Old 02-10-2022, 06:38 PM   #1
PatMegron
Drives: 2016 Sport Tech BRZ
Climate Control and Headunit no power
I was about to attempt to install a backup camera on my 16 BRZ. I unbolted the 4 screws holding in the headunit and before doing anything at all I turned the car on to see if things are going well.
I turn on the car and the headunit and the climate controls don't light up nor function.
I have checked what my manual says are the fuses for the climate control both in the engine bay and the driver kick panel and they looked ok. I also have removed the climate control and headunit just to plug and unplug anything that may have come loose, to which fixed nothing.
Anything people may suggest? I have a months away appointment at a dealership so i may as well see what people can suggest here. Funny enough when I called a different subaru dealer, they advised me to visit an car audio shop instead. Maybe they would have a better understanding of the electronics?
PatMegron is offline   Reply With Quote
Old 02-10-2022, 10:10 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i usually go crazy and just check all the fuses. does the dome light still work? could be the accessory fuses related to dome lights, or ecu.
Old 02-11-2022, 12:18 AM   #3
PatMegron
Yeah the dome light still works, I found a thread that mentioned that switching fuses for a new one might work so I'll be giving that a try. Thanks for your input.
Old 02-11-2022, 03:55 AM   #4
soundman98
soundman98's Avatar
It really sounds like you 'lost' power on the accessory circuit. There's 2 power wires going to HVAC, and radio. A constant power that supplies enough to have the device do what it needs to, as well as a switched accessory power from the key that's a low power circuit that controls the on/off state.
The next step I would take would be to test for voltage behind the radio to confirm if it's getting the turn-on signal.
In my mitsu eclipse, there was a yellow block with 2 fuses that controlled all the vehicle accessories. During shipping, they yanked the block and it killed all the ancillaries. Many a time I blew that fuse and ended up in the same position you are. But because the fuses were in a different block, they went unchecked a lot of times. The 86 doesn't have that same yellow block setup, but the fundamentals are still there that there's really 2 circuits powering the radio and HVAC.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (02-13-2022), PatMegron (02-11-2022)
Anybody Use the Climate Control? carma143 BRZ First-Gen (2012+) — General Topics 32 11-07-2017 08:24 PM
Climate Control Eight6ix CANADA 3 04-18-2016 10:50 PM
Dual Climate Control F3RGY68 Issues | Warranty | Recalls / TSB 1 08-20-2015 10:26 AM
Climate Control Magiclow Cosmetic Modification (Interior/Exterior/Lighting) 3 10-05-2014 06:46 AM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 10:19 PM
