#1177 |
The Dictater
Drives: '13 Red Scion FRS
Ok, need help regarding washes. We FDM printed a larger scale "mini" as a present for someone and I am painting it. The base coat is done minus some touch ups and I have a set of army painter washes that I was hoping to use to get some shading. This would be my first time using them except for a practice piece that wasn't as well printed or basecoated. There are three problems.
1. I am worried the wash will highlight the FDM layers. This happened a bit on the practice piece, but might be less of a problem on the real deal. Not really sure if anyone will have any advice here, but worth a shot. 2. I think these washes were formulated for minis that are much smaller, this being scaled up ~400% I think? That is important because the shading seems a bit off at this scale, and you can see every detail vs smaller minis. 3. The shading is a bit darker than I was expecting, so I really would like a bit more transparency to not change the base color too much. I think reducing the viscosity with flow aid or extra medium might help with all of these, but if anyone has some advice that would be great. Has to be done by Friday, so I can't afford to mess up too badly. Also, pics as an offering to the model gods
#1178 | |
Thinning it will indeed help with your other concerns.
#1179 | |
The Dictater
I've heard: -water -soapy water -flow aid -medium (comes on matte, satin, and gloss) Also, would you apply the wash all over, or just where you need it? |
#1180 | |
Normally I am an all over guy but in tis case stick to just the edges to reduce build up in the layers.
#1181 | |
The Badger being external mix and having sealable glass canisters will be mydedicated flat lacquer brush. No stripping down my double action brush for cleanup after spraying flat top coats. The Aztek is great to have. I have had a full set of nozzles for years and years but never had the rest of the unit to put them on. They have some very cool special effect nozzles (like "spatter") that I will have to try out. Presuming you stop after those four! These would have been perfect starter units and even have the adaptor for using the cans of compressed air or a spare tire. A $10 innertube that you could fill at your local gas station and you would be ready to rock without even investing in a compressor.
| The Following User Says Thank You to Tcoat For This Useful Post: | bcj (01-07-2022) |
#1182 | |
Drives: GR Corolla
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | Tcoat (01-07-2022) |
#1183 |
ProCrastinationConsultant
for those that don't know, i re-discovered micromark, which is always an interesting place to look for stuff. best part? they still have paper catalogs, that make for great reading material in bathrooms
https://www.micromark.com/
| The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (01-07-2022) |
#1184 | |
The Dictater
#1185 | |
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#1186 |
it is now
found my old 2012 edition catalog in some of my hobby stuff
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#1187 |
Drives: RX-7 / BRZ
Ebbro is now making race garages for all their 1/43 cars! At $63ish USD that isn't a bad price but, I cannot find one. Probably a good future scratch-build project anyways-
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | Dadhawk (01-08-2022) |
#1188 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (01-08-2022), soundman98 (01-07-2022) |
#1189 |
The Dictater
So, as a follow up, I didn't have time to get the matching thinner for my washes so I wound up getting Liquitex Gloss Medium, Matte Medium, and Flow Aid to experiment with. The gloss medium looked odd, the matte medium worked better for diluting the pigment. It did wind up making the washes thicker which was good in some cases, considering the increased scale of all the features I wanted to shade. The flow aid was great for making the washes thinner. It also had a dilution effect and was great for keeping the wash liquified to move around on the piece. It says to mix it with water, but I found it to give more consistent results just putting some in the wash/medium.
Anyway, the guy I gave it to was pretty ecstatic. The results: |
#1190 | |
| TRD ABS Plastic Kit? | Shims | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-19-2015 07:31 PM |
| Front lip - abs plastic | _frs | Want-To-Buy Requests | 0 | 09-21-2014 11:11 AM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 10:06 PM |
| plastic interior | lancie | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-16-2011 01:02 PM |
