| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#15 | |
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
However, the differences between the standard BRZ (with & without the Performance Package) and the tS are still apparent (steering feel, turn-in, and confidence from grip). Most of those online/YouTube journalists pretty much say the same thing I did. If you’re familiar with theTopher he even drove a tS against his modified BRZ (13 or 14 I forgot) and consistently got 1 second faster lap times on the track he drove on with the tS.
SPECIAL EDITION VIN LISTS: |
| The Following 3 Users Say Thank You to Veloist For This Useful Post: |
#16 |
Drives: Too fast
That is obviously a tire difference, because you do not get 1 second from braces, a spoiler and so little spring rate differences. If you get this much from so little, do not get camber bolts, 200tw tires and coilovers...you won't sleep for a week.
I read this topic like the tS is a Honda Type R equivalent, while it is not at all. Most competitive classes do not even account for the tS mods...because they barely have any effect. |
| The Following User Says Thank You to dsc_pat For This Useful Post: | Robertw (03-15-2022) |
#17 | |
This was the mod list of theTopher’s BRZ vs the stock BRZ tS: 2014 Subaru BRZ Mod List (in this video): 225/45/17 Falken Azenis RT-615k Tires Corsa Performance Catback Exhaust* 2017+ Subaru BRZ Front & Rear Spring/Shock assembly 2017+ Toyota 86 Rear Stabilizer Bar: # SU003-06461 2017+ Toyota 86 Rear Stabilizer Bar Bushings: # SU003-06462 2017+ Subaru BRZ Limited Rear Differential 4.3 Ratio #4111018030 FT86 Speedfactory Catted UEL Header OpenFlash Tablet FT86 SF Header Tune (Stg 2 91 v3.0) Corsa Powercore® Closed Box Air Intake PN 185206 17x7.5 SSR GT2 Wheels Cosworth StreetMaster R90 Fast Road Brake Pads (Front/Rear) DBA 4000 Front Rotors StopTech STR-600 Brake Fluid Whiteline Front Camber Bolts (set to -1º) Clutch pedal helper spring removed for improved weight/feel Engine oil: 0w20 Eneos Sustina Differential fluid: Motul Gear 300 Transmission fluid: Redline MT-90 2018 Subaru BRZ tS: MSRP: From $33,495 Horsepower: 205 hp Engine: 2.0 L 4-cylinder Wheel size: 18″ diameter, 7.5″ width Curb weight: 2,798 lbs MPG: 21 city / 29 highway Torque: 156 lb-ft
SPECIAL EDITION VIN LISTS: Last edited by Veloist; 03-14-2022 at 07:16 PM. Reason: Removed links |
#18 |
Drives: 2017 Subaru BRZ
Just wanted to say huge thanks for this post
Absolutely incredible read |
#19 |
Drives: '20 Tundra, '84 SpecE30
What a fantastic write up! Every time someone like you posts such beautiful pics of California, it makes me want to put my head in the sand and forget gas prices are a thing and move there!
#20 |
Great write up. These cars are real close so no point fighting about what’s better, it’s very subjective. I do wonder how much time I could save on my 1 hr highway commute driving mostly straight lines, if I had gotten the TS. Get the TS because it was limited and you like it.
| GR86 Premium MPG | joeDoe | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 40 | 01-31-2022 02:03 PM |
| GR86/BRZ Comparison Articles | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 74 | 01-02-2022 09:39 AM |
| GR86 vs. GT86 track comparison | nikitopo | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 5 | 12-30-2021 07:48 PM |
| GR86/BRZ Track Comparison (Japanese) | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 95 | 12-24-2021 07:36 PM |
| Car & Driver Comparison Test Review: Veloster N vs. GTI vs. BRZ vs. GR86 | LimitedSlip | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 158 | 12-12-2021 05:04 PM |
