Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-28-2021, 07:27 AM   #15
emce
emce's Avatar
Drives: 22 BRZ Limited
Originally Posted by Yoshoobaroo View Post
Did you take note of the connector in the car? Same number of wires on the car side harness than in the mirror’s wiring?
No, there is an included harness. I followed the dealer installation instructions exactly, which were very straight forward. There's a 3 wire plug hiding in the roof console that you fish out. You then connect that to a harness they supply with the mirror, that takes it from a 3 wire to an 10 pin connection to the mirror. You drop that out of the roof trim down to the mirror, connect it, and you're done. Not really anything to mess up.
Per the wiring diagram the three wires are just power, ground, and some sort of signal to the back-up lighting system so the problem seems like it may be in the mirror itself.
emce is offline   Reply With Quote
Old 11-28-2021, 08:34 AM   #16
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by emce View Post
No, there is an included harness. I followed the dealer installation instructions exactly, which were very straight forward. There's a 3 wire plug hiding in the roof console that you fish out. You then connect that to a harness they supply with the mirror, that takes it from a 3 wire to an 8 pin connection to the mirror. You drop that out of the roof trim down to the mirror, connect it, and you're done. Not really anything to mess up.
Interesting. I read about the signal from the backup system so I tried the HL when in reverse yesterday, but no change.
Old 11-28-2021, 08:45 AM   #17
emce
emce's Avatar
Yeah, I was assuming that was just to let the mirror know when you're reversing so perhaps it doesn't dim for better visibility? Would really suck if the wiring harness that's pre-run through the car is wrong
Old 11-28-2021, 08:54 AM   #18
Yoshoobaroo
TRACKBREAD
Homelink not working
I guess worst case scenario we need a new patch harness, the mirror is getting switched power at least. May need to just tap the switched power into one of the other 10 contacts on the mirror side.
Old 11-28-2021, 09:01 AM   #19
StE92ve
StE92ve's Avatar
Drives: 2014 Mazda CX-5
Here's a long shot: There are some cars with homelink that the sensors are installed somewhere in the vicinity of the front bumper. Tesla and Audi come to mind. What's the chances they didn't install the sensor and just the mirror?
StE92ve is offline   Reply With Quote
Old 11-28-2021, 09:13 AM   #20
emce
emce's Avatar
I guess worst case scenario we need a new patch harness, the mirror is getting switched power at least. May need to just tap the switched power into one of the other 8 contacts on the mirror side.
That's a really good point. Of note, the pin configuration on the mirror actually matches Toyota's mirrors rather than Subaru's. I found this out because I ordered a Dongar wire harness for a dash cam (haven't installed this yet). That harness has a total of 7 pass-thru connections so it seems likely one of those is an additional power connection. Unfortunately I haven't been able to find a schematic for the Toyota mirrors yet.
Old 11-28-2021, 10:03 AM   #21
soundman98
ProCrastinationConsultant
soundman98's Avatar
sounds like the standard homelink connector that they've been using for years. the 3rd wire will be the switched ignition circuit to tell the mirror that the car is powered on.
there's a 4th terminal used for reverse connection, of which that mirror shouldn't require. it's only there for the backup camera display models.
homelink has always built all of their antenna's into the mirror body, i see no reason that they'd change it for this variation.
give the dealers a chance to figure it out, but if they throw their hands up, give this guy a shout. he knows his mirrors.
https://www.bobsmirrors.com/
Yoshoobaroo (11-28-2021)
Old 11-28-2021, 11:31 AM   #22
Yoshoobaroo
TRACKBREAD
Do you have a link to the instructions? I’d like to take a look under there with my multimeter, but it’s not obvious how to get the dome assembly down without messing the headliner panel up.
Old 11-28-2021, 03:36 PM   #23
emce
emce's Avatar
Here's a link about disassembling the dome - it's for an Impreza but same process. You pop the center of the dome out (pry from the side closest to the windshield) and take out the two screws that exposes. There are two clips on the dome, on the side away from the windshield that are pretty easy to pop loose, then the whole dome drops down.
https://www.subaruxvforum.com/attach...16-pdf.243642/
Old 11-29-2021, 12:07 PM   #24
imLawZ
Drives: 2022 BRZ WRB
Glad I found this thread. At least I'm not the only one experiencing these issues.
I took it back to the dealer a few days ago to take a look at it as they were the ones who installed it. They came to the conclusion that it must be something wrong with the mirror so they're ordering me a new one. Hoping it'll worked once it's replaced but seeing other people experiencing the same thing makes me wonder if it's not a defective mirror..
imLawZ is offline   Reply With Quote
The Following User Says Thank You to imLawZ For This Useful Post:
tenderization (11-29-2021)
Old 11-29-2021, 05:13 PM   #25
OkieSnuffBox
Drives: '23 BRZ Limited
I don't have a 2nd gen yet, but I can say I've had multiple cars with Homelink mirrors and none of them worked properly.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
timurrrr (11-29-2021)
Old 11-29-2021, 05:18 PM   #26
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The one in my '20 worked fine. Currently waiting at the dealer for that and my windshield.
Old 11-29-2021, 05:20 PM   #27
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Got my 22 today, it came with the instructions for the homelink i think. Need a pic uploaded?
SpectreRT is offline   Reply With Quote
The Following 2 Users Say Thank You to SpectreRT For This Useful Post:
soundman98 (11-29-2021), Yoshoobaroo (11-29-2021)
Old 11-29-2021, 05:27 PM   #28
dragoontwo
dragoontwo's Avatar
How about a pdf?
The Following User Says Thank You to dragoontwo For This Useful Post:
Tail lights not working, brake lights and turn signals are working Inter Electronics | Audio | NAV | Infotainment 10 09-15-2022 01:50 AM
FS: Homelink mirror SWPinATL Interior Parts (Incl. Lighting) 8 05-22-2015 05:37 PM
DIY Homelink Install DrunkMonkey45 DIY (Do-It-Yourself) Guides 7 12-26-2014 03:57 PM
Homelink fuse Deathalo Electronics | Audio | NAV | Infotainment 2 03-19-2014 02:02 PM
HomeLink FRS dav0777x Scion FR-S / Toyota 86 GT86 General Forum 37 08-02-2013 08:53 AM
