Old 11-22-2021, 01:15 PM   #421
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I have a Blitz model. If you can hold off on waiting, I'll let you know if it fits sometime in early to mid December.
I'm in no rush but that Megan one is real cheap and looks easy enough to adapt a bar that would clear if needed. At least that's where my head goes on that.
captain awesome is offline   Reply With Quote
Old 11-22-2021, 01:32 PM   #422
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by visbits View Post
Yeah I did mine without any documentation at all lol
Drilling the spotwelds on the strut tower bracket to make more clearance was the only thing I really missed over what they instructed.
I pulled my engine this weekend to replace the transmission already (I strongly recommend power reduction on shifts if you have a turbo build lol) and removed that bracket from my firewall. Previously I just bent it flat but its much nicer removed and wiring rerouted.
This is what concerns me. I plan to keep the power in the 350-375whp 250-275wtq range until I can finish nursing school, which is what I previously had, and then I'll do a BMW tranny swap, or if the new transmission is decently cheap and proven slightly stronger then I'll do that for a while longer. I promised the wife a house upgrade after I get a job as a nurse before any big projects.
Is that just the angle of the picture, or are the AC lines and rear water neck really touching? I had bought some heat shrink wrap, and I planned on dissecting some hose and covering the aluminum lines and then heat shrinking them, so the AC lines were black and not so obvious.
Old 11-22-2021, 01:56 PM   #423
Ebush
Drives: 2017 Hot Lava 86
That would be awesome if the Blitz fits, I have a blitz Widebody on the car so some extra blitz pieces would go great on it.
Ebush is offline   Reply With Quote
The Following User Says Thank You to Ebush For This Useful Post:
Irace86.2.0 (11-22-2021)
Old 11-22-2021, 10:29 PM   #424
Four_wheel_drifts
Drives: Whiteout track car; lava donor
https://www.ft86club.com/forums/show...35#post3483635
Oil pan drain plug clearance issue. Kpower, please address this.
Four_wheel_drifts is offline   Reply With Quote
The Following 2 Users Say Thank You to Four_wheel_drifts For This Useful Post:
Irace86.2.0 (11-22-2021), Jdmjunkie (11-22-2021)
Old 11-23-2021, 11:13 AM   #425
ML
ML's Avatar
Drives: 13 White MT FR-S
Weird, my oil pan drain has plenty of clearance. Sure there isn't a user error here?
The Following User Says Thank You to ML For This Useful Post:
Irace86.2.0 (11-23-2021)
Old 11-23-2021, 11:23 AM   #426
hedtrip
hedtrip's Avatar
Drives: 2013 toyota 86
Do you have a pic for comparison?
hedtrip is offline   Reply With Quote
Old 11-23-2021, 11:40 AM   #427
captain awesome
Wears Pants
I tried looking at the video to compare drain placement on mine. It looks like I might have the same issue, but haven't test fit to check. I went ahead and hammered a little extra clearance just in case though.
Old 11-23-2021, 12:29 PM   #428
Irace86.2.0
I wonder if there is a difference in pan construction or in where the mount bolts all line up.
The question for me is why this spot? Does the drain line up with the oil change opening? It is the lowest part of the pan? Is it off to the side instead of the bottom for ground clearance or undertray clearance issues? What?
Old 11-23-2021, 01:00 PM   #429
captain awesome
Wears Pants
From what I recall in earlier posts about the drain placement, it was so you could use the stock opening.
I know in the instructions they tell you to move the engine/trans as far to the left as possible. Judging by the video of how close the trans is to the sway bar I don't believe it's a fore and aft problem either.
The Following User Says Thank You to captain awesome For This Useful Post:
Old 11-23-2021, 01:01 PM   #430
ML
ML's Avatar
The Following 2 Users Say Thank You to ML For This Useful Post:
captain awesome (11-23-2021), Irace86.2.0 (11-23-2021)
Old 11-23-2021, 01:12 PM   #431
captain awesome
Wears Pants
Oil leaking already lol?
Looks like plenty of space there. I wish I snapped a pic of the plug location on my pan last night for comparison.
Old 11-23-2021, 01:15 PM   #432
ML
ML's Avatar
lol I need to tighten it before I forget!
Old 11-23-2021, 02:07 PM   #433
Ebush
Luckily I tightened my bolt before installing the pan. Kpower sent me an email and said they went through and checked all the pans at the shop and none of them are welded at the corner of the pan like mine. He is sending me a slim drain bolt to try. Unfortunately if it isn’t here by Thursday then I won’t be testing it until maybe March when I change the oil. If you feel like your drain is as far towards the corner as possible maybe have Kpower send you this bolt. Here is a link to it.
https://www.belmetric.com/m14x15-plu...ug-p-6044.html
The Following 2 Users Say Thank You to Ebush For This Useful Post:
Irace86.2.0 (11-23-2021), ML (11-23-2021)
Old 11-23-2021, 02:32 PM   #434
ML
ML's Avatar
crazy you are having all these issues.
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
