Old 06-13-2021, 10:01 AM   #15
7 skulls
Drives: 2014 scion frs
Can't see pics.
7 skulls is offline   Reply With Quote
The Following User Says Thank You to 7 skulls For This Useful Post:
SOCON (06-30-2021)
Old 06-26-2021, 11:56 PM   #16
SOCON
SOCON's Avatar
Drives: 2017 WR Blue PP
A couple of pics from the last test and tune at SGMP Cecil ga. My old friend brought his bone stock C8 Vette out for a leisurely 11.56 run
SOCON is offline   Reply With Quote
The Following 2 Users Say Thank You to SOCON For This Useful Post:
beltax90 (06-30-2021), BrahmaBull1990 (06-29-2021)
Old 06-26-2021, 11:57 PM   #17
SOCON
SOCON's Avatar
I hope the picture business has been resolved now
Old 07-16-2021, 08:24 PM   #18
SOCON
SOCON's Avatar
Just finished up a 750 mile round trip to pick up some tires and wheels I bought in Jupiter Florida. 17x9+40 Konig Hypergrams with Bridgestone RE71RS tires. The whole trip, I couldn't believe how responsive the supercharger was going down the highway. As advertised there were some scuffs on one of the wheels, a blue Sharpie covered that up easily that the casual observer would never notice. Going to cars and coffee meet in the morning and autocross with Red Hills Region SCCA on Sunday.
The Following User Says Thank You to SOCON For This Useful Post:
Dzmitry (07-20-2021)
Old 07-30-2021, 10:33 PM   #19
SOCON
SOCON's Avatar
beltax90 (08-29-2021)
Old 08-07-2021, 09:25 PM   #20
SOCON
SOCON's Avatar
70000 mile oil change
Mobile 1 M1-104A filter
Kendall GT1 0-20
Also finally pulled the trigger on an SCCA annual membership
Dzmitry (08-09-2021)
Old 08-28-2021, 04:53 PM   #21
SOCON
SOCON's Avatar
Go Fast Bits lightweight three pulley set installed.
Improved in town drivability immensely after supercharger install.
Old 01-23-2022, 04:42 PM   #22
SOCON
SOCON's Avatar
Been a while since I updated
Christmas week took an epic journey to North Georgia six passes, Cherohala Parkway (spelling?), Blue Ride Parkway, of course Dragon Tail, Fontana Dam, Zepherhills FL, Tallahassee. 2000 miles in all. First trip to the mountains since boost and Falken Azenis tires.
The side trip to Zepherhills was to grab Verus Engineering rear adjustable contol arms
Old 01-23-2022, 04:45 PM   #23
Espi
Espi's Avatar
Drives: 17 BRZ
Nice pics and progress! Im also in GA and frequent the above spots. Twins really come alive out on the mountains.
Espi is offline   Reply With Quote
The Following User Says Thank You to Espi For This Useful Post:
SOCON (01-23-2022)
Old 01-23-2022, 04:51 PM   #24
SOCON
SOCON's Avatar
suspension upgrades
Verus Engineering LCA
Godspeed Toe arms
Alignment
villainous_frx (12-07-2024)
Old 01-28-2022, 11:29 PM   #25
SOCON
SOCON's Avatar
Well I learned 17x9+40 Konig Hypergrams with Falken Azinis 245-40 and -2.5 deg of camber on front rubs sachs dampers HARD. Will have to back off camber until coil overs with smaller diameter springs get moved up on the wish list of life
villainous_frx (01-29-2022)
Old 01-29-2022, 03:06 PM   #26
rbfr.s
rbfr.s's Avatar
Drives: 2014 FR-S
Originally Posted by SOCON View Post
Well I was this many years old when I learned 17x9+40 Konig Hypergrams with Falken Azinis 245-40 and -2.5 deg of camber on front rubs sachs dampers HARD. Will have to back off camber until coil overs with smaller diameter springs get moved up on the wish list of life
Ran into the same issue with my setup as well. I have 57crs 18x8.5 +45 with Michelin PS4 245/35 and 255/35. Sidewall kept rubbing up on the lowering springs with only -0.5 degrees of camber. Decided to buy some coils off a member and replace my custom Bilstein configuration.
Professional Car Breaker
rbfr.s is offline   Reply With Quote
The Following User Says Thank You to rbfr.s For This Useful Post:
SOCON (02-04-2022)
Old 04-17-2022, 03:51 PM   #27
SOCON
SOCON's Avatar
The clutch replacement saga begins
So after getting some input from the F/I forums I went out to Harbor Freight and got an engine support ~80 bucks. Worked very well. Removed six bolts securing S/C to head and lifted high enough to easily access slave cylinder and trans power plugs
Old 04-17-2022, 04:06 PM   #28
SOCON
SOCON's Avatar
Clutch replacement saga continues
The previous owner or a shop used apparently replaced the clutch without using an anti-seize compound and / or over torquing or cross threading both starter bolts, which despite mine and AeroKroil's best efforts promptly wrung into.
I twice attempted to weld nuts to the exposed threads which promptly wrung off as well. The evening was finished off by drilling out the offending bolts with left hand bits, while the whole time was hoping for a grab and extraction. All of this left the holes pretty fockedop.
This morning began with creating a cardboard template of the block face which I will use to fabricate a drill guide for threaded insert installation.
Diary of a noob track man (oh and his car too). jonbonazza Member's Car Journals 4 10-22-2014 12:14 AM
Evasive Motorsports Pikes Peak International Hill Climb 2014 | Diary Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 07-15-2014 11:41 PM
Tablet Install Build Diary Dezoris Electronics | Audio | NAV | Infotainment 98 03-13-2014 01:40 PM
Diary of the red bat Tucson FR-S Member's Car Journals 8 04-27-2013 09:24 AM
FT86 SEMA Picture Diary - MUST SEE PICTURES!! genometuning BRZ Photos, Videos, Wallpapers, Gallery Forum 12 11-03-2012 05:08 PM
