Drives: 2013 Rally Blue BRZ
You should drop your oil pan and clean out the pickup
I'm mid rebuild after another spun rod bearing at 74k miles on a 2013. I had a new short block installed under warranty at around 54k, then the valve spring recall done around 65k. Doing this latest new short block myself I really can't stress enough how much gasket maker is used on these engines.
I plan on dropping my pan and cleaning out the oil pickup after 1-2k miles once my rebuild is done. I'm also moving to the KillerB oil pickup. Now for the pics. ![]() ![]() All of the debris in this box was shaken out of the pickup tube. This is IN ADDITION TO the gasket maker you can see in the pic above. So I shook this out of the tube, THEN removed the mesh and took the above pic.
#2 |
Drives: 2013 GT86 fully standard
Wtf, this liquid gasket pandemic need to be stopped. Its really all over the world. My car had a new engine before i bought it after a valve spring fix. Now i feel i should check my oil pickup, obviously applying gaskets isn't part of the education for Toyota/Subaru mechanics, i thought it was something you learnt on day 1.
#3 | |
Drives: '13 Whiteout
#4 | |
We should blame Subaru for opting to use gasket maker instead of regular gaskets. Sent from my Pixel 4 using Tapatalk |
| The Following User Says Thank You to demasrv For This Useful Post: | TommyW (01-17-2022) |
#5 |
Drives: brz 2017 hksv2
In the fabric a robot puts the sealant, apparently it s more economic for them like that
#6 |
I've put engines together before, though not this typ of engine, and have never had so much excess, its supposed to be a very thin layer. But i agree, its a cheap solution and skipping the gaskets creates alot of risk, especially if it needs to be opened at work shops.
#7 |
TRACKBREAD
The split crankcase makes it very hard to make a gasket work, add thermal expansion of that weird joint and gaskets will fail much earlier than on simpler engines.
I’d be willing to bet that the sealant is actually more expensive than using a gasket. Part cost vs technician time. Having a tech spend 2mins applying a bead to an interface is more expensive than spending 2 seconds throwing a gasket on it. Keep in mind that Porsche (the only other manufacturer that builds boxers) seals theirs the same way. Considering their MSRPs and profit margins they would do it differently if there was a better way. |
| The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
#8 | |
Drives: Crapcan
There are a few reasons to use sealant over gaskets. On something like the timing cover, a gasket wouldn't work and would leak all the time. That is a big cover and when you throw in the stresses on it(the oil pump is housed in the cover), and heating and cooling cycles it just doesn't work. Another is the tolerancing on sealant is more consistent over gaskets. You also get firmer fastening between two parts.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#9 |
Drives: 2015 FR-S
@demasrv I see you got into your rebuild! One good inexpensive way to find if you have this problem is to look at your oil filter. Like I did here with pics https://www.ft86club.com/forums/showthread.php?t=146429
I found flakes/chunks of sealant there and so I dropped the pan and found some shit, not as much as you. Then installed the killerB. My engine is stock but had to reseal for timing cover leaks and it still happened I mentioned used oil analysis, but I found another place that does use oil filter media analysis haha, more expensive and mostly for industrial/ships/planes applications but probably can be applicable here if you think you have a problem. UOA doesn't pick up solid particles you can see with your eyes |
#10 |
Drives: _
How much time are you guys giving for the sealant to cure before adding any oil?
| Motul Eco-lite vs X-Clean vs X-Clean EFE | Jasper | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-24-2021 08:13 PM |
| Gap Between Oil Pickup & Oil Pan? | Bonburner | Engine, Exhaust, Transmission | 2 | 10-17-2018 06:02 AM |
| 86 pickup | DavidBob | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 01-19-2015 02:10 AM |
| Drop it Like its Hot! *Lets See Your Drop* | VIXEN | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 92 | 09-07-2013 03:53 AM |
