| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#29 | |
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | CockpitCruiser (11-07-2021), Tcoat (11-11-2021) |
#30 |
Custom Title
Drives: GT86
Am I the only one who, with an oil leak around the timing chain cover, forgot to drain and refill their anti-freeze at or before 60k miles? I think this may have had some effect on the breakdown of the rtv seal around my timing chain cover.
Also, how feasible is it to create a rubber gasket for the chain cover, rather than using the rtv as a gasket?
Eat, Sleep, Drive, Work, Drive, Ride, Eat, Sleep. Repeat
#31 | ||
| The Following User Says Thank You to Ultramaroon For This Useful Post: | CockpitCruiser (11-11-2021) |
#32 |
AutoX-10/10ths every run
Sometimes the oil leaks aren't visible from the outside....
| The Following 2 Users Say Thank You to whataboutbob For This Useful Post: | CockpitCruiser (11-11-2021), Ultramaroon (11-08-2021) |
#33 |
I can’t believe no one has stated the most common oil leak on our engine is the hole in the side of the block from the rod!
| The Following 2 Users Say Thank You to Grady For This Useful Post: | Ultramaroon (11-11-2021), x808drifter (11-11-2021) |
#34 |
Drives: Crapcan
The rod usually cracks the top of the block. The heads are on the sides. If it is leaking from the side you have likely ejected a rocker arm.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (11-11-2021) |
#35 |
| The Following 2 Users Say Thank You to Grady For This Useful Post: | NoHaveMSG (11-12-2021), Ultramaroon (11-11-2021) |
#36 | ||
Custom Title
Drives: GT86
Ok, that makes sense - Robots create engines now, whereas men built the engines that I've rebuilt in the past. But just because it was created that way, doesn't mean I couldn't create a gasket to make things easier, even though it would be a massive gasket.
#37 |
Custom Title
Drives: GT86
I saw on this website (somewhere,) a link to the exact sealant to use to complete this task, (timing chain sealant application,) and the complete directions from a manual to get the job done, but I was on another computer and google won't let me find that link on this computer. Can somebody help me find that link? I believe it was Tcoat that shared the link or info. Thank you
#38 | |
#39 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
The most recent sealing procedure info was updated for the valve spring replacement.
Should be in one of those threads. This is the first one I could dig up. It says "Revised" but you could do some more digging. https://static.nhtsa.gov/odi/rcl/201...8V772-6522.pdf
"I gotta rock." -- Charley Brown |
| The Following 2 Users Say Thank You to bcj For This Useful Post: | CockpitCruiser (11-11-2021), Ultramaroon (11-11-2021) |
#40 |
I've saved every one of those files. It's worth just nabbing all and reading them. Good stuff in addition to the FSM. See link in my sig line.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | bcj (11-11-2021), CockpitCruiser (11-11-2021) |
#41 | |
Custom Title
Drives: GT86
Liquid Gasket Threebond 1280B
![]() ...who gave the following link; https://www.ft86club.com/forums/atta...1&d=1413834741 Note in pdf above, page 4; re-seal using Liquid Gasket ThreeBond 1280B (Part No. SOA5499100) or equivalent Now, a couple final questions, before handing this off to my tech ![]() 1. Does the chain cover have a gutter for the sealant to reside in, or are both mating surfaces flat? 2. Once the sealant is applied, what is the recommended time to wait for the sealant to properly cure before mating the surfaces? I read somewhere it's 24 hours, but then a tech on YT said a couple hours... (Robotic machines use a uv light to speed it up) Thanks
#42 | |
Drives: Crapcan
Where are all the possible places oil can leak from the FRS/BRZ?
If you follow the FSM, there is an area for the sealant, but you do not apply it into that area. I believe that is an area where a lot of techs that where doing the spring recall screwed up. I used TB1217H when I did mine. Using a good caulking gun will give you better control when applying the sealant. Make sure you have a nice no slip work surface to place the timing cover, makes it a lot easier. The FSM has application instructions for the sealant, but you have like 10-15 minutes once you apply it to the cover, to get the cover on and torque it IIRC. There are a bunch of different length bolts. Trace the timing cover onto a piece of cardboard and punch the bolt through the cardboard in it's location to keep track of it. The perimeter bolts are 8mm, three inner bolts are 6mm. They have different torque specs. ![]() I would also go to the hardware store and get about 4 5in long 8mm bolts and grind the heads off to use as guides. Will make getting the cover on a lot easier.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
| Best places for stickers | lastexile1987 | Cosmetic Modification (Interior/Exterior/Lighting) | 58 | 02-01-2020 01:32 AM |
| Places to get stuff | Qwimby2 | BRZ First-Gen (2012+) — General Topics | 4 | 12-24-2015 09:30 PM |
| Best Places to go? | BPM | CANADA | 0 | 10-25-2013 02:56 AM |
| Best places to take my car for a wash | slowbrz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 06-14-2013 04:01 PM |
| places you've been, or want to go | wallace03 | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 06-18-2012 02:40 AM |
