#29 |
Drives: best
The correct solution to this situation is to replace the fuse. When you install a fuse designed for a lower voltage, the machine refuses to use it and does not close the circuit. Try buying a fuse set and installing the same fuse or one rated for a higher voltage. Usually, this procedure has helped me with a lot of breakdowns. As for the living room light, I can advise you similar bulbs https://www.vont.com/product/vont-bu...s-smart-bulbs/. I recently bought one of these, and I'm still thrilled. I could not have imagined that it would be convenient to control the lights with my phone.
| The Following User Says Thank You to cfedsasd For This Useful Post: | soundman98 (03-24-2022) |
| 2013 BRZ Reverse Light (Reverse & Reflector) | kberkel | Exterior Parts (Aero, Lighting, Etc.) | 0 | 08-14-2016 02:14 AM |
| FS: OEM Fog Light Bezel, OEM Turn Signal Housings, and OEM Reverse Light Assembly | zeal86 | Exterior Parts (Aero, Lighting, Etc.) | 15 | 05-29-2016 11:01 PM |
| Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) | ZetaPerformance | Exterior Parts - Lighting | 172 | 11-13-2015 11:25 AM |
| For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! | Vicious LED | Exterior Parts (Aero, Lighting, Etc.) | 9 | 08-25-2013 08:26 PM |
