Drives: gt 86
reverse signal wire on tail lights
there is a four pin cable connector on the tail lights does anyone know which colour is the reverse signal for a reverse camera?
#2 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Also, this is a bad way to power reverse cameras depending on what head unit youre using. The stock head units test the backup cam upon start up to see if theres a signal, if not, it wont work even if you power it on later. So you'd have to start your car in reverse gear every time. There are more threads with this info in detail, search around. |
| The Following 2 Users Say Thank You to PandaSPUR For This Useful Post: | continuecrushing (01-17-2017), Tcoat (01-17-2017) |
#3 |
Drives: gt 86
what colour is the reverse signal cable under the trunk? I have an aftermarket Kenwood head unit so this probably doesn't happen?
#4 |
| The Following User Says Thank You to PandaSPUR For This Useful Post: | Tcoat (01-17-2017) |
#5 |
Drives: brz
#6 |
What happens to the backup lights when you unplug it?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (12-23-2021) |
#7 |
Drives: brz
| The Following User Says Thank You to nripinbabu@gmail.com For This Useful Post: | Ultramaroon (01-28-2022) |
#8 | |
| SOLVED: No Reverse/Backup Signal or Lights | sidetrak06 | Issues | Warranty | Recalls / TSB | 46 | 06-30-2025 10:42 PM |
| handbrake wire and reverse wire location Australia gt86 | rsingh | Electronics | Audio | NAV | Infotainment | 0 | 01-16-2017 10:12 PM |
| Wire Valenti Reverse Light to Stock Tail Lights | fizzymike | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 09-10-2016 04:57 PM |
| Tail Lights with reverse | SmartedPanda | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-01-2014 10:47 AM |
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 09:38 PM |
