Old 07-22-2021, 08:50 PM   #211
73TORANA!
Drives: Orange GTS
The values in fuel tables is the values your asking for, the afr value is the measured value from the afr sensor its never going to be exact especially atfluctuating rpm and loads. at light loads light throttle the ecu will use long and sgort term fuel trims to try to match those up
If iam is lass than 1 the fueling compensation table comes into play and may slightly richen fueling depending on value s in that table
Thx Steve for your reply, I think I may have poorly worded my question. there is no IAM drop and yes I understand you will get a richer mix with an IAM drop. My eng load is around .5 in cruise @ 2k rpm so I was trying to work out from the CL fuel correction table what the commanded AFR should be as apposed to the commanded AFR that im seeing on my OFT as it not what I thought it should be, forget actual AFR at this stage as im just trying to work out the how it is calculated from the tables I can see. I have read that the #2 O2 sensor in a UEL cattless header can cause the commanded AFR in C/L to drop / fluctuate and should have its table set to zero ??? thoughts. Cheers.
73TORANA! is offline   Reply With Quote
Old 07-23-2021, 09:07 AM   #212
steve99
Drives: FT86
Ok
OFT in general logs commanded afr about 0.2 afr points leaner than the correct value, jist a logging error i believe
Also in cruise mode the ecu also looks at the rear 02 senspr and apples a coreection to afr known as #AF3 correction, this is not reflected in commaned afr logged parameter.
You need to log #AF3 not sure if oft logs that
This can cause measured afr feom the front wideband 02 to drift from the commanded afr.
The rear 02 is only narrowband and only used for cat monitoring and cruise fueling correction.
Generally I zero out #af3 coreection in tune and many headers put the rear 02 in a long tube so fhe rear 02 sensor doesnt read correctly.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
73TORANA! (07-24-2021), Compelica (07-24-2021)
Old 07-24-2021, 06:43 AM   #213
73TORANA!
Drives: Orange GTS
Thanks Steve,
I set the #AF3 tables in rom raider to "0" and went for a drive. It made a big difference. The Command AFR in C/L cruise is 14.89 - .2 logging error is 14.69 and the actual AFR is 14.58 with minor fluctuations as it was with the factory headers. The actual AFR reading is a lot more stable as well. Thanks for your help in clearing this up for me. I did feel the second O2 was for catt efficiency, its makes sense. I recon setting #AF3 to zero will most probably also help with LTFT learning. Cheers
Old 07-24-2021, 10:50 AM   #214
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks Steve,
This is interesting. But does it actually affect commanded AFR though, as @steve99 mentioned that it shouldn't.
Compelica is offline   Reply With Quote
Old 07-24-2021, 10:08 PM   #215
steve99
Drives: FT86
Its a bit confusing
the #af3 correction does appear to make a difference to the actual target afr in cruise mode. However sometimes you dont see it effect the logged commanded afr paramter. I suspect some systems log commanded afr parameter before the #af3 is added to it, and some dont.
Old 07-24-2021, 10:45 PM   #216
73TORANA!
Drives: Orange GTS
Quote: "This is interesting. But does it actually affect commanded AFR though, as @steve99 mentioned that it shouldn't"
In my case as mentioned it did affect the commanded AFR.
The commanded AFR that I am seeing now follows closely what I can calculate by subtracting the C/L fueling correction table from 14.7 It logs it at 0.2 higher as Steve mentioned and does seem to be a bit hit and miss with its refresh rate. BUT the actual AFR in C/L now also follows the C/L fuel correction table more accurately although 0.2 AFR lower as I believe the OFT logs the AFR at actual - 0.2 lower. It may also be my imagination the car feels much smother maybe because its not chasing its tale ??
Old 07-25-2021, 12:06 AM   #217
Compelica
Compelica's Avatar
Drives: 86 GT
Its a bit confusing
That was my initial guess as well, there are likely two commanded AFR parameters pre and post AF#3.
I have not tried this yet, but I usually log AFRs via OBD2 as well - my take is that the commanded AFR shown in the OBD2 standard PID should be post-AF#3 since that value makes more sense when doing a diagnosis.
Old 07-26-2021, 06:55 AM   #218
tomm.brz
Drives: brz 2017 hksv2
No FBKC at all, and loads are well under the load limits. Here's the log if it helps illustrate things:
https://datazap.me/u/compelica/knock...?log=0&data=20
too much PI on high rpm
reduce it and put more DI to help , or just reduce the advance timing
i would also scale a bit better the maf scaling where afr is getting leaner on mid high rpm so it helps to not trigger the knocks
Old 07-26-2021, 07:23 AM   #219
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks @tomm.brz for the insight, I was asking on the low RPM high load situation and whether there it is possible to advance past MBT.
Old 07-28-2021, 08:13 AM   #220
tomm.brz
well don t rise too much the timings in low load zone, no need to
Compelica (07-29-2021)
Old 07-29-2021, 06:04 AM   #221
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks Steve,
@73TORANA! which AF #3 tables did you specifically alter?
Old 10-20-2021, 12:10 PM   #222
J95
J95's Avatar
@Wayno may I ask for some support here,
I do have a JDL EL 4-2-1 and I am considering to purchase your tune (Stg 2 EL), because it seems that OTS Stg 2+ is probably intended for UEL.
I read from your page "EL has more exhaust retard and more intake advance", so I do understand that the vvt tables are optimized for a EL header. I wonder which kind of impact this have in the real feeling of the car then then, what are the practical gains that I will have by flashing this tune? Does it matters that my header is 4-2-1 instead of 4-1?
I just like to know what I am exactly getting, before dropping the cash
J95 is offline   Reply With Quote
Old 11-14-2021, 09:58 PM   #223
Espi
Espi's Avatar
Drives: 17 BRZ
First off MASSIVE THANK YOU to @Wayno
Currently running greddy snorkel, hks intake, jdl uel catted header, motiv OP, stock fp/exhaust - tuned with stage 2 - 93 cat "Default" Rom by Wayno
My experience with different tunes with above mods:
Stage 1 OFT Tune - Ran this for a little before getting my emissions and it wasn't anything special but it did give a LITTLE "something" to acceleration feel. Nothing too crazy though. Engine sounds terrible but thats the FA20 for ya outside of Stock tune
Stage 2 OFT Tune - Ran well butt dyno was okay compared to stage1. It did have some rough starts, boggle on cold shifts (6AT) and low RPMS. Down shifts sometimes was a little rough. Although the car did feel better with the stage 2 tune, it was a little rough overall and left me wanting more of a better tune. Engine still sounded kind of blah on this tune also.
Wayno Rom Stage 2 93 CAT Default Tune OFT - I feel the car pulling in certain RPM's much better and WAY smoother. Cold starts and shifts is buttery smooth, car just feels like its running so smooth and butt dyno feels more "pull/power" in certain RPMs. Its noticeable compared to Stage 2 OFT tune. The tune has really "wakened up" the car and feels punchier than ever on throttle. Cruising on highway feels and sounds much smoother also. Engine noise is much better and doesn't sound as rough as previous OFT tunes.
Thank you Wayno for your ROM! Very impressed and super thankful.
Espi is offline   Reply With Quote
The Following User Says Thank You to Espi For This Useful Post:
knapper (11-19-2021)
Old 11-15-2021, 05:06 PM   #224
AlinaBetka
Drives: Fast
Thanks a loooooot!
AlinaBetka is offline   Reply With Quote
Maximum weight in the trunk? djmm Scion FR-S / Toyota 86 GT86 General Forum 20 08-13-2015 12:40 PM
“Maximum Attack” Scion FR-S stugray Scion FR-S / Toyota 86 GT86 General Forum 13 02-01-2015 09:45 PM
PA: Rays Gram Light 57 Maximum 5x100, 17x8, +43 (Price Reduced!) Needs more cowbell Wheels and Tires 20 02-22-2013 11:03 AM
MAXIMUM you would pay for a TRD Supercharger installed? FRiSson Forced Induction 24 11-04-2012 01:08 AM
MR-S Effect... Dimman CANADA 11 09-06-2011 12:49 PM
