Drives: frs
Raceseng rear tophat bolts
Dear internet brain trust:
Does anybody know if the Raceseng rear top hat bolts are threaded or pressed it? One of mine got an accidental dose of too much hurry. |
#2 |
Drives: '13 FRS - STX
iirc if you flip it over and see a hex key you can unthread it, might be worth filing down the bolt a little so you don't damage the threads in the top hat when taking it apart.
#3 |
Drives: frs
I tried that. I didn't want to put TOO much torque on it and -- as mentioned --make things worse. Are we sure it's threaded?
#4 |
Drives: 2016 BRZ
| The Following User Says Thank You to Joon525 For This Useful Post: | whataboutbob (11-27-2021) |
#5 | |
Drives: frs
It is an M10-1.5, so I had machine screws already that were an exact match. Disaster averted. Last edited by donour; 11-28-2021 at 08:50 AM. |
| The Following 4 Users Say Thank You to donour For This Useful Post: |
#6 |
Drives: frs
Update: Got a message back from Raceseng too. The bolts had threadlocker, which I didn't see when I took them off, but explains the required disassembly torque.
| The Following User Says Thank You to donour For This Useful Post: | strat61caster (11-29-2021) |
| FS: Raceseng 2" rear shock mounts and EBC Yellowstuff rear pads | captain awesome | Brakes, Suspension, Chassis | 5 | 12-15-2020 02:37 PM |
| SOLD: Raceseng Cas Camber Front Top Mounts Fortune Autos Bolts | AustinTCLN | Brakes, Suspension, Chassis | 5 | 09-25-2017 10:53 AM |
| TopHat Issue St Coilovers | drew_kar | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 08-07-2017 09:21 PM |
| FS: Racer X Rear LCA, Hotchkiss Front Bar, Raceseng 1" Rear Drop Mounts | Kuro86 | Brakes, Suspension, Chassis | 4 | 07-26-2017 03:01 AM |
| FS MA: RCE Tarmac 2 with OEM tophat, $1650 | dreamwonder | Brakes, Suspension, Chassis | 8 | 08-09-2016 07:43 AM |
