#407 |
Drives: 2016 Toyota 86
![]() Looking at the dyno, the ACE does appear to have a 15 ft lbs difference around 3250 rpm. It is hard to tell exactly because some of the ACE's line is missing, but I would guess the ACE has an average of about 10 ft lbs over the JDL between 3200-4200 rpm. For a track or auto-x car, this probably makes very little difference because you would almost never be down in that range of the power band. The increase in power past 7100 rpm is probably more valuable in that situation. However, for a daily driver that is constantly launching from a standstill, the ACE torque advantage between 2300-4500 rpm may be a bit more crucial. At least we have verified proof the ACE is a bit better down low and the JDL is a bit better up top. |
#408 |
My 2 cents: JDL is better in upper range because the primaries are 45 mm (ACE 42.7), ACE is better at lower one because of longer secondaries.
| The Following User Says Thank You to gpvecchi For This Useful Post: | Dzmitry (08-24-2021) |
#409 |
Drives: 2017 BRZ (Sold), 2023 GR86
FWIW my A350 had a flange weld failure too. Cracked right through. It's sitting in my shed collecting dust. I absolutely loved that header but the 4->2 connection coming apart multiple times on track and this weld issue left a sour taste in my mouth :/
Edit: Didn't mean to knock the company or product. It was the best thing I ever put on that car! Sounds like there is a fix so at least I can sell it at some point now that I no longer have the BRZ.
| The Following User Says Thank You to mistople For This Useful Post: | Mike_ZN6 (10-19-2021) |
#410 | |
Drives: 2020 BRZ Sport Tech RS
#411 |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
JDLwith cat. I don't see it on their site now though.
| The Following User Says Thank You to 949 Racing For This Useful Post: | Tatsu333 (10-20-2021) |
#412 |
Drives: Subaru BRZ 2016
More dyno results
This thread seems appropriate for posting dyno numbers I got at Light Touch Tuning. They provided .csv files of the data so I made this graph, rather than posting a screen capture of their software also showing runs we did with another tune.
car: BRZ 2016 mods: JDL 4-2-1, everything else is stock tune: Wayne Rom v167 for ACE, 91 octane fuel |
| The Following 2 Users Say Thank You to NicFromTheNorth For This Useful Post: | J95 (11-19-2021), StraightOuttaCanadaEh (11-18-2021) |
#413 | |
Wes
Instagram: @gt86ws
#414 |
Overall I am satisfied, even though the dip at 3200 rpm bothers me a little because I can definitely feel it. I would recommend this header but I have never driven a UEL equipped BRZ so I don't know whether I'd prefer that setup.
One thing though that can be a little annoying is the hissing sound at certain rpms... I read it is due to the thinner stainless steel walls. Also, in hindsight, I would have bought the overpipe too. Oh and by the way I tested Petro-Canada 94 and I was able to add 2 degrees of timing above 4800 rpm. But I don't have dyno numbers for that. Last edited by NicFromTheNorth; 11-18-2021 at 03:45 PM. |
#415 |
Wes
sorry I'm a bit technically challenged. What exactly does 2 degrees of timing add?
wonder how much more noise the overpipe would result in
Instagram: @gt86ws
#416 |
Drives: brz 2017 hksv2
it adds torque, ergo power
| The Following User Says Thank You to tomm.brz For This Useful Post: | StraightOuttaCanadaEh (11-18-2021) |
#417 |
It's kinda strange there are 2 dips... I would be curious to see what a stock car shows on that Dyno on the same fuel
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
#418 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | J95 (11-19-2021) |
#419 | |
Drives: MY14 BRZ, MY06 WRX
ACE are a bit different, in that the 'overpipe' is actually the last merge collector in the '4-2-1' series, so the 'merging' is done over a much longer pipe length overall. With the JDL, the merging is all done before the overpipe junction. All Wayno's EL tunes have zero per cylinder compensation, but his ACE maps run quite a bit more timing than his other EL maps. Really want to see you succeed, but we may all be hoping for too much from the JDL design, to expect it to run right on an off-the-shelf ACE tune. |
| The Following User Says Thank You to SydBRZ For This Useful Post: | J95 (11-19-2021) |
#420 |
Yes I have, but not on the dyno unfortunately. I did collect data during street pulls and the engine load or VE did show a similar waviness, so I assume that would be reflected on the torque curve too, even if it was shifted up a little.
My objective was to get a first experience with dyno testing, and some sort of a baseline of what my setup can achieve. To be honest the choice of rom between ACE and EL was a bit arbitrary. |
| The Following User Says Thank You to NicFromTheNorth For This Useful Post: | J95 (11-19-2021) |
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
