Old 01-13-2022, 05:01 AM   #127
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by RZNT4R View Post
They make little solar charger you can just put on the dash just for that purpose.
My Panasonic was 3 years old last month from the delivery date, I forgot the dome light a few times while at the gym this winter, battery didn't mind, I'm curious to see how long it lasts with the 2017+ charging system. The Panasonic in my old RAV4 I replaced after 12 years, it was still starting the truck below -20C.
After draining it completely like 3-4 times this fall by forgetting the dome light overnight again and again, even after being put on a battery charger each time and not just driven, the stock panasonic finally gave up and couldn't muster the amps to crank over a -25C block of ice of an engine. Strange, my NOCO 3000A jump starter didn't struggle...
I've claimed in the past that AGM batteries weren't ideal for a 2017+ since they spike the charging voltage high intermittently and AGM has a lower charging voltage than flooded. Though in the the years since, the amount of cars using AGM batteries and start/stop systems has increased a lot and those cars constantly alternating between high charge and discharge rates and their almost universal use of AGM hint at me that I was probably making too much of it. So I went with a beefy Napa-branded East-Penn 9A35/85 with 600CCA/100RC/50Ah.
Old 01-25-2022, 05:54 AM   #128
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Got Costco Membership?
Interstate Battery:USD$99
Item Number 8850242
Group Size 35
CCA 640
CA 800
Voltage 12
RC 100
Length 9 1/16
Width 6 7/8
Height 9 7/16
Weight 38.2
Termination Code POST TYPE
Wet/Dry W
36 Month Limited Warranty Replacement
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 01-25-2022, 08:21 PM   #129
Decep
Drives: 2013 FR-S Series 10
Me and my pop both got those a couple years ago and that's all they lasted. I'm assuming it was a bad batch in 2019. Mine basically puked acid everywhere, my dad's just wouldn't hold a charge anymore.
edit: for what it's worth, he got a refund from costco recently. they don't swap the battery they just give you a refund which kinda sucks, because now of course the battery is more expensive. I ended up going with an AGM Odyssey battery. Completely overkill but hopefully won't have to deal with battery acid everywhere again. I just gave mine to Oreillys since i hate going to costco and dealing with crowds of idiots in parking lots.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 01-26-2022, 10:17 AM   #130
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I had an "Everstart" battery in my FRS whan I first got the car. It also puked acid on the firewall. Went with a red top Optima.
Old 01-27-2022, 02:22 AM   #131
radroach
Drives: car
I prefer a battery size 26R (positive terminal right). They weigh less than a group 35 battery.
Old 01-27-2022, 10:33 AM   #132
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The OEM battery is one of the cheapest options, down to ~80 USD at some dealers.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
22R (02-08-2022), Busybee (01-27-2022), Ultramaroon (01-27-2022)
Old 01-27-2022, 10:40 AM   #133
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
3 years 50k in the NY and Boston region. No issue! Most probably will last another 1-3 years and the OEM will be my choice
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
The Following User Says Thank You to Busybee For This Useful Post:
Yoshoobaroo (01-27-2022)
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 03:05 AM
Is your FR-S your daily driver? Drive Scion FR-S / Toyota 86 GT86 General Forum 136 02-10-2014 10:10 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-16-2012 12:48 AM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 10:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 02:14 PM
