wanting to run a 1-din! if you've got the limited/8 speaker system, the amp in the trunk has high level full range inputs. can easily tap into that within the trunk for the signal.
| The Following User Says Thank You to soundman98 For This Useful Post: | joemysterio (04-06-2022) |
#11 | |
I don't think finding something from another model would work though. Subaru's own cars and Toyota's own cars are wildly different in the head unit area vs. the BRZ. But dash kits are also cheap enough that I could do it in an improvised way first and then do it the proper way once an updated kit is released. I do have a question about the iDatalink Maestro RR2 though for anyone who knows -- do they get software updates to be compatible with new cars or are they actually revised hardware-wise? |
#12 |
Drives: X5 35d, D90, CX-5 Turbo
This may or may not be relevant for you..
Dont replace your GR86 premuim\BRZ Limited Headunit until you read this..... |
#13 | |
| The Following 2 Users Say Thank You to shoreline86 For This Useful Post: | Flarpswitch (04-06-2022), soundman98 (04-06-2022) |
#14 |
I am not sure I understand how the amplifier(s) and speakers are set up. Looking at the diagram does not clear things up for me. My Subaru Ascent has 8 speakers and a big Harmon Kardon amp under the front passenger seat. I assume all the heavy lifting is done by that amp. Whether it is driven by power amps in the head unit or line level signals, I don't have a clue. Same with my previous 2017 BRZ which had 6 speakers and an amp in the trunk area. I assume that the 2022 is set up in a similar fashion. Does the head unit have a power amp capable of driving speakers on its own? Are all 6 speakers in the BRZ connected to the external amp in the trunk area?
| FS: 2014 FRS Bespoke Head Unit w/ Navigation & GPS antenna / 2014 FRS Base Head Unit | vitriumGTS | Audio/Visual, Electronics, Infotainment, NAV | 0 | 07-16-2019 02:02 PM |
| For Sale: Stock BeSpoke Premium Audio head unit with NAV unit | Glok24 | Audio/Visual, Electronics, Infotainment, NAV | 13 | 07-22-2018 12:34 AM |
| FS OEM head unit | Lorico | Canada Classifieds | 2 | 02-28-2015 12:53 PM |
| Anybody know ... what head unit this is? | chaoskaze | Electronics | Audio | NAV | Infotainment | 3 | 12-21-2014 06:44 PM |
| swapping to JDM head lights for BRZ, sacrilege? | BRZPDX | BRZ First-Gen (2012+) — General Topics | 19 | 08-06-2013 03:48 PM |
