Southern California SoCal
Old 11-15-2021, 01:54 PM   #13441
xxthrillxx
Perfectly Balanced...
xxthrillxx's Avatar
Drives: '13 FRS & '13 BRZ
I have two FA20s, one assembled long block, other is disassembled with both heads. Both are blown, if you can make heads out of tails or just need parts, let me know... take them both for $1,200
Sent from my SM-N986U using Tapatalk
xxthrillxx is offline   Reply With Quote
Old 11-16-2021, 06:51 PM   #13442
danng
Drives: slow
White Line Bump Steer Kit
BNIB Bump Steer Kit for BRZ/FRS.
KCA435
2015 Scion FRS - INSTAGRAM
danng is offline   Reply With Quote
Old 11-16-2021, 07:16 PM   #13443
HachirocksU
Drives: Friggin Really Sweet
WTS 2013 Stock rear bumper + exhaust
WTS 2013 Stock rear bumper(firestorm) + exhaust
Sold off the car and have these remaining spare parts.
Pickup will be @ Murrieta. Zipcode: 92563
HachirocksU is offline   Reply With Quote
Old 11-21-2021, 09:28 AM   #13444
jbetanc
Drives: red frs
So. Cal 2013 FRS FOR SALE
SOLD
2013 SCION FRS
Automatic With Paddle Shifters
170,000 FREEWAY MILES Runs Strong
Drive to LA from S. OC Had to go Electric Why I'm selling
Tags good till May 2022 (Smog check in May with Tune)
Airaid 510-307 Intake
Swift springs on stock shocks
Vishnu Openflash Tuning Tablet with stage 2 tune installed
OEM Audio Plus Reference 500 stereo system installed
clear tom's taillights
LED Headlight Bulbs
Cat back Exhaust (No Name Copy of DC Canisters)
Cross Drilled and Slotted Rotors New
18 Inch Rims and Tires (New Goodyear Eagles)
INCLUDED EXTRAS
Stock exhaust
Stock intake
Stock rims and tires (new)
Stock Front Headlights
Carbon fiber look rear wing lip
[ATTACH][ATTACH][ATTACH][ATTACH][ATTACH][ATTACH]Name:  F7.jpg
Size:  300.4 KB[/ATTACH][/ATTACH][/ATTACH][/ATTACH][/ATTACH][/ATTACH]
jbetanc is offline   Reply With Quote
Old 11-28-2021, 07:52 PM   #13445
jbetanc
Drives: red frs
FOR SALE BLITZ DAMPER ZZ-R COILOVERS
like new $600.00
FEATURES
A single mono tube shock absorber is adopted for all lineup
32 way adjustable damper rates
Ideal for both street or circuit use.
A large 44mm diameter piston is used (Some vehicles area excluded)
This damper can be overhauled to maintain prime condition.
STRUCTURE
A single mono tube design is adopted for the complete range. A large 44mm diameter low friction piston control initial damping, allowing a comfortable ride but a great driving response.
DRIVABILITY AND COMFORT
A 32 way damping rate is incorporated into both shock absorbers. With such a wide range of adjustable, driving performance and ride comfort are maintained at the highest level, even at low speed. Spring rate is setup for each vehicle. A comfortable ride can be achieved with the height adjustment function which allows enough stroke for any driving conditions.
STYLING
The spring sheet and upper mounts are finished in a red alumite. The brackets are finished in a classy matt black. The height adjustment function is shown in millimeters, allowing a wide range of setting to suit any driving conditions.
SETTING
Preload adjustment of the spring and the height can be adjusted separately. A variety of damping rates can be achieved through simple adjustment. Camber adjustment allows alignment to be set to personal preference.
DURABILITY
The cylinder case is finished in a black chrome overlay and the bracket is finished in a special point to improve durability and anti-corrosion.
Last edited by jbetanc; 12-11-2021 at 03:40 PM. Reason: pics, lower price, lower price
Old 11-28-2021, 08:27 PM   #13446
fitcious
$20! Take it off my hands!
fitcious is offline   Reply With Quote
Old 11-28-2021, 09:44 PM   #13447
quixeger
Drives: 2019 6MT on CSG flex A w/SX2s
FS: Mishimoto sound-tube delete
Original thread:
https://www.ft86club.com/forums/show...02#post3485002
New, open package. $5 picked up in 90232. $10 shipped.
quixeger is offline   Reply With Quote
Old 11-28-2021, 09:49 PM   #13448
quixeger
FS: Grimspeed lightweight crank pulley
Price reduction (hence re-post)
Original thread:
https://www.ft86club.com/forums/showthread.php?t=147371
$60 picked up in 90232
$72 shipped.
Old 11-29-2021, 01:41 PM   #13449
BRZedsDeadBaby
BRZedsDeadBaby's Avatar
Drives: 14 BRZ
FS: Toyota JDM OEM Black Dash Trim LHD
$OLD
BRZedsDeadBaby is offline   Reply With Quote
Old 11-29-2021, 04:25 PM   #13450
Rando
Rando's Avatar
Drives: 86
Originally Posted by Rando View Post
Pick Up Only - Located in the 626 - TEXT ME if ur interested - (626) 5one5 - 4Five1Five
Enkei RPF1 18x8 +35 Silver w/ tires (needs to be replace soon) - $1000
DC Sports 4 into 1 Equal Length Header - $200
Bump !
Rando is offline   Reply With Quote
Old 11-29-2021, 09:47 PM   #13451
whataboutbob
AutoX-10/10ths every run
Sent you a PM on rear bumper, looking to get the price. Interested.
Build thread:Here
Old 11-30-2021, 01:34 AM   #13452
Xinnie
Xinnie's Avatar
Drives: 2015 FR-S, 1997 328iS
WTT: 3" X-Force Cat-back. They're a company based in Australia, just some background since not many people know of it. No cracks/holes. I bought it brand new a little more than a year ago. Looking for any single exits/dual exits (pref 2.75" ID or larger) in working condition. I do not want muffler deletes btw.
Located in San Diego, but willing to travel up to LA.
Xinnie is offline   Reply With Quote
Old 12-01-2021, 12:19 AM   #13453
WinnaWinna17
Drives: 2013 Scion FRS, 1998 Sentra SE
Found some
Thanks
WinnaWinna17 is offline   Reply With Quote
Old 12-01-2021, 09:42 PM   #13454
whataboutbob
Bump, you have a PM.
Build thread:Here
