| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: TBD
Surprising differences in Motor Trend testing: GR86 vs. BRZ
Motor Trend has recent solo tests of both the BRZ and GR86 I haven't seen referenced here yet. Of interest here are the varying results of a few of the instrumented tests MT ran, as they are substantial and highlight the real impact of the differences in how these two cars' suspensions have been set up. (All cars were tested with the Pilot 4s at the same location under similar conditions.)
The BRZ (manual) averaged .93 g on the skidpad test and posted a 25.7-second, 0.71 g (average) on their figure eight test. The GR86 did significantly better at .98 g (manual) and 1.00 g (auto) on the skidpad, with figure-eight times of 24.7 seconds (manual) and 24.8 (auto) at an identical 0.76-g average. These results seem a bit surprising given the general view that the BRZ is set up for a more neutral handling balance, from which one would infer it should have a higher maximum grip. But it appears likely that the GR86 is in fact more neutral at the limit and the BRZ loses out due to more understeer. As R&T notes, "Each car has its own front and rear damper settings, with the Toyota utilizing a 7-percent lower front spring rate and an 11-percent higher rear spring rate compared to the BRZ, respectively. " So the GR86 sacrifices a bit of sharpness on initial turn-in with those softer front springs for higher ultimate grip? |
| The Following User Says Thank You to Sport-Tech For This Useful Post: | Pete (12-10-2021) |
#2 |
Drives: 22 BRZ
That is surprising, and it's very different BRZ numbers than the C&D skidpad results which had the BRZ at .99g and the GR86 at .98. Interesting.
https://www.caranddriver.com/feature...-toyota-gr-86/
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
#3 |
Drives: 2020 BRZ tS
Maybe the tires on Motor Trend's BRZ were shot.
| The Following User Says Thank You to LancePower For This Useful Post: | Pete (12-10-2021) |
#4 |
Drives: 22 BRZ
It seems like there had to be something else going on. The difference between .93 and .98 is more than I would expect from just spring rate tuning right?
Like a difference that big would have been mentioned by all or most of the reviewers. The C&D numbers are just .01 different, and I could believe that, but .05 seems like a lot for nearly identical cars of the same weight with the same tires. Maybe some of our track rat experts could weigh in here. I've been wrong before lol.
| The Following User Says Thank You to Pete For This Useful Post: | timurrrr (12-10-2021) |
#5 |
Maybe the variability in these tests are larger than you think. You are looking a low N as well.
#6 |
Drives: TBD
#7 |
I wonder if they tested on different surfaces. I highly doubt any OEM suspension tuning differences would be responsible for a delta that large on the same tires.
Pretty interesting find though.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Pete (12-10-2021) |
#8 |
I was going to suggest differing alignments between the C&D and MT cars as a potential cause.
But ultimately it doesn't matter to me since I'll probably be slapping some crash bolts in the first thing next spring. |
#9 |
Drives: 2022 GR86
+1 that this feels more like a mistake in the MT testing protocols (as compared to the "industry standard" C&D).
On top of that, IMO all the peak handling performance test results are irrelevant with stock alignment. Anyone who cares about handling performance of these cars should get as much camber up front as their budget allows. |
#10 |
Drives: '23 BRZ Limited
Loose is fast. Tires need a certain amount of slip angle to produce maximum grip.
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | dsc_pat (12-10-2021) |
#11 |
The Dictater
Drives: '13 Red Scion FRS
Most likely tested on different days. Temperature, people, tire life, humidity, etc.
| The Following 4 Users Say Thank You to Spuds For This Useful Post: |
#12 | |
The Dictater
| The Following User Says Thank You to Spuds For This Useful Post: | track junkie (12-11-2021) |
#13 |
Drives: 2013 Scion FR-S Series 10
If I'm not misunderstanding, MotorTrend measures "lateral acceleration" on their "figure eight skipad" which combines 2-300 foot diameter circles connected by a short straight. So the the car travels around half of each circle, accelerates down the short straight, then brakes into the other half circle. They then average this.
Car and Driver, on the other hand, uses either a 200 or 300 foot diameter circle without straights. https://www.motortrend.com/features/...trend-testing/ https://www.caranddriver.com/feature...-we-test-cars/ So perhaps MT's test better highlights the differences when you introduce acceleration and braking to the turn. Whereas with C&D, both cars are settling on their suspension and are holding the corner identically. Or, yes, alignment or something else could be off. |
#14 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
You can test more things with it though, and your changing direction. |
| BRZ/GR86 driving differences | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 30 | 06-14-2021 02:06 PM |
| First clear look at GR86 / BRZ prototype during testing | >(559)< FR-s | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 454 | 03-30-2021 04:09 PM |
| Motor Trend's Top 10 MPG Outperformers | Clutch | Scion FR-S / Toyota 86 GT86 General Forum | 59 | 09-02-2017 03:48 PM |
| Motor Trend's Top 10 MPG Outperformers | Clutch | BRZ First-Gen (2012+) — General Topics | 12 | 09-02-2017 12:02 AM |
| BRZ Motor Trend article | terrypm | BRZ First-Gen (2012+) — General Topics | 4 | 03-28-2012 03:25 PM |
