Old 03-11-2022, 11:00 PM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Throttle body problems
Ive been getting a p2135 tb sensor code which causes me to go in limp mode while driving. Also noticed rpms drops really low when coming to a stop and its died on me once before. I clean the throttle body which is always visually clean. Before i order a new throttle body could it be something else?
IsaiahW is offline   Reply With Quote
Old 03-11-2022, 11:19 PM   #2
Ashikabi
Ashikabi's Avatar
Throttle pedal position sensor would indicate that it's the pedal not the throttle body
Sent from my ONEPLUS A5010 using Tapatalk
Old 03-17-2022, 02:14 PM   #3
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
That code indicates that it's either. Could be the TB or the pedal position sensor. Make sure throttle body sensor connections are sound. Same thing with the pedal position sensor. You could do a voltage check as well to see that both sensors are working properly.
Dzmitry is offline   Reply With Quote
OEM throttle body nikitopo Engine, Exhaust, Bolt-Ons 10 01-07-2024 12:50 PM
throttle body vin08 Southern California 16 06-27-2017 06:01 PM
WTB FRS/BRZ Throttle Body Tboxer Want-To-Buy Requests 3 12-01-2014 01:13 PM
