Old 02-13-2022, 12:09 PM   #1
jamestemperante
Drives: Subaru BRZ
RPM drops when coming to a stop
hello guys. just want to ask, my BRZ rpm drops when AC compressor turns on while coming to a stop making the car shake. I think it drops around 580 to 550rpm. It doesn't do that if the car is on stand still. It doesn't always happen, but getting a bit irritated. haha. Is this normal? thanks again
jamestemperante is offline   Reply With Quote
Old 02-13-2022, 12:13 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
normal
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
EAGLE5 (02-13-2022), humfrz (02-14-2022), jamestemperante (02-14-2022), zc06_kisstherain (02-21-2022)
Old 02-21-2022, 07:12 PM   #3
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
yup. normal. give a gas little in neutral if you hate it
Old 02-28-2022, 10:15 PM   #4
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
it shouldn't, actually. The ECU should compensate for idle going below and above certain rpm. AC turning on, etc will make the idle lower, but the PCM should raise it. Usually with timing adjustments, or throttle adjustments. Back in the day, they used idle air control devices, but I don't think that ours has one of those being that it has drive by wire electronic throttle.
Id say to clean the throttle body really well, and check for air leaks/rips in the intake pipe.
I'd also look at my fuel trims at idle. If its overly lean or overly rich, that would be a clue
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 03-01-2022, 12:17 AM   #5
soundman98
soundman98's Avatar
But it will dip for a second before the ecu can create a compensation
Old 03-01-2022, 01:50 AM   #6
tomm.brz
Drives: brz 2017 hksv2
stock tune tends to do like that, a retune would fix it (unless the tuner keep idle settings as stock as many do lol)
idle dropping when coming to a stop jamestemperante Issues | Warranty | Recalls / TSB 5 12-04-2021 12:56 AM
Oil light blinks for 1-2 seconds when coming to a stop/complete stop kev0 Engine, Exhaust, Transmission 27 07-10-2019 12:30 AM
car bogging when coming to stop Qball1754 Engine, Exhaust, Transmission 10 06-06-2019 12:39 PM
beeping when coming to a stop Skin Issues | Warranty | Recalls / TSB 8 07-24-2017 11:06 AM
RPM drops 200 rpm and shakes when coming to a stop spatcha88 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 04-21-2015 08:27 AM
