Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-09-2022, 10:42 PM   #85
ATreiDes
Drives: 2022 BRZ - Limited - Sapphire Blue
Originally Posted by Robotaz View Post
The vibrating metallic sound. To me it’s like a slight howl and not at all “road noise” you get with rubber on asphalt.
I have a GR86 I’m struggling with. I bought it Friday and switched the Michelin Pilot Sport 4 tires to the Michelin Pilot Sport A/S hoping for a difference yesterday and nothing.
I’m getting a strange resonating howling sound I’ve never heard before. People are saying it’s tires, but I’m convinced it is resonating noise traveling through various metal components and concentrating in random areas where the frequencies are super positioning. My next step is to have a dealer confirm other cars do it and start sound deadening. I seriously doubt the whole car needs it. I’m starting with the easiest areas to hit in the front area and going from there. My noise seems to come from the front driver area. I’m starting there. Absorbing noise in some random metallic surfaces may just stop it. We shall see.
Sounds like I have finally found someone that is hearing the same thing I am. You are the first to describe it like I hear it. Switching to the DWS 06's is my last resort. If that does not fix it, then to me, it is an inherent flaw to the car that I will not be able to deal with and will have to sell the car. Such a shame too, as everything else is perfect about it. The normal road noise does not bug me in the least bit, just that damn metallic howling sound because it is so unnatural.
ATreiDes is offline   Reply With Quote
The Following User Says Thank You to ATreiDes For This Useful Post:
Robotaz (03-09-2022)
Old 03-09-2022, 10:45 PM   #86
ATreiDes
Originally Posted by Flarpswitch View Post
All this talk about noise, but are all these observations made with the 'fake engine sound' functional or with it either turned off or unplugged? There is no real-time driver control for on/off or volume level. You are held hostage to whatever sound it makes. What if the sound creator module goes haywire? What about the droning sound that gets blamed on tires and other sources? Could the sound from the sound creator combine with other vehicle sounds? The effect could be magnified sound when certain frequencies are in synch and diminished when out of phase. The most annoying sounds will occur when the frequency of two or more sources are off by just a few Hz and create beat frequencies. I once had a phantom noise that was created by exhaust system heat shielding that had become detached in some places and there were loose connections between two joined sections. The damned thing would not rattle, but they had a tuning fork sort of effect picking up vibrations from the not-so-perfect balance of the multi-section drive shaft. Replacing all the pop rivets and bending the sheet metal back in shape (deformed by running over a raccoon). The ghosts disappeared after repairs. The point is that some noise may be originating in places you might not think of.
Nope, turned mine off by unplugging it right after I got the car. I only wished that were the issue...
Old 03-09-2022, 11:06 PM   #87
Robotaz
Drives: 2022 GR86 Premium
Current and Previous gen owners - how bad is the road noise?
If you look at the TRD Japan GR86 accessories page, there are dampers that replace the strut braces in the engine bay. The description says it reduces noise. I wonder if the braces are directly transmitting resonant noise from the strut towers, and whether these dampers address a known issue.
https://www.trdparts.jp/english/prod...unctional.html
Robotaz is offline   Reply With Quote
Old 03-10-2022, 12:28 AM   #88
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Going to assume these are just TRD's version of the STI part?
https://subimods.com/products/subaru...gn=sag_organic
https://www.ft86club.com/forums/showthread.php?t=22441
LRNAD90 is offline   Reply With Quote
Old 03-10-2022, 06:17 AM   #89
autosenses
autosenses's Avatar
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
I did deactivate the piped in sound and it has nothing to do with what I’m hearing. It’s a metallic whirring sound like you might hear in a factory, and I think I’ve figured out enough to stop it, but we shall see.
I'm curious to see what you think. Sound and vibration are subjective and tolerance is different with everyone. My STI had this metal/tinny sound your describing. I put sound deadening in rear trunk, especially in the rear quarter panels and around the spare tire area. That helped ALOT.
I will not be putting sound deadening in my GR. But I'm curious about the road noise..I have a 1hour 20min drive to 2 Tracks from me.
autosenses is offline   Reply With Quote
The Following User Says Thank You to autosenses For This Useful Post:
Robotaz (03-10-2022)
Old 03-13-2022, 11:00 AM   #90
ATreiDes
Considering that most of the noise happens when I can feel vibration coming through the steering wheel and pedals, as well as when going over minor cracks / bumps in the road and gravel, this could be a distinct possibility. I wish there was a way of testing it first without forking over the cash to see if it works.
Thanks for pointing those out!
Old 03-14-2022, 02:06 PM   #91
dsc_pat
Drives: Too fast
Well just removing the OE bars is a 0$, 5min test you can do. Your wish is my command.
dsc_pat is offline   Reply With Quote
The Following User Says Thank You to dsc_pat For This Useful Post:
Flarpswitch (03-20-2022)
Old 03-14-2022, 03:41 PM   #92
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Or you can get the Subaru flexible v-bars for an '18 tS for way less than importing them. Not sure if it will change the noise though. I think you're too far from me to locally test.
Old 03-14-2022, 06:49 PM   #93
drift86
Drives: GT86, 22 BRZ
I noticed a blow off valve style pshhhh sound if I accelerate hard and lift off sharply at just over 5000rpm (I'm still running it in, so haven't reved higher yet).
Anyone else notice that? Pretty strange sound for a NA car!
drift86 is offline   Reply With Quote
Old 03-14-2022, 06:58 PM   #94
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yea the old one did that too, high speed air whistling past the suddenly almost-shut TB maybe?
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
soundman98 (03-19-2022)
Old 03-19-2022, 03:48 AM   #95
joemysterio
Drives: Mini
So I've been driving a bit more the last few days. Road noise is totally fine on the streets but ridiculously loud on the highway, even with music playing. Oh well, I knew what I was getting into. Still fun as hell driving the BRZ!
joemysterio is offline   Reply With Quote
Old 03-21-2022, 02:21 PM   #96
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Originally Posted by LRNAD90 View Post
Not at all. The GR part is a damper whereas the STI part is not.
Interceptor777 is offline   Reply With Quote
Old 03-21-2022, 02:33 PM   #97
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
Yeah threw me a bit the first time I heard that noise.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Old 03-21-2022, 10:33 PM   #98
Robotaz
I can hear the noise driving on gravel at 2 mph. I was backing out of a parking spot on compressed gravel and heard it. I seriously don’t know what it is, but it’s weird.
Some Questions Regarding the FR-S's White Tachometer for Current and Previous Owners WannabeBRZ Scion FR-S / Toyota 86 GT86 General Forum 11 12-21-2020 10:00 PM
Any previous Scion tC owners? Pros & cons vs. the tC? LALFAN Scion FR-S / Toyota 86 GT86 General Forum 98 03-02-2016 12:28 PM
Any previous Miata owners out there? x96nax Tracking / Autocross / HPDE / Drifting 26 07-27-2013 08:29 AM
Any previous/current owners of AE86? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 61 06-28-2013 06:45 PM
Question about financing for current BRZ owners ayau BRZ First-Gen (2012+) — General Topics 46 07-07-2012 02:19 AM
