Old 11-16-2021, 08:38 AM   #1
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Possible TOB Issues
https://www.reddit.com/r/ft86/commen...tm_name=iossmf
This sound goes away when pressing the clutch. I can hear it a little less while driving and on the gas pedal, comes back when coasting. Car has 29K Miles, 2018.
spcmafia is offline   Reply With Quote
Old 11-16-2021, 08:56 AM   #2
Check your pulleys. That has a distinct rattle to it that I have never heard with a TOB.
I am in no way convinced it is the TOB unless you have a failure far different that the rest I have heard.
Old 11-16-2021, 09:01 AM   #3
spcmafia
spcmafia's Avatar
I checked them, I can hear them if I get really close to them, and then sound like always do. But is not as loud as it should be, to be listening to it from inside the car. The only part that leads me to believe is the TOB is because the sound goes away when pressing the clutch.
I don't have issues shifting, and the clutch feels fine. So I really don't know where to start. Maybe just needs grease?
Old 11-16-2021, 10:32 AM   #4
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
that's normal sound. all have that. i even have that after replacing with brand new TOB.
I thought exactly same as you're. when opened up transmission to check and TOB was fine. i replaced clutch and TOB anway
if TOB is failing, you'll hear more than this sound
Old 11-16-2021, 10:35 AM   #5
spcmafia
spcmafia's Avatar
Well that puts me a little at ease. I know these cars are not quiet at all. Is just one of those new sounds that got me wondering. Though it has been reported that certain TOBs go out around the same mileage as mine.
Old 11-16-2021, 10:36 AM   #6
Not sure it is a "normal" sound since I never had it on either of my cars but doesn't sound like the TOB either.
There is no mistaking the sound of a bad TOB
Old 11-16-2021, 10:39 AM   #7
The TOB issue was pretty much from the 13s to the very early 17s when they changed the part. Even then not all of them even had one go.
If your is a TOB you will have the honour of being the very first post 17 car to suffer from it.
Old 11-16-2021, 11:17 AM   #8
spcmafia
spcmafia's Avatar
It seems I have the honor, at least on the forums, of the first reported case of a fuel pump replacement, and also, the first one that had a problem post-repairs.
I don't like these honors.
Old 11-16-2021, 11:18 AM   #9
Well the fuel pumps was a recall so it doesn't count.
Old 11-16-2021, 12:41 PM   #10
PulsarBeeerz
Drives: JRSC BRZ SOLD
Mine makes the same noise even after installing a new bearing, clutch fork, fork pivot and clutch. It's definitely not the sound of a bad TOB. I'm starting to think its the clutch fork rattling on its pivot.
PulsarBeeerz is offline   Reply With Quote
Old 11-16-2021, 12:52 PM   #11
zc06_kisstherain
Drives: SWP BRZ
You are like me having all replaced. Its part of my life now. Lol
Sent from my SM-N986U using Tapatalk
Old 11-16-2021, 03:00 PM   #12
spcmafia
spcmafia's Avatar
So I just turned the car on after coming home from work. No noise anymore. Fixed! It only comes back I’m assuming after the vehicle has been driven and then re-started. Kind of odd.
Old 11-17-2021, 08:53 AM   #13
spcmafia
spcmafia's Avatar
Is definitely something something with the transmission. The car absolutely quiet in the morning when I first start it. The sound comes on by the time I get to work, and it goes away every time I press the clutch. I have no idea what would cause it.
Old 11-17-2021, 09:50 AM   #14
This is again the total opposite of the "normal" TOB issue. It usually is worst when the car is cold and improves when it warms up.
Understeer Issues - Toe Alignment Issues? NutGud Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-29-2021 09:45 PM
Having issues with my first mod Lantanafrs2 Off-Topic Lounge [WARNING: NO POLITICS] 1 04-22-2020 11:51 PM
VVT Issues bobmcboberston Issues | Warranty | Recalls / TSB 2 06-28-2019 08:17 AM
Lug Nut Issues! srizzors25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 04-07-2015 08:25 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 04:41 PM
