Old 01-06-2022, 03:00 PM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by JohnH View Post
as a professional wrench, there are at least 5 normal issues that make this kind of noise. Its definitely a relevant thing to want to listen to it.
For example, is it a lifter not pumping up quickly? Or an exhaust manifold leak? Or a heat shield? Or an item stuck in the belt that flung itself out after a bit? All completely different diagnosis and prognosis. All to Tatatatatatata
could also be an annoying passenger, a passing truck applying their jake brake, or full-auto gunfire.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (01-06-2022), x808drifter (01-07-2022)
Old 01-06-2022, 03:26 PM   #16
As a non-professional wrench, I understand.
I was "jest ah messen wich" ol Ultramaroon -
Old 01-06-2022, 05:13 PM   #17
radroach
Drives: car
I've had tapping on startup once, it was the day after my car had been picked up J02 valve spring recall (3 years ago) and the fuel in the tank had been sitting for a month. It was also the middle of July in a 100+*F. I think it was a fueling issue for one reason or another but given it was right after the recall service, can't throw that out.
Old 01-16-2022, 09:42 AM   #18
Youx
Drives: Toyota GT86 2012
Hello again guys.
After recording each start for ~10 days, it finally happened again (after leaving it outside for a day and a half), and I was able to capture it :
It starts at around 15s and is quite loud (before that there is the sound of rain). No sure how to describe it, kinda metallic vibration/creaking?
Youx is offline   Reply With Quote
The Following User Says Thank You to Youx For This Useful Post:
Ultramaroon (01-16-2022)
Old 01-16-2022, 10:31 AM   #19
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Scary noise on cold start
That sounds like metal on metal. First thing I’d do is check the oil pressure on idle.
Old 01-16-2022, 10:39 AM   #20
JD001
JD001's Avatar
Drives: Subaru BRZ
What part of « ta-ta-ta-ta-ta-ta-ta »,, don't you understand?
Should have bought a VW.. more da-da-da-da......
Old 01-16-2022, 10:43 AM   #21
JD001
JD001's Avatar
Drives: Subaru BRZ
And then for the computer nerds on the forum:
Excuse the quality, it is Microsoft after all...
Old 01-16-2022, 08:29 PM   #22
Originally Posted by Youx View Post
Hello again guys.
I am certain that it's not engine mechanical. Other than that, I could make some wild guesses. It does sound like a metallic creak.
Old 01-17-2022, 05:08 AM   #23
Youx
Thanks for the feedback. That would be quite a relief ��
Where would you look at first? I was thinking loud like that it could come from somewhere along the exhaust line, like something loose or a catalytic converter starting to die? (I know from experience catalytic converters can make a metallic rattle when they start to break, although 80k km seems a bit early). Bottom inspection first?
I’ll keep in mind the oil pressure check too, but for now I don’t have the equipment…
Old 01-17-2022, 10:25 AM   #24
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Can you shoot another video looking under the hood (bonnet). Maybe look specifically at the belt tensioner. Also is the sound coming more from one side of the engine or the other.
Old 01-17-2022, 10:32 AM   #25
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
My first thought was exhaust heat shield rattling or touching part of the frame.
BigTuna is offline   Reply With Quote
The Following 2 Users Say Thank You to BigTuna For This Useful Post:
mswbrz (03-30-2022), Ultramaroon (01-17-2022)
Old 01-17-2022, 12:24 PM   #26
Youx
I’d say from the driver seat, it felt like it came more from the passenger side, but it’s hard to tell as it lasted only a few seconds.
I’ll get the car back in 2 weeks, so I’ll do another video then (and maybe get someone to start it while I film/listen from outside).
I should also have access to a pit then, so I’ll look at the visible exhaust parts.
Thanks!
The Following 2 Users Say Thank You to Youx For This Useful Post:
blsfrs (01-17-2022), Ultramaroon (01-17-2022)
Old 02-07-2022, 10:44 AM   #27
Youx
Noise with hood open :
https://youtube.com/shorts/hiH5tLVjzGo
Old 02-07-2022, 02:27 PM   #28
It's definitely some sort of rattle outside of the engine. I don't think it's the AC compressor itself but notice that the rattle stops as soon as the compressor quits running. This is most likely because the engine quits laboring to drive it.
It's an odd one! Maybe a loose engine support. It's loud!
Transmission Noise in Neutral @ Cold Start Jackal84 Issues | Warranty | Recalls / TSB 57 03-01-2021 04:21 PM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 01:54 PM
Perrin CBE crackling noise during cold start tracerit Engine, Exhaust, Transmission 8 02-26-2015 04:43 PM
Rubbing noise on cold start only in reverse? brsaresmgs Issues | Warranty | Recalls / TSB 2 01-18-2015 08:15 PM
Cold Start Clunk Noise Luckrider Issues | Warranty | Recalls / TSB 6 11-28-2013 06:02 PM
