Old 01-15-2022, 02:46 PM   #1
toughguy39
toughguy39's Avatar
Drives: WRB Turbo Brz
How to maximize grip?
Hey guys,
Besides stiff suspension and better tires, is there more I can do to increase grip in the rear? My car has been turbo'd, running 255s on a 8.5 wheel and the rear just LOVES to break traction whenever I give it the beans... and sometimes not even full throttle either. Open to hearing y'all out. The price of any mods will just save me on tire expenses. Thanks.
toughguy39 is offline   Reply With Quote
Old 01-15-2022, 02:54 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
For stop light racing, sounds like you need better tires.
If it’s track/autox alignment settings can help tremendously to control the oversteer, but you’ll only ever have so much grip, I’ve got no problem sliding the rear on stock power on 245 200tw tires on 17x9’s, and there’s no parts or tweaking that’ll change that.
ineedyourdiddly
Old 01-15-2022, 02:59 PM   #3
DougKelly20
Drives: Legacy 3.6R
What application are we talking here? Street? Track? Drag? What are your current suspension mods?
For traction you want downforce...and if your rear end is TOO stiff that will hurt traction around a track.
How much WHP are you at? What model tire are you running? Do you care about weather conditions?
DougKelly20 is offline   Reply With Quote
Old 01-15-2022, 03:12 PM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
By his wording I'm thinking stoplight warrior
TommyW is offline   Reply With Quote
Old 01-15-2022, 03:26 PM   #5
radroach
Drives: car
Positive traction kit (differential, subframe, and crossmember bushings) helped to fix wheel-hop from my aging subframe and diff bushings
The Following User Says Thank You to radroach For This Useful Post:
jeepmor (01-23-2022)
Old 01-15-2022, 03:26 PM   #6
toughguy39
toughguy39's Avatar
I'm currently running BC Racing BR series coilovers. I will give lowering the stiffness a shot. Not Dyno tuned but I usually sit at 11 psi WOT. My tires are Continental Extreme Contact DWS06.
Old 01-15-2022, 03:27 PM   #7
DougKelly20
Drives: Legacy 3.6R
Yeah well in that case tires are your only option and maybe SOFTER suspension. Get sticky R compounds and don't drive in colder temps.
Sorry posts came in out of order 8 should have quoted. This was in response to stoplight warrior.
Old 01-15-2022, 03:29 PM   #8
toughguy39
toughguy39's Avatar
Lmao there's nobody to race in my city even if I wanted to. It's just when I want speed up in low gears my grip just says no. It's like a cartoon when they are going fast... But not moving for a second lol
Old 01-15-2022, 03:31 PM   #9
toughguy39
toughguy39's Avatar
Is there certain tires you could recommend?
Old 01-15-2022, 03:33 PM   #10
DougKelly20
Drives: Legacy 3.6R
Ahh ok, I have the same setup on my 3.6R...DWS06+ and BC BRs. On the street I run them on 25 out of 30 soft. They hook up very well ...but even tuned I have less torque than you...BUT I have about 300 lbs on you which is probably why I don't break traction. Adding weight would work but also kinda counterintuitive...
Old 01-15-2022, 03:41 PM   #11
toughguy39
toughguy39's Avatar
That's what I'm set at currently. Going to put it to 12 clicks behind full stiff. Should the front and rear be the same?
Old 01-15-2022, 03:41 PM   #12
Jdmjunkie
Drives: Scion FR-S 10 Series
Either get the MCS traction mod or adjustable traction arms to reduce rear anti-squat. The geometry of our rear suspension is off of the WRX so it is setup for awd not rwd. By tuning out the anto-squat you induce more rearward weight transfer giving you more grip. Also get better tires.
Jdmjunkie is offline   Reply With Quote
Old 01-15-2022, 03:46 PM   #13
DougKelly20
Drives: Legacy 3.6R
Lastly, I notice you went up a tire size...check the load index vs stock...you might need to take a couple psi out of the tires too.
The Following User Says Thank You to DougKelly20 For This Useful Post:
Old 01-15-2022, 03:48 PM   #14
DougKelly20
Drives: Legacy 3.6R
No I mean I'm 5 clicks from full soft. Still way stiffer than stock. Would not recommend using much different setting front and rear unless you are really testing how it corners that way...
Need advice on how to maximize my factory warranty moda3 Issues | Warranty | Recalls / TSB 12 05-17-2020 10:29 PM
WTB: NYC/NJ ARK GRIP ChaosTheSlayer Want-To-Buy Requests 0 12-05-2016 11:07 PM
WTB ark grip or dts Ayo_narith Want-To-Buy Requests 0 11-14-2015 12:17 PM
The Different between "Gain Grip by Width" & "Gain Grip by Compound"? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 05-03-2014 03:26 AM
grip? pr086 Scion FR-S / Toyota 86 GT86 General Forum 16 12-21-2012 10:36 PM
