Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-17-2021, 03:21 PM   #15
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
@dragoontwo, could you give me some tips on how to remove the center console. Where can I pull and where do I need to remove a screw? I wanted to see about routing a USB cable to the glove box this weekend.
PhatFreshPrince is offline   Reply With Quote
Old 12-17-2021, 03:23 PM   #16
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Sure. I'll take some pictures when I get home.
Old 12-17-2021, 04:38 PM   #17
dragoontwo
dragoontwo's Avatar
Hopefully the images post in the correct order.
Pull the panel under the switches first. Then the 2 screws behind it. Pull up on the e-brake cover. Pull the outer shifter surround up and back. Pull the inner shifter surround up and out (remove the knob first).
The Following User Says Thank You to dragoontwo For This Useful Post:
jongers (12-17-2021)
Old 12-17-2021, 05:22 PM   #18
PhatFreshPrince
Thank you. This will work great! You should have got a pic of the new cup holder from the automatic console.
Old 12-17-2021, 05:56 PM   #19
dragoontwo
dragoontwo's Avatar
I don't have it in yet.
PhatFreshPrince (12-17-2021)
Old 12-19-2021, 02:07 PM   #20
Kado
Drives: 2022 BRZ
Ok. So it doesn't work. There is a different part number for the console cupholders as well as the whole center console. The AT console with the cup actually sits about a half inch higher and the mounting points for the cubby are equally a half inch off.
PN for the AT setup:
Console Box: 92114CC000
Console: 92113CC010
The console plastic is cheap, but the replacement box with the right mounting points is a bit pricey.
MT Console
AT Console
Height Difference
Kado is offline   Reply With Quote
Old 12-19-2021, 02:21 PM   #21
PhatFreshPrince
Console: 92113CC010
MT Console
AT Console
Height Difference
Thanks for the comparison. Are you going to grind or cut the AT one to make it fit? Or is it just too different to mess with?
Old 12-19-2021, 05:33 PM   #22
dragoontwo
dragoontwo's Avatar
The console goes in the car just fine. The cupholder cubby doesn't cross over.
As I said in the first post. It took me a bit to get the part to finish because Subaru was a bit slow in getting my voucher out. I got the parts before going on vacation.
Old 12-19-2021, 07:23 PM   #23
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Honestly how hard would it be to use a hole saw and cut in a cup holder on the manual? Put a thick rubber gasket at the top and drop in a cup holder. If there is clearance below to accommodate this in the manual, that is likely what I will end up doing
@Kado How much depth is available below the manual transmission console?
Midnightsky is offline   Reply With Quote
Old 01-01-2022, 04:15 PM   #24
dragoontwo
dragoontwo's Avatar
Finally got everything in. Install how-to here.
The Following 3 Users Say Thank You to dragoontwo For This Useful Post:
AK2112 (01-01-2022), Interceptor777 (01-01-2022), Midnightsky (01-01-2022)
Old 01-02-2022, 01:04 PM   #25
Brofessional
Drives: 2022 GR86 MT, 2021 Mach e GT
There are two USB ports in the cupholder area. I was wanted to add space for my phone in front of the gear shifter. There is room to put your phone there without the cover, but it is tight. It will stick in there straight, but it might get hot in there. Also, if I remove the cover then I can put my phone there sideways without it hitting the gear shifter. Man, just like 5 more mm and it would have worked.
When you says it's a tight fit, is that length, width, and/or thickness? This seems like the best/obvious place to put one. Even if we had to cut the tabs, if someone 3D prints a cubby that works well I would think demand would be high.
I have a magsafe cheeseplate mount I was planning on bolting to the console right where the cupholder is on ATs. I've installed them before and looks super clean, but a printed cubby would be even better if it will fit plugged in.
Brofessional is offline   Reply With Quote
The Following User Says Thank You to Brofessional For This Useful Post:
Midnightsky (01-02-2022)
Old 01-02-2022, 02:12 PM   #26
soundman98
ProCrastinationConsultant
soundman98's Avatar
crazy the design differences between a/t and m/t. that's literally a GM move there. very a-typical for a toyota product.
Center console orc BRZ First-Gen (2012+) — General Topics 11 09-27-2021 11:13 AM
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
red center console? gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 13 02-19-2013 08:03 PM
Center Console help mbh1101 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-22-2012 09:56 AM
Center Console encity5 Electronics | Audio | NAV | Infotainment 1 06-10-2012 09:22 AM
