#1541 |
Drives: 2020 BRZ
Oil Cooler
For those of you that track, which oil cooler are you using and where/how did you mount it. Pictures and as much info/input as possible is greatly appreciated.
So far, I am thinking of deleting the windshield washer reservoir and mounting the cooler there, may replace the stock crash beam in favour of a custom "bash bar" to help with mounting and possibly better air flow. Thank you! (this a track only car). |
#1542 | |
Drives: blue - Cosworth SC stage 3.0
eaton say the oil is generally good for 100K miles but if you think the gears are rattling then probably worth changing it |
#1544 |
Drives: BRZ Cosworth SC MY16
Hello there,
haven't been here for a while but I want to ensure that everything is ok with me and my supercharged BRZ. It's winter time, so my car is in a garage since mid November , permanently connected to a Ctek battery charger. In a few weeks it will have it's sixth birthday, and still has less than 20 kkm on odo and less than 10 thousand kilometers with Cosworth supecharger. I have a present for it : a smaller supecharger pulley, belt and new air filter. I mostly use my BRZ on highways, and during a hot summer, oil temp raises to 115'C (240'F) when driving 160-180 km/h. Maybe I need an oil cooler? Best regards Seb
| The Following User Says Thank You to Seba For This Useful Post: | weederr33 (02-03-2022) |
#1545 |
Drives: brz 2017 hksv2
yes, go for the cooler
#1546 |
Drives: 2016 Cosworth 2.2 BRZ
I have just over 70,000 miles on the car and 50,000 miles (80k km) on the supercharger. I have had the smaller pulley installed the entire time and have installed the Crosstrek OEM oil cooler. I also have a Mishimoto oil catch can. These are my only two aftermarket upgrades...
This car is my daily driver and the performance and reliability are perfect. I have driven it in the snow, on long trips and frequent stop an go traffic. For me, this supercharger has performed flawlessly. For maintenance, I change the oil, air filter, rotate the tires and empty the catch can and replaced the belt once. I also spray off the mass air flow sensor when I do an oil change. The only problem I ever had out of the car was it wouldn't start one time. One of my coolant hoses back near the firewall had slipped down and was resting on the wire which runs to the starter. It had unplugged this wire and so the car wouldn't start. I wire wrapped the coolant hose so it couldn't fall down again and the problem has never reoccurred. I get around 29-30 mpg real mileage as calculated from the odometer. It's been through 3 sets of tires and these latest are by far the best for me. I run Michelin Pilot Sport A/S 3+ tires. They outperform the Pilot Sport 4S which I had on before this and have lasted much longer... Plus are cheaper. This car has such an amazingly smooth power band. It's so linear that it feels almost like an electric car. Cosworth did an amazing job and made this car what it was supposed to be. It's just a shame that they don't make them anymore because they really had something here.... |
#1547 |
Drives: 18 BRZ tS, 27 GRMN 86
Hi All,
Anyone experienced blue smoke in the exhaust after tracking the car? The track I went has some elevation change and two other NA BRZ/86 has similar issue after 2 sessions as well. Two mechanics at site suspect that it is the PCV issue. I have a catch can already but we think the oil somehow suck back in to the engine (due to the g force?) but not 100% sure. The blue smoke on my car is relatively less than the other two 86/brz. After driving on the hwy under 4k rpm for 30 min, all the blue smokes are gone and things are back to normal. Any suggestions on how to prevent this? Do we need this for our supercharger? https://jacksonracing.com/product/pcv-valve/ https://www.ft86motorsports.com/suba...lications.html https://www..com/forums/showpost.php?p=1894829&postcount=754 Not sure how to tag Matt@Cosworth here, can someone help? Thanks! |
#1548 |
Yes you should upgrade the pcv
that jackson valve looks good and very cheap, i d take it |
| The Following User Says Thank You to tomm.brz For This Useful Post: | botbs (04-06-2022) |
#1549 |
#1550 |
the wrx sti PCV is compatibile and yes i have that
but i would prefer to have also that Jackson racing one way valve too, seems more robust |
| The Following User Says Thank You to tomm.brz For This Useful Post: | botbs (04-07-2022) |
#1551 | |
Drives: GT86 TRD
| The Following User Says Thank You to kaisersalsek For This Useful Post: | botbs (08-19-2022) |
#1552 | |
all the blue smoke are gone. Also make sure not to overfill engine oil
| The Following User Says Thank You to botbs For This Useful Post: | nikitopo (08-19-2022) |
#1553 |
Drives: 2018 BRZ Ts
this kit looks amazing, i want to SC my car but i only want the best and this looks like the one to get. Anyone looking to sell their Cosworth kit?!
#1554 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Good luck finding the kit! They were rare even when Cosworth was still producing them simply due to their outlandish price. Still, it was an amazing kit and super reliable when I had it on my FR-S and the Cosworth calibrations needed minimal tweaking. Sadly, by this point if you can find one, the only support you will get is from a parts bin (if you gotta fix the kit) and a different tuner who may or may not have tuned a Cossie kit before.
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6041 | 11-28-2025 09:08 AM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 02:12 PM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 02:18 PM |
| Phantom FTS Electric Supercharger Owners Thread | TM | Forced Induction | 1206 | 12-15-2019 03:33 PM |
| Supercharger Kits! Vortech/Cosworth | RallySport Direct | Forced Induction | 61 | 06-29-2015 12:26 PM |
