Old 03-08-2022, 02:09 PM   #1
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
AC just quit blowing cold all of the sudden
And the compressor doesn't appear to be coming on when I turn the AC on.
Troubleshooting tips?
Worst about all of this is my 2022 C8 Vette was supposed to be here by now. So I've either got to fix this and sell it on my own or take the loss in the form of trading it in. FML
Old 03-08-2022, 03:46 PM   #2
p1l0t
p1l0t's Avatar
Does the light come on? I mean it sounds like you are going to have to do some multi-meter testing. You checked the fuses already I assume?
Old 03-08-2022, 03:53 PM   #3
echo419
echo419's Avatar
Yes, light comes on and I have checked the fuses.
Old 03-08-2022, 04:09 PM   #4
p1l0t
p1l0t's Avatar
Replacing the compressor is only $200-300 but I would check for loose wiring first. I think there is only one wire (maybe two) that run to the compressor. Make sure you are getting 12v to it when the switch is on. That should engage the magnetic clutch.
echo419 (03-08-2022)
Old 03-08-2022, 04:31 PM   #5
pope
has a funny hat
if the refrigerant pressure is too low the system won't engage.
pope is offline   Reply With Quote
The Following 2 Users Say Thank You to pope For This Useful Post:
echo419 (03-08-2022), p1l0t (03-08-2022)
Old 03-08-2022, 06:04 PM   #6
echo419
echo419's Avatar
I'll check this stuff out tomorrow. Thanks!
The Following User Says Thank You to echo419 For This Useful Post:
p1l0t (03-08-2022)
Old 03-08-2022, 06:16 PM   #7
There is also a secret cheat code to switch it to a diagnostic mode. Look in the service manual for the dual climate control. It's buried in there. Will check back later tonight when I get home.
Old 03-08-2022, 07:07 PM   #8
echo419
echo419's Avatar
That would be awesome!
p1l0t (03-08-2022)
Old 03-08-2022, 10:22 PM   #9
Grady
Grady's Avatar
First thing to do is put gauges on it and check pressures. For it to not come on at all it would have to be less than around 5psi on the low side. 2nd you could check to see if you are getting voltage to the clutch/clutch resistance. Once you know those items you will know what part of the system to troubleshoot further.
The Following 2 Users Say Thank You to Grady For This Useful Post:
echo419 (03-08-2022), Ultramaroon (03-08-2022)
Old 03-08-2022, 10:22 PM   #10
Alright. Look for the manuals link in my sig. Here's a screenshot of the menu drilled down to the important pages. You'll see what I mean pretty quickly.
Grady's on point. That really is the essential first step.
The Following 6 Users Say Thank You to Ultramaroon For This Useful Post:
Boomerang (03-10-2022), echo419 (03-08-2022), Grady (03-09-2022), humfrz (03-09-2022), p1l0t (03-08-2022), x808drifter (03-09-2022)
Old 03-09-2022, 01:55 AM   #11
YIKES! After looking at that post, I'd suggest the humfrz method - take the car into a shop and have them fix the AC.
Old 03-09-2022, 03:22 AM   #12
Don't lie. You already had your mind made up before even reading the thread title.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
echo419 (03-09-2022), humfrz (03-09-2022), p1l0t (03-09-2022), soundman98 (03-09-2022), x808drifter (03-09-2022)
Old 03-09-2022, 03:40 AM   #13
Boomerang
86
Boomerang's Avatar
This happened to me once when the car went in to limp mode due to disconnecting the OFT during operation. Cleared the fault code and AC returned. Maybe check for fault codes?
The Following 3 Users Say Thank You to Boomerang For This Useful Post:
echo419 (03-09-2022), p1l0t (03-09-2022), Ultramaroon (03-09-2022)
Old 03-09-2022, 01:07 PM   #14
Pretty much so. For me, AC stuff is NOT a DIY thing. Not much anymore is a DIY thing -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
p1l0t (03-09-2022), soundman98 (03-09-2022), Ultramaroon (03-09-2022)
AC not blowing any cold air highway7 Issues | Warranty | Recalls / TSB 33 12-10-2021 10:58 PM
Aircon blowing cold on one side Kris86 Issues | Warranty | Recalls / TSB 9 05-12-2020 01:36 PM
Sudden lean 17AFR, but then sudden rich 10AFR??? No codes D-VO Software Tuning 4 12-11-2019 01:17 AM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 04:29 PM
Quit old job looking for new one ric342 Southern California 4 08-05-2013 04:36 AM
