Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-12-2021, 12:23 PM   #43
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
Originally Posted by tenderization View Post
Just checked my mirror after getting home from the dealer today. Looks like it works, the orange light came on within a second or two of pressing it, and it paired in a few seconds as well.
If you can, look at the connector going to the mirror and see if there are more than 3 wires. Mine has the dead HomeLink issue and there are only 3 wires in the connector. You can see this post at 5:50 of the video to see how to check the mirror side connector.
https://www.ft86club.com/forums/showthread.php?t=147937
PhatFreshPrince is offline   Reply With Quote
Old 12-12-2021, 08:36 PM   #44
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I'm not sure that there should be any more wires. With the lights on, the dots on the homelink buttons are illuminated like they should be. It just doesn't recognize the button presses.
Old 12-13-2021, 03:17 PM   #45
PhatFreshPrince
I am not getting any lights on the HomeLink buttons or on in the mirror with or without the headlights on. I guess I will ask the dealer about it.
Old 12-14-2021, 06:56 PM   #46
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
I showed my dealer this today. They're going to escalate with subaru corporate. They asked I do the same, as nothing will happen fast without a bunch of attention on the topic.
SpectreRT is offline   Reply With Quote
Old 01-12-2022, 05:43 PM   #47
dragoontwo
dragoontwo's Avatar
My local Subaru dealer is getting on my nerves. They ordered the wrong mirror again. This is after it came in on the 4th and the parts dept didn't tell anybody. This will be the 4th mirror order and third homelink mirror(if they order the right one).
They told me we could test plug the mirror before sending it to the shop to save time if it didn't work. Nope. Gotta wait half an hour to find out they don't even have the right mirror. Then have to wait 5 minutes to even leave the parking lot because the car is blocked in the service drive through.
Old 01-12-2022, 05:51 PM   #48
Kado
Drives: 2022 BRZ
There is no real testing needed. Just look at the harness that plugs into the mirror. If there are 4 wires and one is a blue wire, its good. If there isn't its part of a small batch that went out with the wrong harnesses.
If they've ordered 4 mirrors and gotten a bad one every time, you should probably play the lottery. There is no way it was wrong that many times. There is a tech bulletin that states to look at the production date, all mirrors with a production date of 6/30 or earlier need to be replaced. Anything after 6/30/21 is OK
Kado is offline   Reply With Quote
Old 01-12-2022, 06:01 PM   #49
dragoontwo
dragoontwo's Avatar
I asked you about this on Dec 31 and got nothing. They have ordered 2 wrong mirrors. The first was a normal mirror, but they didn't say what was wrong with this one.
Why don't you post a picture of both ends of your jumper harness and we can put this to bed.
Old 01-12-2022, 09:02 PM   #50
otaco
Drives: white limited
I just picked up my limited manual this past weekend and my homelink works fine.
Works great with my chamberlain at my place.
otaco is offline   Reply With Quote
Old 01-17-2022, 03:25 PM   #51
dragoontwo
dragoontwo's Avatar
It seems @Kado can't bother to be a help either time I asked him, so here's a picture of my old harness and new harness together.
After 4 trips to the dealer and 2 non homelink mirrors ordered by them I finally have a working mirror.
Original harness on right, new working on left.
Old 01-17-2022, 03:37 PM   #52
Kado
Drives: 2022 BRZ
"If there are 4 wires and one is a blue wire, its good."
3 wires bad.. 4 wires good. Not super complicated. I have been nowhere near my car to take a picture. Congrats on getting your mirror all squared up.
Old 01-17-2022, 06:21 PM   #53
PhatFreshPrince
Thanks for the update! Can the dealer order just a new wire harness, or do they have to order the whole mirror?
Old 01-17-2022, 06:31 PM   #54
dragoontwo
dragoontwo's Avatar
Not sure on that. There may be a number for just the harness, but you would have to check with the dealer I bet. I can't find it in the parts diagram.
While not proper, you could also just jump the red and blue wires on the mirror. I tried this and it worked.
Old 01-17-2022, 06:58 PM   #55
emce
emce's Avatar
Drives: 22 BRZ Limited
Is there any way to confirm that's what's happening further up the wire bundle? I assume so as the wire harness from the car is only 3 wires. I think it's just constant power, switched power, and ground. So red is probably either constant or switched.
emce is offline   Reply With Quote
Old 01-17-2022, 07:32 PM   #56
dragoontwo
dragoontwo's Avatar
You are correct. The 4th blue wire is teed off under the sheathing.
Tail lights not working, brake lights and turn signals are working Inter Electronics | Audio | NAV | Infotainment 10 09-15-2022 01:50 AM
FS: Homelink mirror SWPinATL Interior Parts (Incl. Lighting) 8 05-22-2015 05:37 PM
DIY Homelink Install DrunkMonkey45 DIY (Do-It-Yourself) Guides 7 12-26-2014 03:57 PM
Homelink fuse Deathalo Electronics | Audio | NAV | Infotainment 2 03-19-2014 02:02 PM
HomeLink FRS dav0777x Scion FR-S / Toyota 86 GT86 General Forum 37 08-02-2013 08:53 AM
