Old 11-11-2021, 11:16 PM   #43
As weaknesses in the process definition came to light, those documents were updated to close those gaps. Keeping your first question in mind, I think you'll find it interesting to note the changes.
CockpitCruiser (11-11-2021), NoHaveMSG (11-11-2021)
Old 11-11-2021, 11:20 PM   #44
CockpitCruiser
Custom Title
CockpitCruiser's Avatar
Drives: GT86
If you follow the FSM, there is an area for the sealant, but you do not apply it into that area. I believe that is an area where a lot of techs that where doing the spring recall screwed up.
I used TB1217H when I did mine. Using a good caulking gun will give you better control when applying the sealant. Make sure you have a nice no slip work surface to place the timing cover, makes it a lot easier. The FSM has application instructions for the sealant, but you have like 10-15 minutes once you apply it to the cover, to get the cover on and torque it IIRC.
There are a bunch of different length bolts. Trace the timing cover onto a piece of cardboard and punch the bolt through the cardboard in it's location to keep track of it. The perimeter bolts are 8mm, three inner bolts are 6mm. They have different torque specs.
I would also go to the hardware store and get about 4 5in long 8mm bolts and grind the heads off to use as guides. Will make getting the cover on a lot easier.
Very informative - I like the last idea with the bolts ground off - great idea. I was wondering how I was going to do this with just two hands
Eat, Sleep, Drive, Work, Drive, Ride, Eat, Sleep. Repeat
CockpitCruiser is offline   Reply With Quote
Old 11-11-2021, 11:27 PM   #45
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I used the OG instructions and I can tell where others could have mistaken the way the sealant is supposed to be applied. In some areas when doing the cam carriers and head covers I used red marker to indicate where not to apply it so I didn't get it somewhere you were not supposed to. The guy who originally put the engine together put it on oil passages too. I guess it was all moot since that was the engine that kicked a rocker and exploded at the Ridge
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (11-12-2021), Ultramaroon (11-11-2021)
Old 11-11-2021, 11:39 PM   #46
Seeing that slop would still irritate the hell out of me. Your dowel technique is brilliant, BTW.
bcj (11-12-2021), NoHaveMSG (11-12-2021)
Old 11-12-2021, 01:36 AM   #47
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It was pretty bad. Especially after the guy told me “I don’t build crap engines.” He worked at a Toyota dealership in Willsonville, wonder if he’s still there.
I have my moments lol
Old 11-12-2021, 01:40 AM   #48
It was pretty bad. Especially after the guy told me “I don’t build crap engines."
Asshole
Old 11-12-2021, 03:15 PM   #49
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Did you decide not to use the rocker arm retainers?
Old 11-12-2021, 03:34 PM   #50
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Different engine, this one blew April 2020. I was waiting on my UOA to come back on my current engine to make sure it was healthy enough to use for another year. I will be putting the retainers in that engine in Dec/Jan along with a bent up Bluemoon oil pan baffle
Old 11-13-2021, 04:04 PM   #51
blsfrs
blsfrs's Avatar
My builder went with the Greddy baffle. I guess he liked the name better. I'm curious as to much the oil sloshes to one side in a high G turn. Maybe as a winter project, somebody can put a container of hot oil in a centrifuge and see how many G's it takes to move the oil away from the pickup.
Old 11-13-2021, 08:45 PM   #52
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I imagine it is a pretty high number. I think in most cases I see it in my car it is a sudden spike in G’s that is doing it. One track I don’t have it happen at all.
blsfrs (11-14-2021)
Old 11-22-2021, 04:54 PM   #53
CockpitCruiser
Custom Title
Drives: GT86
I've saved every one of those files. It's worth just nabbing all and reading them. Good stuff in addition to the FSM. See link in my sig line.
is there a printed form of the entire manual for this vehicle as in the link on your sig, or is it all only online?
Old 11-22-2021, 10:07 PM   #54
I don't think anyone sells a printed manual. Sad. I would buy it.
CockpitCruiser (11-29-2021), humfrz (11-23-2021)
Old 11-23-2021, 03:21 AM   #55
I got the picture. Large print manual with lots of pictures -
Ultramaroon (11-23-2021)
Best places for stickers lastexile1987 Cosmetic Modification (Interior/Exterior/Lighting) 58 02-01-2020 01:32 AM
Places to get stuff Qwimby2 BRZ First-Gen (2012+) — General Topics 4 12-24-2015 09:30 PM
Best Places to go? BPM CANADA 0 10-25-2013 02:56 AM
Best places to take my car for a wash slowbrz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 06-14-2013 04:01 PM
places you've been, or want to go wallace03 Off-Topic Lounge [WARNING: NO POLITICS] 4 06-18-2012 02:40 AM
