#43 | |
Drives: Crapcan
I really dislike K&N’s for anything other then something used strictly for sand
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (02-28-2022) |
#44 |
I guess they're ok if the goal isn't to maximize engine life.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (02-28-2022) |
#45 |
Drives: Crapcan
I have seen a number of desert bikes not survive a weekend with them. Silt and ash just passes through them.
#46 | |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | jcw99 (03-04-2022), Ultramaroon (02-28-2022) |
#47 |
I wasted too much time yesterday looking in vain for a pic of a tiny air cleaner over a v8.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | humfrz (03-01-2022), soundman98 (03-01-2022) |
#48 |
ProCrastinationConsultant
Fab rats on YouTube just picked up a rat rod truck with one.
| The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (03-01-2022) |
#49 |
| The Following User Says Thank You to humfrz For This Useful Post: | soundman98 (03-01-2022) |
#50 | |
Drives: 2013 Scion FRS
So do I just change the scaling in rom raider or do i change the primary open loop fueling chart based off the afr average chart it gives me? And whats the afr cell hit count chart for? Sent from my iPhone using Tapatalk |
#51 |
Drives: Crapcan
You log for and change closed loop first.
#52 |
Something seriously wrong?
Yeah i logged for open and closed loop and made the changes to scaling. So now i change POL or after logging some more driving? And so for Stock afr do i put in afr or commanded afr? Sent from my iPhone using Tapatalk Last edited by Christian628; 03-03-2022 at 04:46 PM. |
#53 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (03-04-2022), Ultramaroon (03-04-2022) |
#54 |
Drives: Crapcan
No need to mess with those things when maf scaling. When you change the maf scale and reflash you need to put some miles on it again to let the ecu relearn fuel trims. You need to do that every time you reflash. Unless you see something bad in the logs like low IAM, crazy fuel trims, ect. Once I reflash I usually log the car once to make sure nothing bad is going on and then I don't bother logging again till I get some miles on it.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (03-04-2022) |
#55 |
^^^ this
Sorry about derailing your thread, OP. No is on point. One step/change at a time and observe carefully.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (03-04-2022) |
#56 |
I think i have tracked my idle issues down to the ac being on… idk. Only notice the problems and crazy afr when my ac is on. Thoughts?
| Something is wrong S/C | Smaay | Forced Induction | 25 | 01-09-2020 11:52 PM |
| E85 gone wrong | MGPAX | Software Tuning | 34 | 03-17-2016 11:53 PM |
| What did I do wrong? | Hags86 | Tracking / Autocross / HPDE / Drifting | 8 | 02-25-2015 02:36 PM |
| HELP! WRONG GAS IN CAR | nabil_frs | Issues | Warranty | Recalls / TSB | 85 | 04-01-2014 02:44 AM |
| What's wrong with this car? | Suberman | CANADA | 41 | 01-14-2014 01:35 PM |
