Old 01-08-2022, 07:46 PM   #239
ML
ML's Avatar
Drives: 13 White MT FR-S
Originally Posted by captain awesome View Post
That makes sense. I really want to get started on a SC setup but for now I think I'm going to hold off. If a partial kit of any brand pops up cheap I may snatch it up to help make piecing something together easier though.
Jackson racing said they have been working with Kpower and will be releasing a SC kit for the kpower kit very soon!
The Following 2 Users Say Thank You to ML For This Useful Post:
captain awesome (01-08-2022), Irace86.2.0 (02-07-2022)
Old 01-08-2022, 07:57 PM   #240
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Time to start saving my pennies now!
captain awesome is offline   Reply With Quote
Old 01-09-2022, 03:58 PM   #241
jflogerzi
jflogerzi's Avatar
So much win in this thread!
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
ML (01-09-2022)
Old 05-03-2022, 10:00 AM   #242
ML
ML's Avatar
Haven't updated this in awhile, but I went to my first hill climb last weekend and did a write up if anyone is interested. Car/motor is running great other than some simple exhaust issues.
https://sandlotmotorsports.com/f/my-...-to-be-a-racer
The Following 7 Users Say Thank You to ML For This Useful Post:
captain awesome (05-03-2022), Code Monkey (05-03-2022), Jdmjunkie (05-03-2022), RedReplicant (08-13-2022), Stonehorsw (05-11-2022), SuperTom (05-03-2022), villainous_frx (05-03-2022)
Old 05-03-2022, 12:32 PM   #243
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Looks badass!
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
ML (05-03-2022)
Old 05-05-2022, 10:11 AM   #244
almostquick
Drives: 2017 BRZ PP
Car looks great! Since you are k24 swapped, have you experienced any driveline vibrations with the single piece aluminum driveshaft? I’m wondering if they worked out driveline vibe with better pinion angles with the k24 kit.
Also, what side mirrors are those? They look great.
almostquick is offline   Reply With Quote
The Following User Says Thank You to almostquick For This Useful Post:
ML (05-05-2022)
Old 05-05-2022, 10:35 AM   #245
ML
ML's Avatar
I have not had any issues with vibration yet, or feel that vibrations are so bad its undrivable or anything. I had solid transmounts when I had the FA20 but since went back to rubber, and I would say the NVH is about the same between semi solid FA20 and rubber mounted K24. I also have a raised and solid mounted rear subframe so that helps with the driveshaft angle for sure.
The mirrors are carbon no name rip offs of something, I got off ebay for $40! lol
Old 05-05-2022, 11:18 AM   #246
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Why did you mount the headlights to the hood? Wouldn't it be more aerodynamic and just as functional inside of the OEM lens?
villainous_frx is offline   Reply With Quote
Old 05-05-2022, 11:38 AM   #247
ML
ML's Avatar
Short answer is because SCCA told me I had to have headlights to run that class, and that was the easiest way to do it.
long answer is because I built by own custom tube radiator and "headlight" mounting setup to run the radiator in a different position. I had to gut the stock headlight housing to get them fit and therefore cannot run OEM headlights anymore. Which at the time I didn't expect I would need headlights anymore but then SCCA's stupid classing rules came along and forced me to come up with something. We needed headlights for our champcar car anyway so it kinda worked out.
The Following User Says Thank You to ML For This Useful Post:
villainous_frx (05-05-2022)
Old 05-05-2022, 02:16 PM   #248
villainous_frx
Off to the track!
Ah so that was just temporary. If you need a more permanent solution, you could mount the LED pods behind the lens of the OE headlights similar to what some Formula Drift teams do.
Old 05-05-2022, 02:22 PM   #249
ML
ML's Avatar
yeah I had considered it but those brackets made it real easy but I may go back and do that!
Old 05-09-2022, 01:52 PM   #250
ML
ML's Avatar
I think this will work out.
The Following 4 Users Say Thank You to ML For This Useful Post:
captain awesome (05-09-2022), Jdmjunkie (05-09-2022), RedReplicant (08-13-2022), villainous_frx (05-09-2022)
Old 05-09-2022, 04:09 PM   #251
villainous_frx
Off to the track!
Looks sleek! For your use it'll be great, as they are still "functioning" headlights
The Following User Says Thank You to villainous_frx For This Useful Post:
ML (05-09-2022)
Old 09-25-2022, 10:11 AM   #252
ML
ML's Avatar
Haven't Updated this page in a while...I have mainly been doing some refinements and planning. After the last hillclimb and my exhaust couldn't keep up with the bumps and fell off I finally took it to a professional and had it welded up. I can add a "laguna pipe" off this if I needed to.
Then I went to VIR and had some major overheating issues with coolant getting to 240 and my intake temps getting to 150 and pulling timing, so rereading some books on race car tuning I came up with a secondary inlet for the radiator to get it more air that didn't go through the intercooler while still "splitting" the high pressure air in the front between the two.
I also designed a little air box towards the back of the car to try and keep the hot air in the engine bay away from the supercharger inlet. Made a little gurney flap on the tailing edge of the hood to try and pull any hot air out from between the hood and cowl as well.
On the subject of heat management I threw about 250$ worth of thermal management products at the engine bay and it really seemed to help!
My next track day at Roebling race way I saw coolant temps never get over 200, oil temps were actually a little too cool with the 10w40 and 70psi of oil pressure. INtake temps peaked at 125 so a dramatic drop and timing never got pulled.
[IMG]https://lh3.googleusercontent.com/pw/AL9nZEVJUhiz5z_MCmzMZ1Yrd0NtiQd6_BCDmXuInazbi5wIPZ ieFYY9_FjbkaG7iE8TSr2WvdLY4cl1mJGgATRkdSkC6ptkkyU3 gyijg3mHKXobcUCdKG3D_Dy88R98yEyPazceISW7is_***_NIR LNNlf71w=w1718-h966-no?authuser=0[/IMG]
Redid my DiBond flat floor and its very secure now as well. Hopefully this is the last revision of this, maybe a lighter material in the future but it didn't give me any problems at RRR.
Last thing I did was make a idle pulley tensioner thing to keep the SC pulley from slipping at peak.
The Following 6 Users Say Thank You to ML For This Useful Post:
captain awesome (09-25-2022), gt5759 (09-26-2022), jay_reef15 (09-26-2022), new2subaru (09-25-2022), RedReplicant (09-28-2022), villainous_frx (09-25-2022)
Whiteout FRS Eric_86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 08-28-2012 12:27 PM
MT Whiteout available now... JohnATL Southeast 8 08-09-2012 02:12 AM
Another WHITEOUT in the bay.. :) tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 31 08-06-2012 03:13 AM
My new Whiteout FR-S! Flawless22 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 07-05-2012 03:46 AM
My whiteout fr-s F3dzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 07-04-2012 08:25 AM
