Old 11-13-2021, 09:10 PM   #15
Dylans47
Drives: Scion FR-S
Originally Posted by saltywetman View Post
Who said Endless had to be blue? :P
My god thats nice. I'm going for a white GR86 so I'd love what you have but in their famous blue.
How much did you pick up your kit for? Is yours the four or six pot? I'm also confused how they do their brakes. So it's a universal caliper but the conversion bracket will vary from platform to platform, or are your calipers specific for the 86?
Dylans47 is offline   Reply With Quote
Old 11-13-2021, 09:47 PM   #16
saltywetman
Drives: 2020 Toyota 86 GT 6M
I'm up in Canada so i think it worked out to be roughtly $7500 CAD after shipping and duties/taxes. Endless was running a promo in the summer and offered free paint color change (no anodization sadly) however since anodization fades with heat i chose to go with paint since i can always get them repainted when they change color from heat. I went with 4pot/2pot because I run 17" winters which won't clear the bigger calipers
I would hope they are not universal calipers. By that logic are all aftermarket brake calipers universal with just custom brackets to fit a specific model? Brembo's gt line has caliper code names that are shared between different models from different makes as well, same as project mu. I would hope that there is some form of tweaking to make a caliper more suitable for a specific car. but who knows maybe all aftermarket bbk's are universal with just different sized rotors and brackets to fit different cars
saltywetman is offline   Reply With Quote
Old 11-16-2021, 03:49 AM   #17
teppey
teppey's Avatar
Drives: BRZ (in near future)
The twin's front caliper is mounted in front of the axle while the rear caliper is mounted behind the axle. AFAIK it is not interchangeable. Source https://blog.racetechnologies.com/20...or-subaru-brz/
teppey is offline   Reply With Quote
Old 11-16-2021, 11:24 PM   #18
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
From that article:
If the calipers are mounted in front of the axle by putting the left hand STI caliper on the right side of the BRZ/FRS and vice versa, then the staggered pistons are in the wrong order, which leads to rapid and significant taper wear on the pad, which causes a number of other problems with the brake system.
The front Brembo calipers on the BRZ have 4 identical size 40 mm diameter pistons.
Some STI calipers have staggered piston sizes, but some model years also have 4x 40 mm pistons. If you find a pair of those, and throw in the Evo rear calipers with 40 mm pistons in the rear, you might be able to get basically the same setup as PP brakes, perhaps for less money.
See also https://www.ft86club.com/forums/showthread.php?t=144662 for more general info on PP Brembos.
Old 11-16-2021, 11:46 PM   #19
Dylans47
Drives: Scion FR-S
Just to clarify guys, by universal we meant that when you go on endless brakes website you can buy a mono 4 kit regardless of vehicle. So we were wondering if the kit saltywetman bought was made specifically for the 86 chassis, or was one of those universal kits. Nothing to do with the same caliper front and rear. I'm certain the front and rear calipers are different for every application be it stock, PP, aftermarket...
Old 11-17-2021, 01:26 PM   #20
DeeAich
Drives: '22 BRZ
Here’s the installation guides in PDF for GR Parts:
https://www.trdparts.jp/product/86/price/
DeeAich is offline   Reply With Quote
Old 11-17-2021, 02:06 PM   #21
ayau
Drives: Some rust bucket
installation of the GR decklid spoiler:
https://www.trdparts.jp/manual_pdf/g...42-18007-8.pdf
looks like it requires drilling, which means you need to swap out the bottom piece when doing a decklid swap.
wonder if the port actually does the installation? seems like a lot of work.
Old 11-23-2021, 09:09 PM   #22
Jianlun
Drives: GR86 RC
Ummmmmmm.......
Jianlun is offline   Reply With Quote
Old 11-27-2021, 02:32 AM   #23
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
They have also an Aero Stabilizing body coat. I am sure butt dyno will tell a difference! Who hired these guys?
Old 11-28-2021, 02:14 PM   #24
Jeonsa
Humble Member
Jeonsa's Avatar
Drives: N/A
Around 4:58 it shows what we’re getting outside of Japan for the most part Lmao.
Jeonsa is offline   Reply With Quote
Old 12-08-2021, 05:03 AM   #25
beltax90
beltax90's Avatar
Drives: 2010 corolla
beltax90 is offline   Reply With Quote
The Following User Says Thank You to beltax90 For This Useful Post:
Midnightsky (12-11-2021)
Old 12-11-2021, 10:56 AM   #26
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I find it really silly how the japanese TRD catalog used to be porn when I was a kid, and now there's a new model! Oh look an ion discharge sticker and aero stabilizing spray! Subaru's got wonky shit like a "flexible stiffner" for the rear bumper and "STi" battery hold down. Even Max Orido is peddling "magic fuse" snake oil.
Meanwhile at Sema in the US: Swaybars, quick shifter, catback, big intake.
The Following User Says Thank You to RZNT4R For This Useful Post:
Lantanafrs2 (12-11-2021)
Old 12-11-2021, 06:33 PM   #27
saltywetman
Has Japan gotten stricter over the years as far as emissions go? Could be the reason we no longer see even catbacks offered from OEM performance branches. Only so much you can milk on suspension/brakes/aero so guess aero spray and a tiny discharge sticker is just a way to pad their bottom end? lol I still prefer japan made parts over even USA.
Old 12-11-2021, 06:44 PM   #28
fredzy
Mebmer
fredzy's Avatar
Drives: Sienna, GR86, TourX
Wow, the aero spray and discharge sticker honestly make me think twice about considering any of this stuff. Legitimately reputation damaging. I mean I’m sure the other parts are fine, but why would anyone give their money to people that offer that crap?
Reminds me of https://jalopnik.com/how-a-box-of-ma...mos-1822559023
fredzy is offline   Reply With Quote
The Following User Says Thank You to fredzy For This Useful Post:
wheelspeed (12-22-2021)
Subaru BRZ parts catalog BMWDavid BRZ First-Gen (2012+) — General Topics 45 08-09-2015 07:28 PM
SUBARU BRZ Accessories Catalog (JDM) Turbo95eg6 BRZ First-Gen (2012+) — General Topics 14 01-20-2014 08:40 PM
Enkei 2014 Catalog mwjcyber Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-19-2013 03:46 AM
SPT Catalog w/BRZ parts available as soon as two weeks... enwave BRZ First-Gen (2012+) — General Topics 13 11-12-2013 04:20 PM
TRDSparks catalog kanundrum Scion FR-S / Toyota 86 GT86 General Forum 6 12-07-2012 03:00 PM
